Thread: Illuminated Door Sills - Anyone?
Results 1 to 10 of 19
  1. Illuminated Door Sills - Anyone?
    Jul 2012
    Manchester, England
    Morning All
    Has anybody installed aftermarket illuminated door sills? I've been having a look at them over the past few days, some of them look really nice and also quite OEM. I noticed these particular ones on AliExpress, the description says you just have to connect the wires to negative and positive footwell lights. Any ideas whether it would be that straight forward?
    http://www.aliexpress.com/item/LED-door-sill-For-Audi-A6L-C7-2013-2014-2015-Sline-Led-moving-door-scuff-plate/32596198531.html?spm=2114.40010508.4.18.XF51q7
  2. Re: Illuminated Door Sills - Anyone?
    Mar 2008
    11 Post(s)
    I had a pair for the old C6 but the wiring was a bit of a pain as it was way too short and I just did not feel comfortable with the quality of the wire they provide.
    Maybe things have changed but in my case, even connected to a 12v battery meant the wire was heating up
    If it has changed, I would not mind trying it again because they do have a nice look to them - it was not in your face bright light but subtle
    Audi A7 Black Edition 3.0 TDI (272) 2015 (FL)
  3. Re: Illuminated Door Sills - Anyone?
    Jul 2012
    Manchester, England
    Where did you wire yours into? Do you have to drill any holes to feed the wires through anywhere?
  4. Re: Illuminated Door Sills - Anyone?
    Mar 2008
    11 Post(s)
    I only did the one side (Drivers) and went straight up to the fuses on the drivers side wedging the cable in-between the seals.
    It's how I did my dashcam so was not too much of an issue
    There was a slot in the plastics where the sills go where the wire tucked inside nicely so again no drilling, just stuck it down with some pads that were included in mine
    I suppose if the cable was long enough, you'd almost want it to be linked to the interior lights rather than always on
  5. Re: Illuminated Door Sills - Anyone?
    Jul 2012
    Manchester, England
    Thanks buddy, tempted to go for them.
  6. Re: Illuminated Door Sills - Anyone?
    Mar 2008
    11 Post(s)
    No probs but do read up/test etc properly. Mine was a much earlier release so don't go on what I had :- )
    I didn't have luck with them due to the heat nor with the led front lights into the fog grill again because of the cheap cable they had which heated up too much for my liking
    Back in my Corsa boy-racer days, I had a similar cable melt which is why I had been extra-cautious
  7. Re: Illuminated Door Sills - Anyone?
    Mar 2014
    Edinburgh
    235 Post(s)
    They actually look quite nice.
    I was thinking about something like this as my wife's merc has these and they look really nice in the dark with the mb badge lighting up.
    2015 272 saloon Fl, lighting pack, 19" 10 spoke alloys, electric boot, memory seat with folding mirrors, tech pack, silver leather interior and privacy glass.
  8. Re: Illuminated Door Sills - Anyone?
    Jul 2012
    Manchester, England
    i'm still waiting for delivery of my A6 so I'm not 100% sure of what they will look like. Would somebody be so kind as to upload a picture of what a Black Edition / S line looks like with the standard sills?
  9. Re: Illuminated Door Sills - Anyone?
    Jul 2012
    Manchester, England
    Ok just giving this some thought and wondered whether anybody could answer the following please.
    As far as I can see, the sills come with just two wires attached two them, positive and negative. Am I right in thinking that I could tap them wires into the wires for the footwell lights on the drivers and passenger footwell? I'm assuming that the wires running to the footwell lights are just a positive and negative wire? If that will do the trick the final question is, do the footwell lights illuminate as soon as the door is opened or do they illuminate when the ignition is switched on?
  10. Re: Illuminated Door Sills - Anyone?
    Mar 2014
    Edinburgh
    235 Post(s)
    My footwell lights come on when I open the door not sure if this is different to others as I have the lighting pack.
    My worry would be its on all the time when the headlights are on so I would be worried about it burning out the light bulbs or over heating the wires.
  1. A4 door sills
    By Staffylover in forum Body Work, Body Styling and Body Kits
    Last Post: 19-05-2014, 06:04 PM
  2. Replies: 8
    Last Post: 25-02-2013, 09:43 AM
  3. Stainless Steel Door Sills
    By Pidge_MKV in forum Golf MK6 - 2009 - 2013
    Last Post: 11-06-2010, 06:26 PM
  4. A4 door entry sills
    By scotty010 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-01-2010, 09:21 PM
  5. Stainless steel door sills
    By d-lite in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-04-2007, 11:57 AM
