Thread: 12v socket always live??
  1. 12v socket always live??
    Sep 2014
    Norwich
    Hi all,
    I'm fitting a dashcam which powers from the 12v cigarette socket on the centre console, trouble is this socket is always live even with the ignition off and so the dashcam will not turn off.
    I've read some A3 threads on a fuse switch which can toggle between permanent and ignition on but this doesn't seem to work for my 8P model.
    Any ideas or am I just gonna have to plug and unplug every time I want the dash cam to start / stop?
    Thanks in advance
    Audi A3 2.0 TFSI DSG S Line 2006
  2. Re: 12v socket always live??
    Dec 2015
    Manchester
    When I looked into doing this you can piggy back off a switched live in your fuse box, get some testers and test to see which fuse comes live when you switch the ignition on, there will be some in there 100% just the fun job of routing the wires! I even thought about souring it off the switched live into the stereo but I'm not sure what implications it may cause
  3. Re: 12v socket always live??
    Sep 2014
    Norwich
    ok thanks, not a simple one but I'll give it a go
  4. Re: 12v socket always live??
    46 Post(s)
    The fuse position for the rear wiper is where I have a fuse-tap for my dashcam into, obviously ignition live.
  5. Re: 12v socket always live??
    Sep 2014
    Norwich
    Quote Originally Posted by Chris View Post
    so is your rear wiper still fused?
  6. Re: 12v socket always live??
    46 Post(s)
    Yes, using a fusetap.
    One fuse slot for the dashcam (or anything else you have connected) and the other for the equipment fed originally by the fusebox.
  1. 12V lighter power socket - always live?
    By madman123 in forum Audi A4 - B9 Forum - 2015 -
    Last Post: 09-05-2016, 05:23 PM
  2. 12v socket
    By Steve1803 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 09-05-2014, 09:45 PM
  3. 12v Boot Socket Change to Permanent Live
    By adstalker in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-07-2010, 08:17 PM
  4. 12v power socket
    By passat tdi130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-12-2008, 12:47 AM
  5. 12v socket?
    By frank99jc in forum Passat - Archive Topics
    Last Post: 19-11-2006, 01:08 PM
