Thread: Seat Leon 1.6 TDI - Failed turbo, low compression
Results 1 to 8 of 8
  1. Seat Leon 1.6 TDI - Failed turbo, low compression
    Feb 2016
    GB
    Hello thanks for letting me join
    My Seat Leon 1.6 TDI 63 plate which I've own from new and fully main dealer serviced had the turbo fail at 33k 10 days after a service
    The dealership has said that the engine has low compression on 1 cylinder
    Is this a common problem
    Thanks in advance
    James
    Sent from my SM-G920F using Tapatalk
  2. Re: Seat Leon 1.6 TDI
    May 2008
    Yorkshire
    James - welome to the forum.
    I think you'll get a better response in the Leon section of the forum:
    Leon
    Andy
    2020 B9 A4 Avant Black Edition S Tronic
    2016 FL C7 A6 Avant Ultra Black Edition S Tronic | 2015 FL C7 A6 Avant Ultra Black Edition - S Tronic
    2012 B7 A4 Avant SLine |2008 B7 A4 Avant Sline | 2008 VW Golf PD150 GTI | 2007 VW Golf PD150 GTI
    2004 B6 A4 Avant Sport | 2000 A3 1.8T Sport | 1983 VW Golf GTX
  3. Re: Seat Leon 1.6 TDI
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Since car has a full service history and is a 63 reg. it would be good idea to approach dealer for a warranty claim to see what they say. Low compression & turbo failure at this age and mileage is not normal and indicates an engine fault.
    Skoda Octavia II SE 1.9PD TDI
    0 2 0
  4. Re: Seat Leon 1.6 TDI
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Most problems with the 1.6 CR TDI I've seen here seem to do with the egr cooler leaking. I dont know about the low compression on the vw 1.6 being common, but my pals ford TDCI went in with misfire and knocking on one cylinder, it was a bust small end and I suspected an injector had dripped and filled a cylinder, hydraulic locking the engine when next started. That was a Delphi fuel system, it got repaired at great cost and never ran right again. Fight your corner with the dealership as CR diesel system repair costs are eye watering.
  5. Re: Seat Leon 1.6 TDI - Failed turbo, low compression
    Feb 2016
    GB
    Over 2 weeks now and the supplying dealership still don't know what the issue is
    Been on to Seat UK again
  6. Re: Seat Leon 1.6 TDI - Failed turbo, low compression
    Nov 2010
    104 Post(s)
    Good luck !
  7. Re: Seat Leon 1.6 TDI - Failed turbo, low compression
    Feb 2016
    GB
    Quote Originally Posted by Rob69 View Post
    Good luck !
    Thanks I'm not a happy bunny
  8. Re: Seat Leon 1.6 TDI - Failed turbo, low compression
    Jul 2007
    glasgow
    35 Post(s)
    Can you get a scan done ?? Might be a Mass Air Flow meter
  1. Replies: 10
    Last Post: 29-04-2017, 06:25 PM
  2. Question 2009 Audi A3 tdi cabriolet - over boost & low compression...help
    By EMCKAUDI in forum 1.9TDi - Engine
    Last Post: 28-05-2015, 07:05 PM
  3. Replies: 0
    Last Post: 14-09-2013, 09:20 AM
  4. Please Help Low compression all cylinders 2001 1.9 TDI AWX
    By m.ramsdale in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-05-2011, 11:40 AM
