Thread: OBD codes - what is bank 1?
  1. OBD codes - what is bank 1?
    May 2016
    Cumbria
    Last month I had the following codes:
    P0141 - o2 sensor heater circuit (Bank 1 Sensor 2)
    P0139 - o2 sensor circuit slow response (Bank 1 Sensor 2)
    P0140 - 02 sensor circuit no activity detected (Bank 1 Sensor 2)
    P2188 - system too rich at idle bank 1
    After replacing the O2 sensor and some fuses and cleared the codes the light stayed off.
    But now I have 4 codes again:
    P0341 - camshaft position sensor A circuit range / performance (Bank 1 or single sensor)
    Notice that P2188 has gone but now I have P0341.
    The common factor seems to be bank 1.
    What is bank 1? And could this be a clue or just coincidence?
    Any responses would be appreciated.
  2. Re: OBD codes - what is bank 1?
    Jul 2015
    glasgow
    What car do u have if I remember right the mk5 golf had a controller unit that caused issue and was a PITA
    Sent from my SM-G900F using Tapatalk
  3. Re: OBD codes - what is bank 1?
    Jul 2016
    Essex
    You only have one back on an inline 4 cylinder engine. One a v type engine such as a V6 or V8 you have two banks.
  4. Re: OBD codes - what is bank 1?
    Jul 2016
    Essex
    It seems you pretty much have the same issue and the work that has been done on the car hasn't cured the original fault, which O2 sensor did you have replaced? And was it tested prior to it being replaced?
  1. VAG Workshop Codes [WSC] - anyone recognise these UK codes please? ...
    By JulianHicks in forum VCDS - General Questions
    Last Post: 09-07-2015, 09:53 PM
  2. OBD codes my A6 2005
    By Kenpassey in forum VCDS - General Questions
    Last Post: 31-12-2014, 03:06 PM
  3. Question I need to replace my cats on my 2.4, how do I tell if I need OBD or non-OBD?
    By Carpie in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-01-2011, 09:39 PM
  4. OBD II Codes P18625 and 0550 17-10
    By freddyuk in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-09-2010, 04:34 PM
  5. OBD Codes
    By ilfdlab in forum Golf MK4 - 1999 - 2004
    Last Post: 22-07-2008, 11:29 AM
