Thread: Locking wheel nut stuck solid and socket slipping off.
  1. Locking wheel nut stuck solid and socket slipping off.
    May 2013
    At foot of the Lammermuirs
    With spring in the air it was time to take the winter wheels and tyres off. Three wheels completed and everything going well but then a problem. The locking wheel nut on the final wheel is stuck solid and the security socket appears to be just slipping off the teeth. I tried the usual tricks such as giving it a sharp blow with the hammer but to no avail. I'm now driving around with 3 summers and 1 winter on. The local tyre depots are all closed so I can't visit any of them.
    Any suggestions as to how to get this off?
  2. Re: Locking wheel nut stuck solid and socket slipping off.
    Dec 2014
    Bedford
    42 Post(s)
    Does your locking tool look worn? If it does you could take it to an Audi dealer. They will have a master set. They should be able to remove that wheel nut for you.
    Sent from my SM-G900F using Tapatalk
  3. Re: Locking wheel nut stuck solid and socket slipping off.
    Mar 2014
    Edinburgh
    235 Post(s)
    As long as it's the key that's bust and not the bolt/nut head you have a chance in ordering a new key from Audi. If both are bust it's gonna need drilled out which can be costly.
    Normally the keys get damaged from air guns at tyre places and garages and people jumping on the wheel brace to tighten the nut instead of turning with just arms.
    2015 272 saloon Fl, lighting pack, 19" 10 spoke alloys, electric boot, memory seat with folding mirrors, tech pack, silver leather interior and privacy glass.
  4. Re: Locking wheel nut stuck solid and socket slipping off.
    Feb 2007
    Try using a 18mm socket and hammer it on to the the lock nut. A 6 sided socket is best - then use long lever on the secured socket.Apply a strong force to the lever. This should hopefully work. good luck.
  5. Re: Locking wheel nut stuck solid and socket slipping off.
    Mar 2014
    Edinburgh
    235 Post(s)
    What about using one of those gator grip sockets ?
  6. Re: Locking wheel nut stuck solid and socket slipping off.
    May 2013
    Thanks all. I took the car to my local fitters and they managed to get it off in about 2 minutes. One had the security socket on a long bar while the other was hitting it with a lump hammer. I now have 4 summer wheel/tyres back on.
  1. Question Looking for recommendation for unsticking a stuck locking wheel nut
    By jangles in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-09-2011, 09:07 PM
  2. Question Wheel Nut Socket Size
    By ToMBoY_C in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-05-2011, 07:51 PM
  3. Missing locking nut socket
    By JON4C in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-02-2011, 10:37 AM
  4. Missing VW locking wheel nut socket.
    By VWjim in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-08-2010, 09:22 PM
  5. wheel locking nut
    By yogise in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-04-2007, 08:02 AM
