Thread: Q7 4M All wheel steering help please
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. Q7 4M All wheel steering help please
    Mar 2016
    Ipswich
    72 Post(s)
    Hi all
    ive got a q7 2016 all wheel steering and can some one who has this on there q7 would you kindly answer some questions please
    if the car is sat still running and you turn the steering on full lock as you stand outside the car watching the rear wheels can you see them move and turn?
    or do they only turn when car is moving?
    even when I turn into my drive full lock and get out to look at the rear wheels they still look straight
    I know in high speed there controlled by computer but surly they should turn when I'm turning in the drive?
    May be not when stopped but if I stop half way through a turn and get out the rear wheels should be turned a little?
    really hope some one can help on this as worried it's not fitted to the car
    thanks all
  2. Re: Q7 4M All wheel steering help please
    Apr 2016
    berkshire
    39 Post(s)
    I think they only move +/- 5 degrees very minute.. Will check have read or saved it somewhere
    Sent from my LG-H961N using Tapatalk
  3. Re: Q7 4M All wheel steering help please
    Apr 2016
    berkshire
    39 Post(s)
    Do you not think it helps in car parks etc otherwise
  4. Re: Q7 4M All wheel steering help please
    Apr 2016
    Stansted
    169 Post(s)
    Some diagrams here might help you by looking under the car 2016 Audi Q7 - Five Link Rear Suspension With AllWheel Steeing | Wallpaper #89 iPad | 1024x768
    Former Q7 owner
  5. Re: Q7 4M All wheel steering help please
    Apr 2016
    berkshire
    39 Post(s)
    Not sure if this helps towards the middle of the article..
    2017 Audi Q7 First-Drive - SlashGear
  6. Re: Q7 4M All wheel steering help please
    Apr 2016
    berkshire
    39 Post(s)
    When I get mine, I will be looking to find someone local to me or compare to a one @ my local Audi to see if there is actually any difference on the SLOW tight turns :-) (y)
  7. Re: Q7 4M All wheel steering help please
    chrisjerman Guest
    Just reading that , the Q7 starts at $54800 that's under 38 grand !
  8. Re: Q7 4M All wheel steering help please
    Apr 2016
    Stansted
    169 Post(s)
    I think that's before sales tax which is around 10% but is still cheap! I guess they benefit from such a big market. I get more frustrated about the lake of consistency in options between markets.
    Former Q7 owner
  9. Re: Q7 4M All wheel steering help please
    Feb 2016
    Essex
    They do only turn 5 degrees from center which is not a lot but that should still be noticeable at full lock.
  10. Re: Q7 4M All wheel steering help please
    Mar 2016
    Ipswich
    72 Post(s)
    Thanks guys on your help
    ive watched a few you tube clips etc but nothing shows the rear wheels steering at a standstill or moving slow so still stuck on this
    i did see a interesting you tube clip of a guy had his car on axle stands showing the movement of the rear wheels but not at slow speeds or standing
    so what I can work out so far it's prob above 10mph or so
    so will either have to get under the car or pop to the dealer and put on a ramp or ask for more info
    was hopping another Q7 owner had AWS also to get more thoughts on this
    i was hopping it would help me park in my drive but deffently no help with that
    M
  1. Did steering wheel sensor adjustment - now steering wheel a lot better???
    By Google44 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-06-2015, 08:07 PM
  2. Replies: 1
    Last Post: 28-02-2015, 12:31 PM
  3. Please Help ***BREAKDOWN*** Red Steering Wheel Light & 3 Beeps. No Steering/Steering Locked
    By Stuart_B in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 03-10-2013, 11:00 PM
  4. Mk5 Standard Multifuncion steering wheel to R32 wheel
    By Caudy in forum Golf MK5 - 2004 - 2009
    Last Post: 18-04-2008, 12:44 AM
  5. Can the steering column cowling be removed without removing the steering wheel?
    By rich_jc in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-04-2008, 06:48 PM
