Re: Planning to retrofit MMI 3G High –
01-04-2016,05:37 PM
Originally Posted by
hufodorp
Hi all,
I have a 60 plate A6 2.0TDI S-Line SE (former Le Mans). I have factory MMI 3G LOW in this car and I have found a good source for a new MMI unit which is High version. I know the PN that I need is "4H0 035 666" but don't know exactly the letter after this. The source that I found is "4H0 035 666 L" which was manufactured in 2013. Will this be compatible with my car? Perhaps if anybody has 60 or 11 plate A6 with MMI High would do me a favor and check the PN through VCDS?
Thanks for the help in advance,
Pal
Not quite in the age range you're after, but I had a 2009 A6 Le Mans with MMI 3G High. The VCDS scan for the 5F unit is below:
Address 5F: Information Electr. (J794) Labels: Redir Fail!
Part No SW: 4E0 035 666 D HW: 4E0 035 666
Component: H-BN-EU H64 0143
Revision: -------- Serial number: 345BY097545942
Coding: 010101000102C3ED01000715EF6300030001
Shop #: WSC 00778 210 97003
VCID: 2756F150EF7D
Part No: 8R0 060 884 R
Component: EUR 2010 1107
Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Part No SW: 4F0 910 609 E HW: 4F2 919 611 M
Component: Bedienteil MM H01 0060
No fault code found.
None of the components in mine had a 4H code. Mine was 4E0 035 666 D. Probably worth you waiting for a reply from someone with a later car though
Cheers!
MF.
Now: E 53 AMG 4MATIC / Q5 2.0TFSi Prestige
