Thread: Abs pump leak
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. Ableeding abs/abs pump leak
    Aug 2014
    uk
    I have a 2001 1.9 tdi passat sport estate. Break fluid is leaking quickly from the abs pump that sits in the nearside wing when pedal is pressed. New pump only solution ?
  2. Re: Abs pump leak
    Jan 2010
    southport
    Where brakes are concerned, always buy New.
    If it's leaking from a brake pipe only, try tightening it up. If it's leaking from within the unit/from the sides. Replace the unit and bleep up the brake system afterwards.
    2000 2.5TDI Quattro 173,000miles, just run in...Sold
    2006 TT 3.2 Quattro 40,000miles
    2005 A6 Avant 3.0TDI Quattro
  3. Re: Abs pump leak
    Aug 2014
    uk
    Aye its Deffo leaking from the unit, probably be one from a breaker. Just a case of changing the unit like for like and then bleeding all brakes ?
  4. Re: Abs pump leak
    Jan 2010
    southport
    That's up to you, just make sure all the codes/serial numbers match.
  5. Re: Abs pump leak
    Aug 2014
    uk
    It's just a case of usual brake bleeding after? I read something about having to use vag to bleed the pump/unit. Cheers
    edit:
    just a case of matching these numbers, 3B0614111 0265220621
    leak is coming from under this
  6. Re: Abs pump leak
    Aug 2014
    uk
    fitted another pump, trying to bleed the brakes, starting at the rear offside... using ezibleed, there is very little comming out the bleed niple, and when i remove the ezibleed from the tyre the fluid the in the ezibleed bottle refills..
    is it possible the fluid isnt passing the abs pump?
  7. Re: Abs pump leak
    Aug 2014
    uk
    i have vcds lite, but not sure how to log into it?
  8. Re: Abs pump leak
    Jan 2010
    southport
    I can't help you with that.
    When I was having issues with my rear brakes, people on here told me not to let my brake fluid bottle get empty. If I did I would need vcds to bleed system, to get fluid through the abs pump.
    Im sure someone will be able to tell you how soon.
  9. Re: Abs pump leak
    Aug 2014
    uk
    i tried bleeding the brakes the old skool way, a few pumps on each corner, there are brakes but its like theres alot of air still in the system.... anyone any idea if its worth while doing this again or trying ezibleed again?
  10. Re: Abs pump leak
    Aug 2014
    uk
    hope this can shed some light
    VCDS-Lite Version: Release 1.2
    Saturday, 06 August 2016, 13:25:19:3906
    Chassis Type: 3B - VW Passat B5
    Scan: 01,02,03,08,15,16,17,19,35,36,37,46,47,55,56,57,58 ,75,76,77
    Address 01: Engine Labels: 038-906-019-AVF.LBL
    Controller: 038 906 019 EP
    Component: 1,9l R4 EDC G000SG 1442
    Coding: 00002
    Shop #: WSC 05314
    VCID: 69A531E50061
    WVWZZZ3BZ2E154738 VWZ7Z0A4011569
    1 Fault Found:
    18057 - Powertrain Data Bus: Missing Message from ABS Controller
    P1649 - 35-10 - - - Intermittent
    Readiness: N/A
    Address 03: ABS Brakes Labels: 8E0-614-111-ASR.LBL
    Controller: 3B0 614 111
    Component: ABS/ASR 5.3 FRONT D00
    Coding: 00012
    Shop #: WSC 02325
    VCID: D3D9730D32ED
    No fault code found.
    Address 08: Auto HVAC Labels: 3Bx-907-044.LBL
    Controller: 3B2 907 044 J
    Component: CLIMATRONIC B5GP 0003
    Coding: 17000
    Shop #: WSC 05311
    VCID: 292571E5C0E1
    1 Fault Found:
    01274 - Air Flow Flap Positioning Motor (V71)
    37-10 - Faulty - Intermittent
    Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
    Controller: 1C0 909 605 B
    Component: 0A AIRBAG VW51 04 02
    Coding: 12353
    Shop #: WSC 05311
    VCID: 233963CDA2CD
    1 Fault Found:
    00532 - Supply Voltage B+
    07-10 - Signal too Low - Intermittent
    Address 17: Instruments Labels: 3B0-920-xx5-17.LBL
    Controller: 3B0 920 926 A
    Component: KOMBI+WEGFAHRSP VDO V01
    Coding: 05415
    Shop #: WSC 00700
    VCID: 223766C9BDD7
    1 Fault Found:
    01316 - ABS Control Module
    49-10 - No Communications - Intermittent
    Address 19: CAN Gateway Labels: 6N0-909-901-19.LBL
    Controller: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 05314
    VCID: F093DC81A3BB
    1 Fault Found:
    Address 46: Central Conv. Labels: 1C0-959-799.LBL
    Controller: 1C0 959 799 B
    Component: 0M Komfortgerát HLO 0003
    Coding: 00258
    Shop #: WSC 05311
    VCID: 361FAA99015F
    2 Faults Found:
    01131 - Control Circuit for Turn Signals
    25-10 - Unknown Switch Condition - Intermittent
    00929 - Locking Module for Central Locking; Front Passenger Side (F221)
    27-00 - Implausible Signal
    Address 56: Radio Labels: 1J0-035-18x-56.LBL
    Controller: 1J0 035 186 D
    Component: RADIO SON 0003
    Coding: 05403
    Shop #: WSC 05311
    VCID: 263F7AD9D1FF
    1 Fault Found:
    00853 - Loudspeaker(s); Rear
    36-10 - Open Circuit - Intermittent
    End --------------------------------------------------------------------------------------------------
  1. Tandem pump leak
    By alevuc in forum Octavia
    Last Post: 04-07-2016, 01:16 PM
  2. Fuel Pump Leak...
    By Nigella in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-12-2013, 09:32 AM
  3. vaccuum pump leak
    By windyj in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-01-2013, 02:37 PM
  4. Replies: 13
    Last Post: 15-12-2011, 08:58 AM
  5. tandem pump leak
    By nickeym1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-09-2009, 05:16 PM
