Thread: What on Earth is going on with the MMI???
Results 1 to 10 of 15
  1. What on Earth is going on with the MMI???
    Jun 2014
    Uckfield, East Sussex, UK
    Hi all,
    I've just come back from a 2 week holiday and have found the MMI in my car to be faulty.
    At first I thought 'oh dear me, the rear washer has leaked' but after checking, it's bone dry in there.
    Symptoms - The MMI with the engine on starts up and I get a splash screen on the 2G High screen, and I get the correct lights on the centre console. After the MMI boot screen, the screen and centre console lights go off.
    So I tried again and again with the same results.
    Until, I tried the electrics with the engine off. Everything works as it should running on the battery... Bluetooth works fine, Radio (DAB, FM, LW, MW etc.), Sat Nav, voice control, AMI USB stick etc. with the correct lights on the centre console.
    So I got the VCDS out (please see below)...
    Code:
    01-Engine -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    06-Seat Mem. Pass -- Status: OK 0000
    07-Control Head -- Status: Malfunction 0010
    0E-Media Player 1 -- Status: OK 0000
    0F-Digital Radio -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    34-Level Control -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    57-TV Tuner -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    67-Voice Control -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
       Part No SW: 4F1 910 732 E    HW: 4E0 035 729 A
       Component: Interfacebox    H43 5570
       Revision: 00000000    Serial number: 351GM067522444
       Coding: 0001002
       Shop #: WSC 02335 785 00200
       VCID: 264457EE915B650E24-8072
       Subsystem 1 - Part No: 4F0 910 609 E
       Component: Bedienteil MMIC6H02 0060
       Subsystem 2 - Serial number: 00000000485403
       Subsystem 3 - Serial number: 0128.07.060000000100010191ÿ
       Subsystem 4 - Serial number: 010191ÿ
    1 Fault Found:
    00384 - Optical Databus
                011 - Open Circuit - Intermittent
                 Freeze Frame:
                        Fault Status: 00101011
                        Fault Priority: 5
                        Fault Frequency: 11
                        Reset counter: 40
                        Mileage: 172906 km
                        Time Indication: 0
                        Date: 2016.07.02
                        Time: 16:18:14
    Address 19: CAN Gateway        Labels: 4F0-910-468.clb
       Part No SW: 4F0 910 468 A    HW: 4F0 907 468 D
       Component: Gateway         H11 0070
       Revision: 11          Serial number: 130080672101F2
       Coding: ECEE7BDC1B7D04
       Shop #: WSC 02334 785 00200
       VCID: 275A5AEA96517C061F-8072
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 4
                        Reset counter: 19
                        Mileage: 172906 km
                        Time Indication: 0
                        Date: 2016.07.02
                        Time: 16:19:00
    So I've just done a Optical Bus Diagnostics with the engine on...
    Control Module Part Number: 4F0 910 468 A
    Component and/or Version: Gateway H11 0070
    Optical Bus Diagnostic : Standard
    Controller Electrical Optical
    19-CAN Gateway OK ERROR
    07-Control Head(High/D3) OK ERROR
    0E-Media Player 1 OK OK
    77-Telephone OK ERROR
    47-Sound System OK OK
    67-Voice Control ERROR ERROR
    56-Radio OK ERROR
    57-TV Tuner OK ERROR
    37-Navigation OK ERROR
    0F-Digital Radio(DAB) OK ERROR
    And one with the engine off...
    19-CAN Gateway OK OK
    07-Control Head(High/D3) OK OK
    77-Telephone OK OK
    67-Voice Control OK OK
    56-Radio OK OK
    57-TV Tuner OK OK
    37-Navigation OK OK
    0F-Digital Radio(DAB) OK OK
    I cleared all the fault codes and tried again, but it is still happening.
    I've had no new components fitted or replaced for a couple of years (last one being the AMI that I fitted instead of the CD stack in the glove box), and before I went on holiday everything was working just fine.
    Why would everything work fine with the engine off, but with the engine on, I get no MMI at all?
    Last edited by Sam; 04-07-2016 at 01:45 PM. Reason: Removing swearing and adding CODE tags to VCDS autoscan
  2. Re: What on Earth is going on with the MMI???
    Mar 2013
    Lincolnshire
    Could this be anything to do with battery voltage?
    A6 2008 57 Reg 2.7TDi SE Tiptronic Avant Quattro
  3. Re: What on Earth is going on with the MMI???
    Jun 2014
    Quote Originally Posted by markaz View Post
    I have no idea. The car started up first time with no hesitation, and I've driven it to the office along country roads for 30 minutes but the problem still persists.
    Perhaps it's the alternator? The system runs fine when on battery power, but not at all when the engine is on.
  4. Re: What on Earth is going on with the MMI???
    Mar 2013
    Lincolnshire
    Sorry that's what I meant. Have you checked battery voltage with the engine running?
  5. Re: What on Earth is going on with the MMI???
    May 2014
    Darlington
    78 Post(s)
    I believe the answer could be in the optical scan, it is unusual to get an electrical error, however there are very few A6's with full voice control, so you don't see many scan's with that module installed.
    56-Radio OK ERROR
    For me something has gone wrong with the voice control module (what I have no idea) Remove the power connector from the radio module and then remove the voice control module from the radio module, reconnect the power and see if the MMI works with the engine on. This could either be faulty radio module or voice control module, it could also be that the voice control module just needs to be re-seated in the radio module (bad connection)
    Hope you get it sorted.
  6. Re: What on Earth is going on with the MMI???
    Jun 2014
    Quote Originally Posted by B5NUT View Post
    56-Radio OK ERROR
    Funny you should say that about the radio. I did some more scans with the VCDS tool and here are the results...
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 T HW: 4F0 035 541 H
    Component: TUNER EU/US/RDW H42 0630
    Revision: 00000000 Serial number: 396C.067534496
    Coding: 0000001
    Shop #: WSC 00045 210 90248
    VCID: 316EB4B2A89532B6C1-8064
    2 Faults Found:
    00532 - Supply Voltage B+
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 7
    Fault Frequency: 18
    Reset counter: 28
    Mileage: 172932 km
    Time Indication: 0
    Date: 2016.07.02
    Time: 17:15:22
    00447 - Function Limitation due to Over-Voltage
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 229
    Reset counter: 28
    Mileage: 172954 km
    Time Indication: 0
    Date: 2016.07.04
    Time: 18:22:19
    But I'm also getting this...
    Coding: 0001002
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 173098 km
    Time Indication: 0
    Date: 2016.07.07
    Time: 16:54:11
    If the Radio doesn't work, would that knock out the optical system? Or are there 2 possible faults? One issue is with the radio and another with a break in the optical bus?
    EDIT: According to the Ross-Tech site http://wiki.ross-tech.com/wiki/index.php/00446 this over voltage could be down to the following...
    Possible Causes
    • Fuse(s) faulty
    • Supply Voltage low
    • Battery faulty
    • Generater faulty
    I had a new battery fitted not long ago, and I can't imagine it's a fuse as everything works while on battery power only. How do I check voltage or generator?
  7. Re: What on Earth is going on with the MMI???
    May 2014
    Darlington
    78 Post(s)
    i would be looking at the radio module being faulty, look at the "Fault Frequency" on some of the errors.
  8. Re: What on Earth is going on with the MMI???
    Jun 2014
    So if the radio module is faulty, would it cause the other components to fail? The radio (and everything else) works just fine when on battery power. If I turn the engine on, it may be 5 seconds to 5 minutes before the MMI turns off completely.
    Having had this problem for a week and a half or so, I've been monitoring when the MMI shuts down. It seems as if it's when I change gear or when I release the clutch without applying any gas if I'm in slow moving traffic - possibly indicating that there's not enough power coming out of the alternator??
  9. Re: What on Earth is going on with the MMI???
    May 2014
    Darlington
    78 Post(s)
    The system runs on a fiber optic loop system, so if one module fails it takes out the entire MMI system. The MMI system does not use much power, if you suspect the alternator then the most power hungry systems are heated seats & headlights, so switch them both on and see if the lights start flickering, if that is Ok, then you have another electrical fault.
    I used to bench test MMI systems, and ran it off a leisure battery which would last weeks without needing charging.
  10. Re: What on Earth is going on with the MMI???
    Dublin, Ireland
    I have something of a similar issue actually....
    On mine though (05 car with MMI 2G High) 2/3 times now the whole MMI system (lights/buttons) are dead on key turn (battery or engine running). The screen shows the splash screen/logo but that's it
    Give it a few hours though/overnight and it's fine again? Maybe a battery drain issue as it does seem to complain very quickly that the battery level is low when parked up?
  1. MMI+ Nav Google Earth error: "Not Enough Data in Memory"
    By belly buster in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 01-02-2014, 08:28 PM
  2. Replies: 25
    Last Post: 27-09-2012, 06:34 AM
  3. Google Earth Maps on MMI Nav Plus
    By ianfarnham in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 05-02-2012, 02:05 PM
  4. Please Help Where to earth my sub to?!
    By VictoryWorks in forum Golf MK4 - 1999 - 2004
    Last Post: 15-11-2008, 07:45 PM
  5. Possible Earth
    By Peanut in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-12-2007, 12:32 PM
