Thread: 2009 Audi B8 A4 2.0 t Injector/coil wire harness problem (broken peice) how do i change it?
  1. Lightbulb 2009 Audi B8 A4 2.0 t Injector/coil wire harness problem (broken peice) how do i change it?
    May 2016
    Portland Oregon
    Okay so i've been searching everywhere and I can't find anything related to the topic.
    I have a 2009 Audi a4 2.0 T and it started idling a little rough and the check engine light came on. After Inspecting the wires I notices that one of the ports that connects to the injector is broke off. (picture attached)
    so i bought this new injector harness off ebay 2009 Audi A4 2 0T Fuel Injector Wire Wiring Harness 06H971627 | eBay and here is the picture of the one i got in the mail
    so here is a picture of my car wire and it dosnt match up. Can someone explain to me whats going on?
    It seems that this is all tied into the main wireharness i dont understand this at all but i have a broken tab on the left front. The part that I ordered the tabs for the injectors fit but the harness is shaped different.
    Any help would be appreciated and I hope you understand my question. Thanks
  2. Re: 2009 Audi B8 A4 2.0 t Injector/coil wire harness problem (broken peice) how do i change it?
    May 2016
    Portland Oregon
    Hey can someone help me out please?
  3. Re: 2009 Audi B8 A4 2.0 t Injector/coil wire harness problem (broken peice) how do i change it?
    May 2014
    Darlington
    78 Post(s)
    Just remove the damaged connector and replace it with one of the spares on the other harness you purchased. You will need a (google search) "vw terminal release tool"
    It looks something like this
    But a couple of pins either side to push in the prongs on the pins as shown in this image
    Try ebay for the tool or use a couple of pins. Or another option is to cut off the damaged plug (without damaging the pins) and buy a new plug as the connectors just push in.
  1. Injector harness
    By kevin tdi in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-08-2013, 01:40 PM
  2. Please Help Aftermarket stereo harness - Illumination Wire
    By patomlin76 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 01-08-2011, 10:13 PM
  3. injector harness
    By dadmgm in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-02-2010, 12:14 AM
  4. injector harness
    By leso in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-02-2008, 12:09 AM
  5. sensor wire enters the harness by the positive battery lead.
    By parts in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-08-2007, 05:56 PM
