Thread: 1.9 tdi bxe gearbox oil specs?
Results 1 to 10 of 11
  1. 1.9 tdi bxe gearbox oil specs?
    Feb 2016
    Oxfordshire
    Hi guys, wanting to do a gearbox oil change on the golf, it's a mk5 1.9 tdi 2007 match. Is it vw only stuff or is there an equivalent in the market?
  2. Re: 1.9 tdi bxe gearbox oil specs?
    May 2012
    Everywhere
    308 Post(s)
    Always an equivalent and usually cheaper .
    What's the VW part number / oil spec ?
  3. Re: 1.9 tdi bxe gearbox oil specs?
    46 Post(s)
    VW stuff only, it's cheap enough from them plus knowing it's the absolutely correct oil for the box it makes sense getting it from them.
  4. Re: 1.9 tdi bxe gearbox oil specs?
    May 2012
    Everywhere
    308 Post(s)
    No don't be silly who do you think makes the oil for them.
    It'll be either Fuchs or Castrol .
    You don't get data sheets with genuine gearbox oil .
  5. Re: 1.9 tdi bxe gearbox oil specs?
    Jul 2007
    glasgow
    35 Post(s)
    Go to VW direct and get the spec, the spec can & does change over time ........................................... you don't have to buy from them , but you may well be pleasantly surprised on the price. If its say £9 or £10 per litre from them, I would just buy it.
    TPS or trade part specialist will be around the same price
  6. Re: 1.9 tdi bxe gearbox oil specs?
    Jul 2015
    Staffs
    46 Post(s)
    Some VW gear oil is nearly as thin as water. After market oil, even with the correct spec is nothing like it.
    Ian
    A4 B6 Avant Nogaro Blue
  7. Re: 1.9 tdi bxe gearbox oil specs?
    Jul 2007
    glasgow
    35 Post(s)
    Its just personal choice, but my skoda fabia was far easier to get into 2nd gear with upgraded specs.
    Get the correct spec & then its personal choice
    By the way, my VW dealer is really expensive for parts. I go to my Skoda dealer who accesses the same VAG computer to buy gearbox oil. Strange but true, however I am dealing with Arnold Clark who are notorious
  8. Re: 1.9 tdi bxe gearbox oil specs?
    May 2012
    Everywhere
    308 Post(s)
    Quote Originally Posted by rowdy-999 View Post
    So what is its viscosity at 40°C ?
    I'm sure a company such as Fuchs would have the savy to match these genuine oils for viscosity very well as a recommendation.
  9. Re: 1.9 tdi bxe gearbox oil specs?
    May 2012
    Everywhere
    308 Post(s)
    If it's thin when cold you want I recommend...
    I know this to be suitable for the vag 2.0 tdi 6 speeds and can't see a reason why a 1.9 Big Exploding Engine couldn't use it .
  10. Re: 1.9 tdi bxe gearbox oil specs?
    Feb 2016
    Oxfordshire
    Thanks for all your replies, how much does it hold?
  1. Question Oil Specs
    By jcdub in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 22-02-2016, 09:12 AM
  2. 2.0 tdi Gearbox Transmission oil spec & amount for GYX gearbox ?
    By niall campbell in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-09-2015, 03:08 PM
  3. Question VW / Skoda: Are the oil specs the same?
    By djmx5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-12-2010, 10:41 PM
  4. oil for a 1.9TDI - specs
    By philfingers in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-11-2010, 08:23 AM
  5. B7 RS4 oil specs
    By Teutonic_Tamer in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-08-2007, 12:10 PM
