Thread: INtermittent exclamation mark warning on dash
  1. INtermittent exclamation mark warning on dash
    Dec 2013
    A, A
    Hi all,
    Every now and again, usually when it's cold, I start the car (A6 1.9tdi avant) and get three high pitched peeps and a red exclamation mark flashes three times, and I usually can see the traction control symbol flashes too, then all is ok. Today it happened three times and everytime the car started but then cut out immediately, at the same time I was getting the flashing key symbol on the dash. on the third time it started ok.
    THe key symbol is apparently linked to the key and immobiliser system, but the handbook says the car would;t start at all if the key wasn;t the right one for the car...
    I have checked brake fluid and steering fluid, both ok.
    Any ideas?
  2. Re: INtermittent exclamation mark warning on dash
    Oct 2005
    Any red lights mean stop as soon as you are able and don't drive the vehicle.
    If the light looks like this;
    (Not my image)
    ...then it's a brake warning. If the brake fluid level is fine, then it'll be low fluid pressure or a fault with the ABS.
    Start with a fault code scan and work from there.
  3. Re: INtermittent exclamation mark warning on dash
    Dec 2013
    A, A
    HI Sam, thanks for the response.
    Just to clarify, no red light stays on, it occasionally does the three flashes on start up. THis morning (which was very cold) it didn't. I will get the brakes checked out though, as the brake fluid level is fine.
  4. Re: INtermittent exclamation mark warning on dash
    Jan 2015
    Israel Kfar uriya
    9 Post(s)
    If you have this option would be right to check for fault codes
  5. Re: INtermittent exclamation mark warning on dash
    Jul 2007
    glasgow
    35 Post(s)
    Its your battery
    1st thing car does on start up ( I had your car) is check the battery has enough power to work the brakes.
    As the car has just started and the alternator has not had a chance to charge battery, the battery will show as a fault.
    Check the battery at a garage for a dud cell(s) . This should be free .
    If the battery is fine, then check alternator output
    The 2005 onwards A6 checks after 10 minutes the state of the battery, allowing the alternator a chance to charge the battery.
    Cold mornings will expose any battery with dud cells
  1. Question Flashing red exclamation mark (audi 80 cabriolet auto 1999)
    By lorriesharday in forum 80 - 90
    Last Post: 25-03-2010, 08:31 PM
  2. Replies: 0
    Last Post: 13-11-2007, 05:31 AM
  3. Newbie please help abs and exclamation mark light
    By 20vt1 in forum Archive posts
    Last Post: 07-03-2007, 01:01 AM
  4. Newbie ABS and exclamation mark light HELP PLEASE!!!
    By 20vt1 in forum Passat - Archive Topics
    Last Post: 05-03-2007, 10:01 AM
  5. flashing exclamation mark on dash
    By nik in forum 80 - 90
    Last Post: 04-11-2006, 09:08 PM
