Thread: Glow plug light flashing and loss of power
  1. Glow plug light flashing and loss of power
    May 2012
    Manchester
    9 Post(s)
    Hey guys.
    I have a 2.0 Audi A6 C6 Multitronic Gearbox with BRE engine. (140 bhp remapped to 170 and DPF removed )
    Today on the way home from work on the motorway while at a steady speed, the glow plug light started flashing and i noticed a loss in power. I pulled over on the hard shoulder and was going to limp it to my mechanic, suddenly after about 10 mins of limp mode, the car came back to life.
    When my mechanic scanned it with a vag tool, it said something about the EGR value shorting out, mentioned it was sporadic and check for leaking along the loom. The wiring all appears to be fine and my mechanic cleared the fault and said see how it goes. (hence i dont have the exact fault code)
    Just wondering what you guys think this is.
    My mechanic said if it happens again just replace the EGR value
    Thought guys?
    2008 Audi A6 C6 S-Line Saloon, 2.0 Diesel with Multitronic Gearbox. BRE engine code and remapped to 170BHP (Stock was 140) Has 85k on the clock
  2. Re: Glow plug light flashing and loss of power
    May 2012
    Manchester
    9 Post(s)
    if anyone can assist? the issue happened again today and i just did a VCDS scan and got the following error:
    Address 01: Engine Labels: Redir Fail!
    Control Module Part Number: 03G 906 016 MF HW: 03G 906 016 MF
    Component and/or Version: R4 2,0L EDC G000CG 1142
    Software Coding: 0000076
    Work Shop Code: WSC 11111 111 11111
    VCID: 73F0FCD38BB5DD9A12E2211-8026
    1 Fault Found:
    001027 - EGR Valve (N18)
    P0403 - 000 - Malfunction - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 150204 km
    Time Indication: 0
    Date: 2016.03.15
    Time: 20:30:36
    Freeze Frame:
    RPM: 2919 /min
    Speed: 151.0 km/h
    Duty Cycle: 0.0 %
    Voltage: 13.60 V
    Mass Air / Rev.: 1240.0 mg/str
    Duty Cycle: 14.7 %
    Bin. Bits: 00000000
    Readiness: 0 0 0 0 0
    im assuming the EGR valve needs replacing?
  3. Re: Glow plug light flashing and loss of power
    May 2014
    Darlington
    78 Post(s)
    I would say it's a faulty EGR valve, and will need replacing. They are a known failure item, and with an EGR failure the car may go into limp mode.
  4. Re: Glow plug light flashing and loss of power
    May 2012
    Manchester
    9 Post(s)
    I thought as much. Any ideas on a good source for these? Does brand matter? ECP sell for varying prices. Between £150 and £250?
    I have seen brand new ones on ebay as cheap as £80
  5. Re: Glow plug light flashing and loss of power
    Nov 2008
    Loads on eBay m8, don't buy a 2nd hand 1 that's been cleaned up
    Easy enough to fit, about 7 bolts in total
    Star drive, torx bolt fittings
    2008 Audi A6 2.0 tdi s line avant. BRE engine. 19" le mans alloys, bluetooth, sat nav,full leather
  1. Please Help Flashing glow plug light and loss of power
    By jasonmking in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-12-2016, 06:15 AM
  2. Please Help Loss of power - smoking and then flashing glow plug light
    By simyboye in forum A8 - S8 - V8
    Last Post: 08-12-2013, 07:56 PM
  3. Glow plug light flashing loss if power
    By Furion in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-10-2013, 08:02 AM
  4. Glow plug flashing + loss of power
    By Macdoon in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-05-2011, 09:28 PM
  5. Replies: 3
    Last Post: 10-09-2009, 10:41 AM
