Thread: A3 TDI 2.0 8p weird starting issue
  1. A3 TDI 2.0 8p weird starting issue
    Jul 2016
    Northampton uK
    Hi everyone,
    I hope you can help me with my 2.0tdi. It has a number of issues which the search has helped me with (timing torsion causing rough idle as the 2nd biggest) but can't seem to see anything on my main issue...
    The car presents with flat battery symptoms that don't appear to be necessarily a battery issue.
    • If the car stalls when driving along it will not start (starter clicks as though not enough juice to turn over)
    • If I return to the car within 15 minutes it will not start
    • If I leave it at least 20 minutes car will fire up fine
    • car will start no problem after being left for a week untouched
    • When the car fails to start, if I can push it enough and use second gear, this will make the car start. But I get the impression this is more something being shaken as I really don't think i'm strong enough to achieve a diesel bump start.
    Car will always jump start fine. I'm really confused about what it can be. Surely a battery would be the opposite (ok after a minute but refuse to start if left for time).
    Common sense says a loose connection or dodgy earth / ground but I wouldn't have a clue about where to look.
    Please help!
    Jimmy
  2. Re: A3 TDI 2.0 8p weird starting issue
    Jun 2016
    United Kingdom
    Put some jump leads to the starter motor and see if it actually starts bypass the starter solenoid and wiring and ground issues
    Also stalling whilst driving can insinuate battery terminals being an issue, remove them using a 10mm spanner, clean the mating surfaces and tighten
  3. Re: A3 TDI 2.0 8p weird starting issue
    Jul 2007
    glasgow
    35 Post(s)
    I would suspect the starter
    My A6 tdi has to start AFTER I wait for the glow plug lights go out, hot or cold .
    Try that as its free ............................ plus it extends the life of the glow plugs .........................plus its good practice to wait 1 to 2 seconds after the glow plug light goes out as they are still heating up
  4. Re: A3 TDI 2.0 8p weird starting issue
    Jun 2016
    United Kingdom
    Quote Originally Posted by niall campbell View Post
    His car stalls when driving which insinuates a loss of the 12V feed, plus intermittent starting so more likely to be a loose Battery terminal or battery chassis ground
  5. Re: A3 TDI 2.0 8p weird starting issue
    Jul 2007
    glasgow
    35 Post(s)
    yes possibly, would need to drive incase its just stalling due to driving style ........................ my 2.0 A6 stalls very easy and takes a bit of getting used to
    Does the A3 have a clutch pedal switch for starting ?
  6. Re: A3 TDI 2.0 8p weird starting issue
    Jun 2016
    United Kingdom
    A3 does have a clutch switch
  7. Re: A3 TDI 2.0 8p weird starting issue
    Jul 2007
    glasgow
    35 Post(s)
    ok thanks, in my A6 I would get a flashing glow plug light if this is faulty
    For a free check I would test battery for any dud cell(s) and the voltage of the alternator charging ........................ just my humble opinion & fault diagnosis
    Checking all electrical connections are clean, no green gunge, tight and no chaffing of wires around engine block a must ................. again free
    Then a scan which costs money
  1. 2.0 TDI 170 starting issue
    By Territouran in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-05-2015, 05:57 PM
  2. A3 2.0 FSI 2003 problems starting when warm & weird rear wiper issue?
    By Rick_C in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 17-10-2013, 11:21 PM
  3. 2004 TDI Polo Weird starting problem
    By rg1642 in forum Polo - Derby - Lupo - Fox
    Last Post: 04-02-2012, 09:32 PM
  4. Please Help Starting issue A4 1.9 TDI 90
    By Connor_Scotland in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-12-2010, 12:22 AM
  5. A6 2.5 TDI SE (1995) Starting issue
    By M V E Pullen in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 07-01-2008, 04:34 PM
