Thread: What can cbdc engine 110 hp vw passat CR 2.0 tdi Turbo can max handle?
Results 1 to 10 of 12
  1. Cool What can cbdc engine 110 hp vw passat CR 2.0 tdi Turbo can max handle?
    Jun 2016
    bimingham
    First of all I am not a big fan of cars. I am noob and still trying to understand. All I want is the best output for my car to handle.
    So I have a vw passat saloon 2009/10 2.0 tdi 110hp with engine code cbdc.
    I recently stage 1 remap it and had my dpf removed because of the regeneration annoying processed. After the remap I obviously felt a lot of difference and I was so happy that I didnt bother to asked how much power I have gained. On top of that the mpg has drastically improved along with it crazy power!
    So now I am looking forward to try and hit stage 2! and I need your ideas on what are the up's and down or even possible to hit 300 hp! what are the thing I need to changed and add?
    Also do you guys know how much can my TURBO handle? I mean the max it can take? Because some of my friend saying that it might reach 200hp by itself. I looking forward to either upgrade it to hybrid turbo or buy a bigger turbo.
    Looking forward for your help!
  2. Re: What can cbdc engine 110 hp vw passat CR 2.0 tdi Turbo can max handle?
    May 2012
    Everywhere
    308 Post(s)
    160 bhp is safe max .
  3. Re: What can cbdc engine 110 hp vw passat CR 2.0 tdi Turbo can max handle?
    Apr 2016
    Ashburton
    Did you know vehicles will automatically fail the MOT test if the filter had been fitted as standard but is found to be no longer present.
    The Maximum amount of power your engine can handle without modification is below:
    VW Remap
    Standard Power (BHP): 110 bhpRemapped Power (BHP): 148 bhp
    Standard Torque (nm): 235 nm
    Remapped Torque (nm): 305 nm
  4. Re: What can cbdc engine 110 hp vw passat CR 2.0 tdi Turbo can max handle?
    Jun 2016
    bimingham
    So I need to definitely change my turbo for stage 2 map to atleast reach 200+ hp?
  5. Re: What can cbdc engine 110 hp vw passat CR 2.0 tdi Turbo can max handle?
    Jun 2016
    bimingham
    Quote Originally Posted by turboextreme View Post
    VW Remap
    Hmmm im guessing thats the max input for stage 1 map process?
    can you give me an advice for stage 2 process? what I need and changing?
  6. Re: What can cbdc engine 110 hp vw passat CR 2.0 tdi Turbo can max handle?
    May 2012
    Everywhere
    308 Post(s)
    Gut and weld back up away from tester eyes , PASS .
    DPF delete pipe , FAIL .
  7. Re: What can cbdc engine 110 hp vw passat CR 2.0 tdi Turbo can max handle?
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    Quote Originally Posted by tjdayao View Post
    Like a computer system your engine will only give the maximum available for the weakest component. You will be restricted by the standard components in the car and this means your total bhp increase will be limited too. You can change the exhaust, turbo and air intake set up to get your first increases with a remap. You will only be able to achieve higher gains by replacing other components such as injectors, fuel delivery systems, intercoolers, con rods, pistons, cams etc., etc. as the stock items will have a breaking point or will not deliver gains past a certain point.
    If you are serious about maxing out a 110hp cbdc engine then you will need some proper help and a big wallet!
    Mad Mitch
  8. Re: What can cbdc engine 110 hp vw passat CR 2.0 tdi Turbo can max handle?
    Norfolk
    The turbocharger has less to do with improved performance than you might think. Bolting on a bigger turbo charger will in most cases make power worse, not better. There is no such thing as stage 1, stage 2 tune etc.
    It is best to go to a professional tuner with a rolling road and let them custom map the car for its best performance based on the stock parts.
  9. Re: What can cbdc engine 110 hp vw passat CR 2.0 tdi Turbo can max handle?
    Sep 2008
    SE London
    Quote Originally Posted by martin1810 View Post
    A K04 instead of a K03 will offer enhanced performance. Of course it'd have to be installed with the other items too -- down pipe, inlet, DV, re-map, etc. The "Stages" are generally held terms following APR's system kits. So a Stage1 is usually the ECU-only flash not requiring any change of components (apart from on the tFSI 2.0L that would benefit from a faster-acting Diverter Valve such as AW Tuning's instead of the OEM Peirburg who's diaphram rips)
    Which will always result in something better than an off the shelf tune . Superchips' home installers download your existing, send the data to their workshop reader/writer who modifies that map and sends it back to the home installer for uploading to your ECU. A copy of your existing OEM map is kept. You can have that stored at their works or on a handheld unit that you can re-flash with.
    Beware: there's a stock tune available in the US that gets lost (ECU reverts to default) when battery's disconnected. Of course this could be an olde internet forums' wifes tale -- but it has been repeated. The firm mentioned is over here too and does offer a handheld that stores your new Stage1 tune as well.
  10. Re: What can cbdc engine 110 hp vw passat CR 2.0 tdi Turbo can max handle?
    Norfolk
    Adding a bigger turbocharger does not enhance performance. The only way to enhance performance is to increase fuel. Then more air may be required.
    ECU tuning should be done in stages so how can an ecu flash be one stage. That doesn't make sense. A good tuner would not use words like stage 1, stage 2 etc as they are meaningless.
    Most engine tunes work by defeating emissions controls which means that if the annual test was to the original manufacturer standard most tuned engines would fail the test.
    An ecu cannot lose a tune because the battery was disconnected. That is impossible.
  1. How To passat cr camshaft locking tool cbdc needed
    By lee1970 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-07-2013, 08:20 PM
  2. Please Help B5 99 AFN 110 Passat TDI. Turbo appears to have blown, car wont start.
    By B5_Passat. in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-05-2013, 12:22 PM
  3. 97' passat cl tdi (110) which turbo
    By bagseye in forum Early Passat Forum - Pre 97
    Last Post: 20-01-2009, 10:30 AM
  4. Engine Swop 98 passat TDI 90-110
    By mr_c in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-01-2008, 11:24 AM
  5. Passat TDi 110 engine bay picture required please?
    By BenthamBloke in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-11-2007, 12:55 AM
