Thread: A4 2L 20v ALT tuning options
  1. A4 2L 20v ALT tuning options
    Jan 2016
    Bristol
    Hi, so have some questions that I can't find the awnser on good old Google..
    So I have two options on my build. Swop the 2L for a 1.8t or tune the 2l and wack a turbo on it...
    But! What are the differences between an ALT engine and a APX engine other than the capacity. Do they share the same block number of 06A?
    Also would a 06A block mount longitudinal?
    What benefits would I have from a 2l opposed to a 1.8?
  2. Re: A4 2L 20v ALT tuning options
    131 Post(s)
    1973 Post(s)
    The ALT is an EA113 which is a derivative of the EA827 and the block is an 06B but I would not convert to a 1.8T for the simple reason you can buy one off the shelf for a fraction of what it would cost to build one. A 2litre turbo would have the advantage of better low end torque.
  3. Re: A4 2L 20v ALT tuning options
    Jan 2016
    Bristol
    Ok cool. Does anyone know what power the 2l crank will hold?
    Also are the pistols made of the same material as the 1.8t?
    So to turbo the 2l what will I need to replace. Just rods? Looking to make 350bhp?
    Of other stuff I will need externally?
  4. Re: A4 2L 20v ALT tuning options
    131 Post(s)
    1973 Post(s)
    I use those cranks (06A 105 021 AR/BP) in 2 litre 1.8T conversions and I one did last year is supposed to be giving 450 PS ish but at very high levels of boost your problems would come from main cap movement and so a thick billet steel ladder frame would be desirable to replace the flimsy tin plate one and heavy duty 12.9 cap bolts would be a must, APR studs even better. Use some steel H beam rods which plenty of companies sell but pistons are going to need to be forged custom low compression such as Arias, Wössener, Wiseco etc. Integrated Engineering in the US would be able to help you with rods and boost ready pistons.
  5. A4 2L 20v ALT tuning options
    Jan 2016
    Bristol
    Cool to turboing the 2l is possible if the crank is good for that.
    So for the build I need some rods and lower cop Pistons then bolt on the turbo?
    What kind of compression is what I should run as its 10.3:1 on the 3l stock
  1. Tuning my 20v turbo
    By Iain20vT in forum 1.8T - Engine
    Last Post: 19-09-2015, 10:56 PM
  2. 1.8T tuning options
    By A4B6Cab in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-05-2009, 03:40 PM
  3. 2.0 tdi tuning options
    By hightower in forum Audi A3 - Archive Topics
    Last Post: 14-03-2009, 02:06 PM
  4. t5 tuning options??
    By stockcar in forum The Commercial Range
    Last Post: 28-10-2007, 08:43 PM
  5. Passat 1.8T 20V tuning?
    By RobBentley in forum Passat - Archive Topics
    Last Post: 03-09-2007, 05:41 PM
