Thread: Headlights left on warning buzzer not working
  1. Headlights left on warning buzzer not working
    Jun 2016
    Not sure if I have the solution, so thought I would check with you guys/girls.
    Upon exiting my car with headlights on dipped, keys removed, I don't get any audible warning to let me know that I've left my lights on, (dipped only, as works with sidelights and also if i leave the rear fog lights on).
    I have noticed that when either the sidelights or rear fogs are left on and the keys removed the instrument panel is illuminated and audible warning can be heard, but with dipped lights on the instrument panel doesn't illuminate and the audible warning doesn't activate, is this down to the bulb not working, thus in turn breaking the circuit.
    I was wondering, is it just a case of replacing the faulty bulb in the instrument cluster, if so how do I do this, is there a guide anywhere?
    2010 Polo 1.4 SEL
    2010 Touran 2.0 Match (chopped in against the passat)
    2011 Passat 2.0 Bluemotion S
  2. Re: Headlights left on warning buzzer not working
    Jan 2016
    Winchester Hants
    29 Post(s)
    Bit late but mine is the same. I have the remote key and Auto light switch version vehicle. If I select sidelights it bings when the door is opened and when the main beam is selected on, nothing when door is opened. I cannot leave the main beam on anyway with ignition off.
    2013 B7 Passat BlueMotion Sport Estate 2.0 TDi 177PS (CFGC), 6 speed Manual, Metallic Night Blue, Fontana alloys, Start/Stop, RNS-510 (HW H09, SW 5238 V13 maps, 8316) Nav DAB, ACC, XDS, TPM, Westfalia Tow bar, Rear View camera, Keyless Entry, Easy Open/close Electric Tailgate, Park Assist, Electric Parking Brake, DRL's, Amb light, Zebrano wood, Tinted Glass, mud flaps, 61K. Cheat emission software. Nextbase 402G iN-CAR CAM.
  3. Re: Headlights left on warning buzzer not working
    131 Post(s)
    1973 Post(s)
    Does the door open warning show the door is open and does the courtesy light come on?
  4. Re: Headlights left on warning buzzer not working
    Jan 2016
    Winchester Hants
    29 Post(s)
    Yes, but not when the headlight is on. Maybe the buzzer indicates the door is open and not side lights on. I will go and check the courtesy light. Yes they come on when sidelight and headlight left on.
    OK decided to look in manual.
    With the ignition off or key removed and door opened.
    Accoustic warning when,
    Parking light is switched on.
    Light switch in position sidelight or headlight
    If the light switch is in position dipped headlight (vehicles without orientation lighting)
    Reason:
    Sidelight switch on, lock car = sidelights on.
    Dipped headlight switch on, lock car = no lights on.
  1. Question warning light buzzer for headlights.
    By simon74 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-10-2017, 11:27 AM
  2. Warning Buzzer not working.
    By vince70 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-02-2012, 10:44 PM
  3. fuel/headlights left on warning buzzer
    By betchrider in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-10-2010, 04:01 PM
  4. Please Help Headlights Warning Buzzer inop
    By mreid1977 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 01-09-2009, 08:17 AM
  5. Lights left on warning buzzer not working - fuse??
    By sharastani in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-12-2006, 12:28 PM
