Thread: B6 2.0TDI common problems
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. B6 2.0TDI common problems
    Feb 2015
    United Kingdom, Oxford
    HI all,
    I’ve just bought my second Passat, my wife will have my B5 1.9TDI and I’ve now got a B6 2008 2.0TDI 140BHP Highline estate, 112K on the clock.
    I spent quite a bit of time at the dealers checking everything worked and couldn't find any problems, car looks straight, is in in very good condition. Dealer is putting it in for a new cam belt before I collect it.
    My question; is there anything I should check when I get it home e.g. I know my B5 was liable to blocked drains under battery causing water to get into the passengers footwell
    Also I would like to service it so what oil should I use, again experience from my B5 suggests getting the right oil is VERY important..
    And lastly, now I have two VWs in the family I am considering getting some diagnostic software – what is recommended ?
    Thanks in advance for the advice
    Paul
  2. Re: B6 2.0TDI common problems
    Pembrokeshire
    22 Post(s)
    have you parted with any money yet ?
  3. Re: B6 2.0TDI common problems
    Feb 2015
    That sounds ominous! Paid 15% deposit, why?
  4. Re: B6 2.0TDI common problems
    Pembrokeshire
    22 Post(s)
    because there are a lot of common problems. oil pump drives, electric handbrake, same plenum problem but with far more expensive consequences, the list is long. crasher, our resient guru and owner of c&r enterprises , doesnt have many good words about them. really best avoided. look in the relevant section for some of the faults. just hope yours is a manual not a dsg.
  5. Re: B6 2.0TDI common problems
    Feb 2015
    Ok. Yes its a manual. Its also the later comon rail engine (CBAB?) Which I thought was better.
  6. Re: B6 2.0TDI common problems
    May 2012
    Everywhere
    308 Post(s)
    May have the inferoir 77mm hex key oil pump drive .
    My father has one , and the wallet has been well and truly raped.
    It will never be as reliable as a 1.9 tdi B5 , B5.5 .
  7. Re: B6 2.0TDI common problems
    Pembrokeshire
    22 Post(s)
    Quote Originally Posted by s1paulj View Post
    yes, the common rail is better than the older injectors
  8. Re: B6 2.0TDI common problems
    May 2012
    Everywhere
    308 Post(s)
    Common rail isn't immune from the odd 77mm Terminator .
  9. Re: B6 2.0TDI common problems
    Pembrokeshire
    22 Post(s)
    oh sorry, i was only talking about the injectors, the rest of the engine is as bad as the others
  10. Re: B6 2.0TDI common problems
    Up North
    Never seen a problem on this part of the forum with the common rail engine. To the best of my knowledge it's completely different to the PD engine that caused so many problems.
    But I'd certainly take a good look at the electronic handbrake. Also, at that mileage look for gummed up turbo problems, that's an issue common to all VAG diesels eventually and it's easy to check for. As for diagnostic software, go look at the VCDS portion of the forum.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  1. common fault for 2.0tdi engine
    By Fanatic in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-03-2015, 04:50 PM
  2. 2.0TDI common rail are they affected by oil pump balancer shaft failures?
    By crazy4alfa in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-07-2014, 06:41 PM
  3. Any common problems?
    By davidrc in forum Exeo
    Last Post: 05-11-2013, 06:00 PM
  4. 3.0TDI Bosch 0455 010 090 common rail pump
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-09-2010, 05:13 PM
  5. 2.0TDi Sline 2007 Sportback Common problems to look for ?
    By Sunny in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 30-06-2010, 09:23 AM
