Thread: Replacing AGM Battery
  1. Replacing AGM Battery
    Jun 2016
    Rutland, UK
    I have a 2013 Passat B7, bluemotion diesel model, I'm concerned about replacing the battery.
    From reading different forums some mentioning fitting matching BEM batteries and having them re-coded afterwards and others saying that as long as the battery is matched in capacity it will be fine.
    Can anyone advise on this please?
    Car currently has a Varta 7PO 915 105 battery, BEM: VAO230110A0KQ.
    I've found replacement from Tayna, https://www.tayna.co.uk/E39-Varta-Start-Stop-Plus-AGM-Car-Battery-570901076-P4367.html, which I believe should do the job (right capacity), but not sure if I can just swap it out?
  2. Re: Replacing AGM Battery
    Flitwick
    I swapped mine over and never done any re-coding and it worked just fine. Go with the same battery and all should be good.
    Steve.
    Steve
    2014 Passat Estate
    Executive Style
    2.0 TDI Bluemotion
    Tungsten Silver
  3. Re: Replacing AGM Battery
    Jun 2016
    Rutland, UK
    Thanks Steve, think I will go for the Varta and see how I get on. I never needed to worry about coding when I replaced the battery on the Octavia, and that was fine.
    Thanks again.
  1. Replacing Battery
    By 2fquick in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-12-2014, 09:43 AM
  2. Audi A8 D3 2008 4.2 TDi AGM Battery Upgrade
    By Howdy Doody in forum A8 - S8 - V8
    Last Post: 11-12-2014, 02:05 AM
  3. Audi A8 D3 4.2 TDi AGM Battery Upgrade
    By Howdy Doody in forum VCDS - Help Requests
    Last Post: 09-12-2014, 12:23 PM
  4. Replacing BATTERY. In Q7
    By Q7quattro in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 28-02-2014, 09:03 PM
  5. Replacing Battery
    By Scampy in forum Golf MK5 - 2004 - 2009
    Last Post: 07-12-2009, 05:35 PM
