Thread: HELP ! Audi A6 Idle Problem
Results 1 to 10 of 10
  1. HELP ! Audi A6 Idle Problem
    Apr 2015
    Goole United Kingdom
    Hi all,
    I have got an Audi A6 2007 2.0 TDI BRE engine.
    I have the following Issues:
    -On Idle car shakes slightly
    - When the car is running between 1600-2000 RPM I can feel the car shakes only when stationary when driving I can't feel it. Also when is cold if i run constantly between 1600-2000 RPM the car runs lumpy over 2000 RPM its fine.
    - I have notice at old if I start the car and the coolant temperature is between 50-70 and I start the AC at full power the car judders a lot.
    I can provide pictures in VCDS and I can scan it aswell.
    The clutch and flywheel has been changed on the car 1 year ago, also O rings at the injectors, the diesel from fuel filter is clear as well. Throttle has been changed. EGR has been cleaned.
    Please can someone help me?
  2. Re: HELP ! Audi A6 Idle Problem
    130 Post(s)
    1972 Post(s)
    Any fault code?
    SMF or DMF fitted?
  3. Re: HELP ! Audi A6 Idle Problem
    Apr 2015
    DMF fitted, It only has done 20-25k since was fitted
    No fault codes in the engine, that is the most annoying
    When running ok but still with the wobble
    On Engine Mesuring Blocks:
    Group 23 I have -63 -47 -64 -55
    Group 13 I have -0.21 ; 0.00; -0.09; 0.28
  4. Re: HELP ! Audi A6 Idle Problem
    Apr 2015
    Hello,
    Today when it did it again I disconnect MAF sensor and the car stop shaking and the idle was fine.
    With the VAG I don t have any error for the MAF. Is this faulty but not "faulty"?
  5. Re: HELP ! Audi A6 Idle Problem
    Jun 2012
    Aberdeen Scotland
    see my rev counter video, only happens at 75°C water temp (3.0TDI)
    19 September 2015 - YouTube
    Garry.
    VW golf GTi 1991 8 valve 3 door
    Alfa Romeo Giulia 2021 2.0 Turbo petrol
    Gone 2010 A6 Quattro Le Mans S Line 3.0TDi - Remapped to 290BHP by e-maps.co.uk, money well spent
  6. Re: HELP ! Audi A6 Idle Problem
    130 Post(s)
    1972 Post(s)
    Do you get smoke from the exhaust after the engine has been idling for a long time?
  7. Re: HELP ! Audi A6 Idle Problem
    Jun 2012
    Aberdeen Scotland
    no.
    Garry.
  8. Re: HELP ! Audi A6 Idle Problem
    130 Post(s)
    1972 Post(s)
    I have just realised there are two cars here..... radududuman, your car sounds just like the problem in VAG Technical Product Information notice 2008919/14
    1) Light juddering at constant engine speed and low load between 1200>2000 rpm
    2) Slightly delayed accelerator response from overrun of 1000>2000 rpm
    3) Accelerator operation insufficient in stop& go operation
    4) Slightly erratic idle speed.
    This due to the after injection during DPF regen and is normal, no repair or production change possible.
  9. Re: HELP ! Audi A6 Idle Problem
    Apr 2015
    Hi, my car does not have a DPF filter. Its my revs it does nearly the same as gary_m but my car is 2.0 BRE
  10. Re: HELP ! Audi A6 Idle Problem
    130 Post(s)
    1972 Post(s)
    Does this match your fault?
    1) A6 2.0L TDI - Idle speed fluctuates by 100 - 200 rpm at a coolant temp between 40 and 70 degrees centigrade.
    2) Vehicle judders when accelerating during warm up phase.
    If it does, get your local Audi dealer to see if your car is subject to TPI Transaction number 2015457/9 which involves a software update and/or a new EGR cooler seal.
  1. Intermittent Idle problem Audi A3 1.6
    By A3 puzzler in forum VCDS - Help Requests
    Last Post: 26-05-2009, 06:00 PM
  2. Audi A6 A/T 2.6 idle problem
    By lappies in forum Archive posts
    Last Post: 23-11-2007, 04:22 PM
  3. Audi A3 1.6 Start-up Idle Problem
    By craigbeal in forum Audi A3 - Archive Topics
    Last Post: 12-07-2007, 01:52 PM
  4. audi 100 idle problem
    By jessicasdad in forum 100 - 200 - Turbo - 100 S4
    Last Post: 19-09-2006, 11:36 AM
  5. 2000 Audi A4 Idle Problem
    By Jaimie129 in forum Chat - Completely Off Topic
    Last Post: 08-08-2006, 03:24 AM
