Thread: mk7 Golf 1.6 tdi oil Filter location ??
Results 1 to 10 of 11
  1. mk7 Golf 1.6 tdi oil Filter location ??
    Aug 2015
    Hi guys,
    2015 mk7 Golf Hatchback 1.6 TDI
    Spent a while under the engine bay and struggle to find the oil filter, totally baffled
    It doesn't seem to appear to be in the same place as the mk6 golf 1.6 tdi
    really would appreciate a steer in the right direction
    Times like this, you could kill for a haynes manual. Don't know whats taking them soo long to produce a manual for the mk7 Golfs
  2. Re: mk7 Golf 1.6 tdi oil Filter location ??
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Are you not getting it done at the dealers or garage that can stamp the book to keep your warranty ?
  3. Re: mk7 Golf 1.6 tdi oil Filter location ??
    Feb 2013
    Quote Originally Posted by cameron1 View Post
    Hi guys,
    You'll see it if you remove the bottom engine compartment ( noise insulation ) cover.
    To remove it you need to disconnect connector from return flow-pump.
    Then unclip the alternator cable from its clip & swing it out of the way
  4. Re: mk7 Golf 1.6 tdi oil Filter location ??
    Aug 2015
    Quote Originally Posted by Rob69 View Post
    Yes, plan is to do an in between service. When the service light turns on, will still have it serviced by VW.
    Just can't see any benefits of leaving the old oil in for 20k/2years. Thats why i'm planning on doing oil changes myself at every 6k to increase its longevity
  5. Re: mk7 Golf 1.6 tdi oil Filter location ??
    Aug 2015
    Quote Originally Posted by algarve View Post
    sorry, still not getting it.
    You dont have any pictures or diagrams that you could show....please
  6. Re: mk7 Golf 1.6 tdi oil Filter location ??
    Aug 2015
    For the love of god, all i can say is my 1.6 tdi mk7 doesn't have an oil filter, i know that can't be right, you are probably right.... all i say is, if it does exist on my car, VW have certainly done a damn good job of hiding it........
    Spent absolutes ages under the bonnet in the cold and still unable to trace the oil filter..... damn VW
    Would be forever grateful if anyone could help me, by showing me a diagram or even a video on youtube of the oil filter location....... i've scanned most of the videos on youtube of the 1.6 tdi and none of them look like my engine. Most of the 1.6 TDi on youtube seem to look the same as the mk6 golf and NOT MK7
    Many Thanks in advance
    Cameron
  7. Re: mk7 Golf 1.6 tdi oil Filter location ??
    Anyone knows how much oil mk7 1.6tdi chla takes?
  8. Re: mk7 Golf 1.6 tdi oil Filter location ??
    Feb 2013
    Quote Originally Posted by bakili View Post
    You probably mean engine code CLHA ?
    If so its 4.6 litres including the filter.
  9. Re: mk7 Golf 1.6 tdi oil Filter location ??
    Many thanks
    Yes CLHA, sorry typo.
    Will it need slightly topping up after adding 4.6 ltrs?
  10. Re: mk7 Golf 1.6 tdi oil Filter location ??
    Feb 2013
    [QUOTE=bakili;1013605]Many thanks
    Sent from my SM-G930F using Tapatalk[/QUOTE
    Before adding anymore oil after changing the filter and putting in the new oil I'd run the car run for a few minutes to circulate.
    Then I would check the oil level again after leaving the engine off for five minutes (car on a level surface of course) before doing a level recheck.
    I wouldn't add any further oil at all until I'd done that..
  1. Location of oil filter Mk5 Golf 1.4S
    By ronnyb in forum Golf MK5 - 2004 - 2009
    Last Post: 23-07-2011, 11:06 AM
  2. oil filter location
    By rusty b in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-12-2009, 06:28 PM
  3. Oil filter location !!!
    By Chappers in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-09-2009, 06:39 PM
  4. A4 Oil Filter Location
    By brad.mcbride in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 19-07-2008, 03:36 AM
  5. Oil filter location
    By dfb in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-06-2007, 10:05 PM
