Thread: 1998 VW Polo 1.4 Auto CL - won't start after engine wash!
Results 1 to 10 of 16
  1. 1998 VW Polo 1.4 Auto CL - won't start after engine wash!
    Feb 2016
    Middlesex
    Hi Chaps and Chapesses,
    I have a problem that I wonder if you can help please
    So - Car was running perfectly, idling away on the drive and my son was Jetwashing over for me.
    He opened the bonnet and I thought he was going to just jet the slam panel - but he went over the top of the engine and down the side (gearbox). The car then cut out.
    It will now turn over - but not fire...
    So - basics:
    - I have a spark at every plug
    - When removing the fuel feed to the fuel rail - I have fuel at ign on - and then on crank it also spurts out
    So I have spark - and Fuel - and you would assume air as the butterfly on the throttle operates perfectly.
    Tried a drop of fuel in the butterfly for good measure but no difference.
    Any ideas? I assume something to do with the injectors not opening?
    I am an ex Saab / Vauxhall mechanic so know my way around these things.. Potentially just water in a connection somewhere I suppose that will dry and problem over?
    Frustrating!
    thanks all
  2. Re: 1998 VW Polo 1.4 Auto CL - won't start after engine wash!
    Feb 2016
    Middlesex
    Sorry - I should add.
    I have the Ross-Tech VCDS - and that reports no faults at all... So thinking that it can't be a sensor fault?
  3. Re: 1998 VW Polo 1.4 Auto CL - won't start after engine wash!
    Oct 2005
    Welcome to VWAF
    Leaving the plugs in, check the plug wells for water and blow any out with compressed air/WD40.
    Check fuses on top of the battery and the rest of the electrics in the engine bay.
    This is why you degrease an engine and not pressure wash it
  4. Re: 1998 VW Polo 1.4 Auto CL - won't start after engine wash!
    Feb 2016
    Middlesex
    Quote Originally Posted by Sam View Post
    Welcome to VWAF
    Thanks very much for the reply.
    It was as he went over the plug area (through the shield) that it seemed to cut out.
    Ill spray some WD40 into the wells with the plugs in and see what happens.
    Is there any special way the injectors are powered up?
  5. Re: 1998 VW Polo 1.4 Auto CL - won't start after engine wash!
    Oct 2005
    Have you checked any filters to see if they're damp, if it's sucked in water you could be looking at all sorts of fun.
    Thinking about it, there's the main loom somewhere in the engine bay and from memory there's a connection there too, it's a big plug that twists the two halves together.
    Sorry I can't be more specific but it's been a while since I've been in the engine bay of a 6n.
    Edit: Injectors run from a loom IIRC, nothing special as far as I can remember.
  6. Re: 1998 VW Polo 1.4 Auto CL - won't start after engine wash!
    130 Post(s)
    1972 Post(s)
    Water inside the distributor cap.
    1 1 0
  7. Re: 1998 VW Polo 1.4 Auto CL - won't start after engine wash!
    Feb 2016
    Middlesex
    Thanks again - so yes, I took the air filter off the top of the throttle body and it was bone dry - so its not taken in water I don't think.
    I only had plus gas available yesterday so gave some connections a squirt of that. Will get some WD40 on the plug / lead wells and see how that goes tonight..
    Really appreciate all the help.
  8. Re: 1998 VW Polo 1.4 Auto CL - won't start after engine wash!
    Feb 2016
    Middlesex
    Dizzy cap all dry too.
  9. Re: 1998 VW Polo 1.4 Auto CL - won't start after engine wash!
    Pembrokeshire
    22 Post(s)
    have you taken the dizzy cap off and dried it out as crasher says. ?
    you have, yes, hahhaa]#
  10. Re: 1998 VW Polo 1.4 Auto CL - won't start after engine wash!
    Feb 2016
    Middlesex
    I did mate - there was no water ingress in there at all.
  1. 1998 Audi A4 2.5 TDI SE won't start
    By Axle360 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-01-2015, 10:58 PM
  2. A4 B5 1998 2.4 30v (80000 miles) cranks but won’t start
    By Paulnz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-05-2014, 10:04 AM
  3. What kicks in within 2 minutes of cold engine start?? - A6 2.5TDI Auto 1998
    By freddyuk in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-11-2010, 11:51 PM
  4. 1998 1.9TDi. Left 2 months, won't start
    By 31satara in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-08-2007, 11:13 AM
  5. VW Passat 1998 A/C heating won't start. Please help!!!
    By nacid in forum Chat - Completely Off Topic
    Last Post: 08-11-2006, 06:38 PM
