Thread: A4 B6 2002 Left indicator problem
Results 1 to 10 of 12
  1. A4 B6 2002 Left indicator problem
    Aug 2007
    Our B6 left indicators do not work except the side repeater, which does, its an intermittent problem and normally lasts a few days before it packs up and then starts working again for no reason that I can fathom.
    I have run VCDS and there are no errors being detected. I have also tried the Output test on the Cent Elect controller and the Left Front and Rear indicator inputs are working according to VCDS, but the indicators except the left repeater are not physically working. From the threads on the forum it appears that it maybe the Power controller that is at fault but is there any way of checking this just in case there is any other possible causes.
  2. Re: A4 B6 2002 Left indicator problem
    Jan 2016
    East London
    Is the bulb connection corroded? Maybe not making full contact
    Sent from my SM-N910F using Tapatalk
    Googling to see if my car sounds normal
    Audi A4 (B6, ASN) 02 Avant 3.0 Quattro Sport 6Spd
  3. Re: A4 B6 2002 Left indicator problem
    Jan 2016
    East London
    Or the metal contact loose? I once had to bend the contacts a little when I had aftermarket headlights in, but that was on an A3
  4. Re: A4 B6 2002 Left indicator problem
    46 Post(s)
    Stalks fail pretty often too.
  5. Re: A4 B6 2002 Left indicator problem
    Aug 2007
    Hi H45man,
    Yes checked the bulb connections for corrosion- all ok, also replaced the bulbs just in case.
  6. Re: A4 B6 2002 Left indicator problem
    Jan 2016
    East London
    Try get a voltage tester thingy and try check the pins/connection to see if anything comes across and measure the right side too.
    Changed fuse? Not sure if that would make difference :/
  7. Re: A4 B6 2002 Left indicator problem
    Aug 2007
    ok Ill try measuring the voltage and update the thread. Got to locate a voltmeter now, but should be ok
  8. Re: A4 B6 2002 Left indicator problem
    Aug 2007
    Managed to borrow a voltmeter and checked the voltages for the left indicators on {Power Controller T23/6 and 9 no output and then tried the same for the right indicators J23/4 and 7 voltage Ok and going on and off. The only strange thing I noticed was that on the left indicator J23/9 the output was .01 negative and then 0 as the indicator cycled on and off from the noise of the relay behind the dash panel.
  9. Re: A4 B6 2002 Left indicator problem
    Jan 2016
    East London
    Intermittent Indicator "Out" fault
    http://www.audi-sport.net/xf/threads...ing-up.149663/
    Most are saying loose connection. Does it happen when driving over bumps etc?
    Tried shaking the headlight unit a little with the indicator on? or wriggle the bulb holder
    Process of elimination but hope its something simple before you have to go buying parts
  10. Re: A4 B6 2002 Left indicator problem
    Jul 2015
    Staffs
    46 Post(s)
    Quote Originally Posted by beano1 View Post
    Have you checked the connector on the bulb holder, where the loom attaches?
    Mine has slight corrosion on one of the 'prongs' which causes similar problems every few months.
    Ian
    A4 B6 Avant Nogaro Blue
  1. Left turn facia indicator
    By Autostadt in forum Golf MK4 - 1999 - 2004
    Last Post: 03-05-2014, 09:11 PM
  2. Please Help sharan 2002 1.9 tdi central locking problem with indicator?
    By silversharan in forum Touran - Sharan - Caravelle
    Last Post: 03-06-2011, 02:10 AM
  3. Please Help Indicator - Left TICK TOCK - relay issue
    By CrazyA4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-10-2010, 03:29 PM
  4. Please Help A4 Indicator - Left turn - tick tock relay issue
    By CrazyA4 in forum New Member Introductions
    Last Post: 29-08-2010, 11:20 PM
  5. Left mirror changing indicator
    By danimur in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-04-2008, 07:53 AM
