Thread: Hot rear brake disc - A4 - B7
Results 1 to 8 of 8
  1. Hot rear brake disc - A4 - B7
    Jan 2014
    Sweden
    2.0T A4 B7 Quattro
    Hi everyone, hopefully someone can shed some light on my brake issue.
    My rear left brake has been getting hotter than the other 3.
    I have replaced the slide pins, the discs, pads and have put on a new caliper.
    Brakes have been bled.
    But it still appears to be much hotter than the other 3 after a drive.
    What more can it be?
  2. Re: Hot rear brake disc - A4 - B7
    May 2012
    Everywhere
    308 Post(s)
    Caliper piston , clean , or renew , grease and new seal kit .
  3. Re: Hot rear brake disc - A4 - B7
    Pembrokeshire
    22 Post(s)
    hes had a new caliper
  4. Re: Hot rear brake disc - A4 - B7
    Jul 2015
    Staffs
    46 Post(s)
    Faulty flexi?
    Ian
    A4 B6 Avant Nogaro Blue
  5. Re: Hot rear brake disc - A4 - B7
    Jan 2014
    Sweden
    Yip new caliper fitted yesterday.
    I first noticed 2 weeks ago when i heard scraping from the brake. on inspection the rear pad was worn to the backing plate. Though not evenly, was worn on an angle.
    I fitted some new pads and suspected the slide pins had seized, so replaced them too. think that was the problem solved.
    A couple of days later i noticed that the brake was hot again. So I ordered news discs think the old one could be warped. And i ordered a new caliper, since I new that side was original (all others had been changed).
    Funny when i took the 2 week old pads of yesterday they were again worn uneven at an angle.
    How would the flex pipe cause this?
  6. Re: Hot rear brake disc - A4 - B7
    Pembrokeshire
    22 Post(s)
    flex pipe can delaminate internally and act as a one way valve. to test, jack up and remove wheel. press brake pedal really hard. wheel should spin easily as soon as pedal is released. get a helper to do the pedal. if the wheel doesnt release, crack open the bleed nipple. if you get a sudden release of the brake then its probs the flexi keeping pressure in the caliper. you can confirm by again pressing the pedal and this time cracking off the joint the other side of the flexi from the caliper. if nothing happens and wheel stays tight then you have it cracked.
    0 2 0
  7. Re: Hot rear brake disc - A4 - B7
    Jan 2014
    Sweden
    Great!
    I guess i can try a similar test with the handbrake.
  8. Re: Hot rear brake disc - A4 - B7
    Pembrokeshire
    22 Post(s)
    you could, that would rule out a sticky handbrake cable which is another option.
  1. A4 Rear Brake Disc size?
    By loucla93 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-03-2016, 08:24 PM
  2. rear brake disc fitting help
    By malk in forum Leon
    Last Post: 10-07-2011, 04:36 PM
  3. Sticking rear brake caliper? Hot Rear Wheel
    By timdave25 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 01-03-2011, 01:58 PM
  4. Binding Disc Brake...Hot front wheel
    By onzarob in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-02-2008, 10:44 AM
  5. Rear disc brake noise
    By panos.v in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-01-2008, 11:39 AM
