Thread: Coolant leak through EGR valve V6 3.0 quattro TDI
Results 1 to 9 of 9
  1. Coolant leak through EGR valve V6 3.0 quattro TDI
    Jun 2009
    Cornwall TR12
    I Initially posted this in a related thread on the A4 forum (same engine type).
    I'm about to receive a hefty bill due to a coolant leak through the
    EGR valve on my 2010 A6 V6 3.0 TDI (130,000 mostly motorway miles).
    it manifested itself initially via a low coolant level warning whilst driving on the motorway and some black exhaust smoke evident when manouvring around the motorway services seeking water. Remaining 65 miles completed, coolant level warning re-appeared just before arrival. Topped up again and next day drove 15 miles to Audi dealership. Plently of action en-route (DPF warning, but only for a couple of minutes, continuous flashing glow plugs warning and reversion to limp mode. Coolant level warning after a while too (engine temp normal at 90 deg at all times).
    Pressure testing located the leak in the EGR valve and several EGR parts need replacement. What confuses me is the apparent possibility that the DPF may also need replacement. The DPF was clearly unhappy at some stage, but can anyone here suggest why coolant ingress (which did initially have the correct anti-freeze concentration) could damage a DPF?
  2. Re: Coolant leak through EGR valve V6 3.0 quattro TDI
    Jul 2013
    76 Post(s)
    If the EGR cooler has failed then coolant will be getting into the exhaust system (DPF,Cat etc).
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: Coolant leak through EGR valve V6 3.0 quattro TDI
    Dec 2015
    Southend, UK
    Quote Originally Posted by dan2485 View Post
    Is the EGR cooler still required if the EGR valve has already been blanked and mapped out ? is this something else that could be safely blanked off or will the EGR still get hot and require cooling if it is inoperative ?
  4. Re: Coolant leak through EGR valve V6 3.0 quattro TDI
    Jan 2011
    Stafford, UK
    Quote Originally Posted by Not_Anumber View Post
    I was talking to my son (he is in the car trade) the other day about getting rid of my DPF, he told me not to do it.
    Although the MOT requires a visual inspection for the DPF and EGR at the moment, there are plans in the pipeline to include them both in the MOT to be checked that they are functional.
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
    0 2 0
  5. Re: Coolant leak through EGR valve V6 3.0 quattro TDI
    Jun 2009
    Cornwall TR12
    The DPF did indeed need replacement, because (as dan2485 mentioned) obviously the coolant had run down into the exhaust system from the EGR, what I still can't get my head around is that water and alcohol can be more effective at blocking a DPF than soot! Nevertheless, they ran the static regen after fixing the EGR and it would not regenerate - apparently. What I did find irritating is that there was no regen report to verify the need to replace, do the machines not provide a printout?
  6. Re: Coolant leak through EGR valve V6 3.0 quattro TDI
    Feb 2016
    London
    13 Post(s)
    If the DPF is old it will have a high ash content and if you add water to this it can solidify into a sludge and dry out like cement thus block the dpf.
    2011 A6 Allroad 3.0TDI
  7. Re: Coolant leak through EGR valve V6 3.0 quattro TDI
    Jan 2011
    Stafford, UK
    Quote Originally Posted by C6Allroad View Post
    I thought that a lot of water was generated as the fuel was burned, so water would be going through the exhaust all the time that the engine is running.
    How is it that this doesn't clog the DPF ?
  8. Re: Coolant leak through EGR valve V6 3.0 quattro TDI
    Jul 2015
    Staffs
    46 Post(s)
    Quote Originally Posted by royclark View Post
    Smaller quantity, doesn't contain coolant, and is more than likely atomized.
    Ian
    A4 B6 Avant Nogaro Blue
  9. Re: Coolant leak through EGR valve V6 3.0 quattro TDI
    Feb 2016
    London
    13 Post(s)
    The difference between water vapour produced by combustion and liquid draining into the DPF from a leak?
  1. Question 1999 A4 2.8 quattro 2.8 - coolant leak under inlet manifold
    By timmyp666 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-02-2015, 05:49 PM
  2. Please Help Egr valve 038131501t on mk4 gt tdi 1.9 130pd ..broken part of valve body
    By Dobbo37 in forum Golf MK4 - 1999 - 2004
    Last Post: 30-09-2013, 07:13 PM
  3. EGR valve leak?
    By Mike McKinstry in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-09-2011, 08:15 PM
  4. Losing Coolant Golf 2.0 GT TDI 140 (EGR Valve)
    By felinus in forum Golf MK5 - 2004 - 2009
    Last Post: 27-01-2009, 11:39 PM
  5. Question Coolant leak 1998 A4 2.8 Quattro
    By joca in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-12-2008, 08:38 PM
