Thread: DPF Regenerations, Driving me mad!
Results 1 to 10 of 11
  1. DPF Regenerations, Driving me mad!
    Jul 2012
    Manchester, England
    Afternoon all,
    I collected my 2.0 TDI Ultra S Tronic Black Edition in March and have to say that so far, it's been fantastic. Love the car but one thing that's starting to drive me mad is the frequency and intrusiveness of the DPF filter regeneration cycles. I suspect there may be a fault with the car because it's running through regeneration cycles up to three times a week! Admittedly I don't do a lot of motorway driving, it's mainly town driving but I do occasionally drive on motorways.
    Here's why I think I have a fault. On Saturday and Sunday of last week I went up and down the M60 to Warrington (About 30 miles from my house) on both days. I would assume that at some point during these journeys it's been able to complete a regeneration cycle?
    On Monday morning I went out to the car and began my journey to work only to find that the car decided to try and do a regeneration within minutes of starting the journey! What drives me insane is that when it's in the process of doing a regen the car feels a little bit more harsh to drive. The gear changes are a bit more snatchier than usual, has anybody else experienced this?
    Thoughts please, ta
  2. Re: DPF Regenerations, Driving me mad!
    Dec 2009
    Amesbury, Wiltshire
    18 Post(s)
    It does seem as though the regens occur at pre-defined intervals rather than necessarily making the most of motorway journeys. I don't notice the car being more harsh during regen (but maybe I'm not so perceptive!) but it does idle quicker and disables start-stop and the fans continue for a prolonged period when parked. I'd be interested to know what the parameters are that define time for a regen...
  3. Re: DPF Regenerations, Driving me mad!
    Jul 2012
    Manchester, England
    Thanks for the reply bud. Yes I can definitely tell when it's part way through a regen cycle. As you say, the tell tale sign is the idle speed sits at around 1,000RPM. The change definitely isn't as smooth in my car, that's what frustrates me the most I think.
  4. Re: DPF Regenerations, Driving me mad!
    Mar 2008
    A colleague and myself were just talking today about how loud and often the regen runs. We both do lots of motorway miles, and even after 4 hours straight at motorway speeds, we've both stopped to find a regen underway and the fans running like crazy. Seems to be a VAG 2.0 litre thing as a colleagues VW GTD is similar.
  5. Re: DPF Regenerations, Driving me mad!
    Feb 2015
    stoke on trent
    I wrote a post about the very same thing when I did a little review after 1,000 miles.
    I am now at 6,000 miles and the regen is much less frequent but as you say not when you expect it, IE on a longer run, but usually quite soon after starting out and yes usually when it is a shorter run (as though it seems to know lol) if I can I usually try to take the car back out for another ten minutes to allow the regen to complete. I used this method for five years with my previous BMW and had no issues.
    I would make the point that just because the fan is running when you stop doesn't seem to always indicate a regen you can usually smell the exhaust when it is regenerating.
    To recap yes mine is exactly the same and I have been assured that this is all perfectly normal.
  6. Re: DPF Regenerations, Driving me mad!
    May 2008
    The new 'Ultra' engine based on the EA288 family seems to regen much more often than the old EA189 I had in the previous A6. It appears that the ea288 has a more complex set of rules for the regens and according to the service training documentation for the new engine, there is a 'mileage regen' that triggers every 465 miles if there hasn't been a successful regen. This happens regardless of the DPF filter load and is designed to keep the soot loading in the DPF low thus prolonging its life. This I believe is why you can get the regen happening even at the end of a long motorway run (which would typically burn the soot off as you drive) if the mileage timing is such. Hope this helps clarify what people are seeing happen.
    Current - FL A6 Avant 2.0 Ultra BE S-Tronic, Tornado Grey, 20" titanium alloys
    Previous - 2012 - A6 Saloon S-Line 2.0TDI, Daytona Grey, 19" 7 Twin spokes, DAB
    The good ladies - 2014 Golf GT 1.4 TSi ACT - Black
  7. Re: DPF Regenerations, Driving me mad!
    Feb 2004
    Yorkshire
    49 Post(s)
    I don't think that it is mileage or time based, the DPF will regenerate when the soot level reaches a set level, so if you do a motorway trip there is no guarantee that it will do a regeneration, may not have enough soot...
    My 2015 Skoda Superb seems to do it a lot more than the Seat Exeo I had before it, the Superb does it every couple of weeks, but it is only used at weekends, so around every 250-300 miles, I usually pull up at home, the rev;s are high so, as I live n the country and the main road in national speed limit just go about 4 miles at higher revs and all is back to normal...
    It was in for a service a couple of weeks ago so I asked a mate who works there to check the DPF soot content which at the time he said was 15% and look to be regenerating normal...
    I suspect that the setting now are more stricter or better calibrated than a few years back so they seem to do it more...
    Stuart l VWAudi Forum
    VW Audi Forum - Founder
    Ways to support the website
  8. Re: DPF Regenerations, Driving me mad!
    May 2008
    Quote Originally Posted by stuart View Post
    Sorry if I was unclear, there are of course 'normal' DPF regens - according to the documentation there are 4 possible regen modes,
    Passive - where regen happens as you drive - eg long motorway drives, no increased exhaust temperature is required as the soot burns as you drive
    Active - where the ECU causes the regen to happen, this is triggered by DPF soot load, ECU adjusts fueling etc to force temp up in exhaust and regen to happen
    Regen trip by customer - where the DPF light comes on the owner needs to take the car for a regen drive, driven by soot load and inability to reduce (regen is not completing), again ECU controls the fueling to increase exhaust temp and force the soot to burn off
    Dealer regen - DPF light and workshop message - needs a forced regen at the dealer. Drinking in last chance saloon.....
    On top of these options, there is now a mileage based regen that happens at 465 miles if no regen has happened i.e. long motorway journey where the passive regen has been happening as you've driven.
    I believe they have done a lot of work to improve the longevity of the DPF filters obviously keeping the soot load as low as possible is key to improving their life.
    Hope this clarifies - if you google 'EA288 engine' you can find the service training document that contains the full detail (I have the link but i'm not sure if i'm allowed to post it due to copyright)
  9. Re: DPF Regenerations, Driving me mad!
    Jun 2015
    Europe
    Just do what i do and boot the living daylights out the engine on a regular basis. Thats should stop any issues.
  10. Re: DPF Regenerations, Driving me mad!
    Aug 2015
    Woking
    I have never noticed a regen happening (3.0 TDI) does a light come on to tell you its doing it ?
  1. Please Help This is driving me mad
    By Callybantan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-02-2012, 11:00 PM
  2. vw t4 driving me mad!!!
    By NELLIEBUS in forum The Commercial Range
    Last Post: 28-10-2010, 08:44 AM
  3. Please Help Knocking driving me mad!!!!!
    By Manni78 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-04-2010, 10:01 PM
  4. what oil?, its driving me mad
    By zlr177 in forum Golf MK4 - 1999 - 2004
    Last Post: 18-07-2009, 10:32 PM
  5. Bora is driving me mad!
    By Paul Jay in forum Bora - 1998 - 2005
    Last Post: 08-02-2008, 07:51 PM
