Thread: Rear washer - pipe routing info request
Results 1 to 8 of 8
  1. Rear washer - pipe routing info request
    Mar 2009
    Cotes d"Armor, France
    Yes the flow is going elsewhere than to the rear screen so Ill have to start taking up carpets. It would help if I knew which side the pipe went. Can anyone help?
    `05 1.9 TDI 130 Avant Multitronic - 4B5 06H - AVF HB9 Final Edition
  2. Re: Rear washer - pipe routing info request
    May 2012
    Glasgow
    From behind glove box (rhd), Along left inner sill under carpet, then up over rear wheel arch, emerges in boot cubby hole on left. It can leak in a few places along this route, also within the rubber boot between body and tailgate (right hand side if I remember rightly).
  3. Re: Rear washer - pipe routing info request
    Mar 2009
    Thanks, Just what I was looking for.
  4. Re: Rear washer - pipe routing info request
    Jan 2015
    Israel Kfar uriya
    9 Post(s)
    If there is no water flooded carpets in the rear seat With a similar smell to the flushing fluid, I think that is right look for free or torn tube near the sprinkler pump. (At the bottom of the washing liquid container)
  5. Re: Rear washer - pipe routing info request
    Mar 2009
    When the rear washer stopped working I realised that the water might be leaking somewhere it shouldn't so I refrained from using it so I don't have wet carpets (I think). The wash container looks a favourite place to start the hunt.
  6. Re: Rear washer - pipe routing info request
    Jul 2010
    Worcestershire
    Drat. Double post. See below for the much funnier version.
  7. Re: Rear washer - pipe routing info request
    Jul 2010
    Worcestershire
    It might be worth checking the pipe join right in the back corner (under the toolbox and CD changer rack). That joint blew apart on mine one winter when the washer fluid froze in the rubber bellow up by the tailgate hinge.
    I tried the rear washer and there was nothing except an asthmatic wheeze from the pump and half a pint of Smurf wee dribbling out onto the floor behind the wheel arch.
  8. Re: Rear washer - pipe routing info request
    May 2012
    Glasgow
    Same as above, mine had burst at that joint in the boot cubby hole, filling that corner with pish. As well as in the rear passenger footwell where the pipe had split and someone had previously tore up the carpet and bodged it together with micro bore central heating pipe!?.. Successfully I might add..
  1. A4 Avant - Rear Washer Bottle / Motor / Washer Pipe routing
    By mumutley in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-03-2013, 09:18 PM
  2. Rear Washer jet and where the pipe goes
    By padrag_king in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-04-2012, 08:31 PM
  3. Rear washer pipe work
    By Chappers in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-02-2012, 03:03 PM
  4. leaking rear washer pipe
    By thewall in forum Polo - Derby - Lupo - Fox
    Last Post: 22-12-2010, 04:48 PM
  5. Where does rear washer pipe run?
    By a4tdidriver in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-12-2008, 04:46 PM
