Thread: 2012 A6 3.0T cooling/AC fans stopped working - Fuses?
Results 1 to 9 of 9
  1. 2012 A6 3.0T cooling/AC fans stopped working - Fuses?
    Jul 2016
    Chicago, IL USA
    Hi...
    Both of my cooling fans stopped working at the same time, VAG showing short to ground. I want to check the fuses but I have no idea where they are. Can anyone give me any information on where these may be located in the c7 models? I have a US left drive version, but I would think it would be similar. I assume the fuses are in the engine compartment, but I can t find them. Any help MUCH appreciated!
    VAG:
    Address 01: Engine (J623-CGXB) Labels: 06E-907-551-CGW.clb
    Part No SW: 4G0 907 551 A HW: 4G0 907 551 A
    Component: 3.0l V6 TFSIH07 0008
    Revision: --H07---
    Coding: 0A2A0034052600060000
    Shop #: WSC 02311 785 00200
    ASAM Dataset: EV_ECM30TFS0214G0907551A 003009
    ROD: EV_ECM30TFS0214G0907551A.rod
    VCID: 2757D80D5E42AF061F-8072
    3 Faults Found:
    6140 - Fan 1 Control Circuit
    P0691 00 [045] - Short to GND
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 118277 km
    Date: 2016.07.07
    Time: 19:05:43
    6143 - Fan 2 Control Circuit
    P0693 00 [045] - Short to GND
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 118291 km
    Date: 2016.07.07
    Time: 20:11:14
    18198 - Coolant pump
    P1B1C 00 [045] - Mechanical malfunction
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 118377 km
    Date: 2016.07.08
    Time: 18:14:03
    Readiness: 0000 0000
  2. Re: 2012 A6 3.0T cooling/AC fans stopped working - Fuses?
    Jul 2016
    Chicago, IL USA
    Quote Originally Posted by mattbult View Post
    Hi...
    Ok, I found the box, its under the ECM, which is under the washer fluid reservoir, which is under the plenum chamber cover. Now to see if the cooling fan fuse/fuses are actually in there and if anything is blown. If anyone has a fuse/relay diagram of the connections in that box, please share. Thanks!
  3. Re: 2012 A6 3.0T cooling/AC fans stopped working - Fuses?
    Aberdeen
    63 Post(s)
    If you have an owners manual, I suggest you have a look. As far as I know there are fuses in the luggage compartment, engine bay and (on your car) in the drivers side dash panel. There's a list of the fuses in the manual as well.
  4. Re: 2012 A6 3.0T cooling/AC fans stopped working - Fuses?
    Jul 2016
    Chicago, IL USA
    Quote Originally Posted by Scott K View Post
    Thanks Scott... Yes, the owner's manual has great info on the two passenger compartment fuse boxes (dash left/right) as well as the trunk (right side storage compartment). It has no information on the engine bay fuses or relays, unfortunately. I would need to find someone with a service manual for that, apparently.
    thanks,
    -m
  5. Re: 2012 A6 3.0T cooling/AC fans stopped working - Fuses?
    Aberdeen
    63 Post(s)
    Could also be the control module. Hopefully someone like Crasher will be along soon and can help you or get a look on elsawin.
    1 1 0
  6. Re: 2012 A6 3.0T cooling/AC fans stopped working - Fuses?
    Jul 2016
    Chicago, IL USA
    Thanks to everyone who checked this thread. Found the fuses, both 40A, both blown. Replaced with new 40 amp fuses and both fans operating properly, still working after about an hour. Maybe just a perfect storm of electrical overload, I literally got a call on bluetooth, closed the sunroof and auto-up on the windows, turned on the a/c, and had been sitting stationary in traffic in the heat for 15 minutes. Going to reset the codes with vag/com and see how it goes. If anyone needs help finding these fuses, let me know. They were not in the e-box under the ECM and washer reservoir. They were in a separate panel under the crossmember. Just about the most difficult location possible.
    -m
  7. Re: 2012 A6 3.0T cooling/AC fans stopped working - Fuses?
    Jul 2016
    New jersey
    I am having this issue...saw the pic(thank you)where are those fuses? You said under the crossmember but where exactly?
  8. Re: 2012 A6 3.0T cooling/AC fans stopped working - Fuses?
    Jul 2016
    Chicago, IL USA
    Quote Originally Posted by Peterdm22 View Post
    I'll post pics tonight, but it's exactly in the rear middle of the engine compartment under the plenum cover and then under the aluminum crossmember. You need a special tool to get the crossmember off,, not sure of the technical term but it's a spline style male socket. I can post more tonight when I get to the office where the pics are.
  9. Re: 2012 A6 3.0T cooling/AC fans stopped working - Fuses?
    Jul 2016
    Chicago, IL USA
    Peter, hopefully these two pics will help you find the cooling fan fuses:
    The day after I changed the fuses was 85 degrees. I spent about 2 hours idling with the air on both as a test and because I had some field work to do, no problems with fans or fuses. This weekend I went to michigan an sat in traffic for at least an hour with no problems. So far so good, but I bought a few spares just in case (fuse part no N10424906) get them from AutohausAZ, $0.50 each. Audi wanted $10 each and VW sold them to me for $3.70 each. Hard to find too, two local audi dealers didn't have them.
    Good luck, let me know if you have any questions.
    -m
  1. Replies: 5
    Last Post: 06-06-2015, 10:44 AM
  2. Please Help Cooling fans not working :/
    By Bob Vega in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 03-10-2013, 11:50 PM
  3. Please Help A3 Cooling fans always on
    By MAFED in forum Audi A3 - Archive Topics
    Last Post: 06-03-2009, 11:33 PM
  4. Please Help cooling fans not working
    By denimblues3 in forum Audi A3 - Archive Topics
    Last Post: 04-11-2008, 09:11 PM
  5. A6 cooling fans
    By firefox in forum New Member Introductions
    Last Post: 02-05-2008, 10:43 AM
