Thread: Help - Wing Mirror not folding out.
Results 1 to 10 of 17
  1. Help - Wing Mirror not folding out.
    Oct 2012
    London
    Have a problem with the electric folding mirrors on my car.
    Parked the car and all was fine, but have come back and now only the passenger mirror is folding out when starting the car.
    Is there any manual release to fold out the mirror?
    I've tried to push it gently but it feels firm, so I don't want to force it.
    Could it be a blown fuse or Do they work off the same fuse?
    I'm a bit stuck as its not really safe to drive with no drivers side wing mirror!
  2. Re: Help - Wing Mirror not folding out.
    46 Post(s)
    No fuse as they're wired into the door controller, they do tend to stick quite a bit.
    You can push it out, not the first time I've had to do mine on the A3.
  3. Re: Help - Wing Mirror not folding out.
    Oct 2012
    London
    Thanks Chris.
    So is there a special trick? like pushing when they are supposed to be folding out?
    Or just a case of forcing the mirror?
    Can I do any damage if the mirror is forced?
  4. Re: Help - Wing Mirror not folding out.
    Dec 2009
    Amesbury, Wiltshire
    18 Post(s)
    Mine sticks sometimes, but folds out properly if I use the button to fold in and back out again. But it has only every stuck half way and not refused to move at all.
  5. Re: Help - Wing Mirror not folding out.
    Oct 2012
    London
    Thanks robes401, first time it's ever happened.
    I've tried retracting the mirrors using the switch to fold/unfold them numerous times. But no luck.
    Also tried shutting off car completely and turning on again.
    Looks like I've no option but to force the mirror open.
  6. Re: Help - Wing Mirror not folding out.
    Oct 2012
    London
    Managed to open it manually just by pushing it. There were no sounds of the motor whirring on the drivers side mirror, even before opening it manually. So I'd assume the motor has gone.
    Can this be replaced on its own or does the whole housing have to be replaced. Which I guess would cost ££££££££!
  7. Re: Help - Wing Mirror not folding out.
    46 Post(s)
    The whole mirror base needs replaced, the ones for my A4 are ~£180 a side.
  8. Re: Help - Wing Mirror not folding out.
    Dec 2010
    CD UK
    6 Post(s)
    Apologies for the hijack, but does anyone know if you can override the "in motion" disabler with VCDS? I found out that this was built into my A4 B7, wasting £130 or so but I'd reconsider adding it in future or even retrofitting to my current car if the mirrors could be made to fold in and back out when moving. Probably a type approval thing as it was really handy with previous VW group cars.
    Does manually forcing a stuck mirror damage the folding motor? And would it be a straightforward retrofit?
    MY2014 A6 allroad 245PS, my 8th Audi in 20 years - all quattros. 15th VAG car (incl 2 used ones).
  9. Re: Help - Wing Mirror not folding out.
    46 Post(s)
    Don't think it's possible. Haven't seen any setting.
  10. Re: Help - Wing Mirror not folding out.
    Mar 2014
    Edinburgh
    235 Post(s)
    I always found these to be a bit flawed. When they fold the mirrors turn up so acts like a bucket and collects water. On my last a6 the mirror was already juddering and folding smoothly when I got rid of it at 10 months old.
  1. Question Wing mirror inside clips broken (electric folding / light indicator)
    By Oxylis in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-11-2012, 01:38 PM
  2. Question Wing mirror replacement (for power folding)
    By PerryGarrod in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-10-2012, 10:18 PM
  3. Automatic Folding Wing Mirrors
    By steallan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-10-2012, 03:08 PM
  4. Folding Wing Mirror question
    By leowfc in forum Passat CC
    Last Post: 04-05-2010, 03:32 PM
  5. Folding wing mirrors
    By h7ptw in forum Golf MK5 - 2004 - 2009
    Last Post: 19-02-2009, 07:33 PM
