Thread: A6 saloon facelift conversion problems
Results 1 to 10 of 14
  1. A6 saloon facelift conversion problems
    Sep 2015
    widnes uk
    Hi, I require some assistance/ knowledge from fellow forum members please.
    I have a 2006 a6 3.0 Le Mans.
    I have recently completed the front and rear facelift conversion.
    I believe that in order to enable the led rear lights and bootlid lights they need to be coded and wired as an avant.
    This has been done to the best of my knowledge.
    After hrs of trial and error I cannot get the left reverse light and full brake lights to work properly.
    Also the indicators seem quite weak if that makes sense?!
    The brake lights come on as blocks rather than the full cluster as the daytime lights
    I have attached pics sorry about the quality- lack of.
    I'm really hoping that someone on here has completed the rear facelift previously or has knowledge of this process and can help put me right
    Thanks in advance
    Work done so far
    Facelift front bumper inc fogs and grilles
    Black center grille
    Facelift xenon drl headlights
    Black wrapped trims all round
    Gun metal alloys
    Black calipers and hubs
    Led interior bulbs
    Led licence plate bulbs
    Facelift bootlid
    Facelift rear bumper
    Facelift rear led clusters
    Stage 2 re map
    De cat dpf delete
    Straight ss exhaust tips
    Recently changed throttle body and actuator rods but yellow light still on!?
    Next on list - dab, reverse camera usb if poss
    Full write up as soon as lights sorted and I have time to give car a good detail
    Rick
  2. Re: A6 saloon facelift conversion problems
    Jan 2011
    Stafford, UK
    Are you sure that the lights are not faulty ?
    I can give you a list of my 2009 facelift codes if that will help.
    Code:
    Wednesday,18,March,2015,16:06:21:31033
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 14.10.2.0 (x64)
    Data version: 20150311
    Ross-Tech: Home
    VIN: WAUZZZ4F19Nxxxxxxxx   License Plate: BK 09 xxx
    Mileage: 60380km-37518mi   Repair Order:
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 08 09 0E 15 16 17 19 42 46 47 4F 52 53 55 56 5F
              62 72 76
    VIN: WAUZZZ4F19Nxxxxxx   Mileage: 60380km-37518miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    76-Park Assist -- Status: OK 0000
    Address 01: Engine (CAN)       Labels: Redir Fail!
       Part No SW: 4F7 910 401 K    HW: 4F0 907 401 E
       Component: 2.7TDI EDC17G000CG  0090
       Revision: 16H01---    Serial number:
       Coding: 010D002C02070128
       Shop #: WSC 18432 423 592680
       VCID: 2B5F28B68A7C0979EBD-807E
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans        Labels: 01J-927-156.lbl
       Part No SW: 4F5 910 157 H    HW: 01J 927 156 JG
       Component: V30 0AN 2.7lTDI RdW 0010
       Revision: --H05---    Serial number: 00000000000328
       Coding: 0000001
       Shop #: WSC 02325 785 00200
       VCID: 2E5921A2B96E7C51CC3-807B
    Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
       Part No SW: 4F0 910 517 AK    HW: 4F0 614 517 AT
       Component: ESP8 front      H03 0060
       Revision: 00000000    Serial number: 00000000000000
       Coding: 0020876
       VCID: 6DDBE6AE74E8C749B59-8038
    Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 D
       Component: FBSAUDIC6 ELV   H05 0100
       Revision: 00H05000    Serial number: 10602601261827
       Coding: 0000147
       Shop #: WSC 02324 785 00200
       VCID: 254BDE8EEC983F093D9-8070
       Subsystem 1 - Part No: 4F0 910 132 E
       Component: FBSAUDIC6 EZS   H03 0020
       Subsystem 2 - Part No: 4F0 910 220 D
       Component: FBSAUDIC6 IDG   H01 0040
    Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
       Part No SW: 4F0 910 043 B    HW: 4F2 820 043 AA
       Component: KLIMABETAETIGUNGH30 0070
       Revision: 00000073    Serial number: 00000000601444
       Coding: 0001302
       VCID: 1D3BF66EC4C8F7C9659-8048
    Address 09: Cent. Elect.        Labels: 4F0-910-279.lbl
       Part No SW: 4F0 910 279 N    HW: 4F0 907 279
       Component: ILM Fahrer      H22 0320
       Revision: 00000000    Serial number: 4F0907279
       Coding: 0013121
       Shop #: WSC 02335 785 00200
       VCID: 346D33CA57425681BA7-8061
       Subsystem 1 - Part No: 4F2 910 113 C  Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H10 0040
       Coding: 00056595
       Shop #: WSC 02335
       Subsystem 2 - Part No: 8K0 910 557   Labels: 8K0-955-559.CLB
       Component: REGENLICHTSENSORH04 0003
       Coding: 00146221
       Shop #: WSC 02335
    Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
       Part No SW: 4E0 910 110 L    HW: 4E0 035 110 A
       Component: CDC-MP3-Pana  H47 0050
       Revision: 00000012
       VCID: 2143CA9E38B0D329411-8074
    Address 15: Airbags (J234)       Labels: 4F0-910-655-10.clb
       Part No SW: 4F0 910 655 L    HW: 4F0 959 655 E
       Component: Airbag AU1042 H06 0090
       Revision: --------    Serial number: 003000000000
       Coding: 30314236303630303033554A305234463053
       ASAM Dataset: EV_Airba10AURB4 001001
       ROD: EV_Airba10AURB4.rod
       VCID: 30653FDA6B5A6AA1DEF-8065
       Crash sensor for side airbag; driver side:
       Serial number: 3574SRB400008495215.
       Crash sensor for side airbag; front passenger side:
       Serial number: 3584SRB40000849D397E
       Crash sensor for side airbag; rear; driver side:
       Serial number: 35152RB402J838NMVR2V
       Crash sensor for side airbag; rear; passenger side:
       Serial number: 35252RB402P838NMV35H
       Crash sensor for front airbag; driver side:
       Serial number: 3554NRB40000491848A/
       Crash sensor for front airbag; front passenger side:
       Serial number: 3564NRB4000049100D8W
    Address 16: Steering wheel        Labels: 4F0-910-549.lbl
       Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
       Component: J0527               0530
       Revision: 00H05000    Serial number: 90055083440101
       Coding: 0102142
       VCID: 2757D48696942D190F5-8072
       Subsystem 1 - Part No: XXXXXXXXXXX
       Component: E0221           H02 0030
    Address 17: Instruments (J285)       Labels: 4F0-920-xxx-17.clb
       Part No SW: 4F0 920 983 B    HW: 4F0 920 983 B
       Component: KOMBIINSTR.   H06 0135
       Revision: 00000000    Serial number: AE940E1D8
       Coding: 2F57110502002700010401
       Shop #: WSC 02391 823 56573
       VCID: 2B5F28B64A7C0979EBD-807E
    Address 19: CAN Gateway (J533)       Labels: 4F0-907-468.clb
       Part No SW: 4F0 907 468 F    HW: 4F0 907 468 F
       Component: GW-BEM 4CAN-M H06 0024
       Revision: 4LA70021    Serial number: 2100L0910680F4
       Coding: 000303
       VCID: 326135D26D5658B1A8B-8067
       Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
       Component: J367-BDM  H07 0107
    Address 42: Door Elect, Driver (J386)       Labels: 4F0-959-793.clb
       Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
       Component: TSG FA        H11 0250
       Revision:             Serial number: 0000100632175
       Coding: 011F06205041410001
       VCID: 46897902F1DED411143-8013
    Address 46: Central Conv.        Labels: 4F0-910-289.lbl
       Part No SW: 4F0 910 289 J    HW: 4F0 907 289 J
       Component: Komfortgeraet   H27 0220
       Revision: 02200027    Serial number: 01166766660000
       Coding: 0140027
       VCID: 31633ADEA85063A9D11-8064
       Subsystem 1 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HORN H03 1301
       Subsystem 2 - Part No: 4F0 910 177
       Component: Innenraumueberw.H01 0020
    Address 47: Sound System (J525)       Labels: Redir Fail!
       Part No SW: 4F0 035 223 P    HW: 4F0 035 223 P
       Component: BOSE G3 C6    H01 0100
       Revision: AG001300    Serial number: 00000000002161
       Coding: 0F010000
       VCID: 2953D2BE40801B69191-807C
    Address 4F: Centr. Electr. II        Labels: 4F0-910-280.lbl
       Part No SW: 4F0 910 280     HW: 4F0 907 280 A
       Component: ILM Beifahrer   H13 0100
       Revision:             Serial number: 00000000610073
       Coding: 0001103
       Shop #: WSC 02145 785 00200
       VCID: 5EB9B162894EACD13C3-800B
    Address 52: Door Elect, Pass. (J387)       Labels: 4F0-959-792.clb
       Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
       Component: TSG BF        H11 0250
       Revision:             Serial number: 0000100622308
       Coding: 011F06205C41410001
       VCID: 458B7E0ECCD8DF091D9-8010
    Address 53: Parking Brake        Labels: 4F0-910-801.clb
       Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
       Component: EPB  CEFC0090   H05 0090
       Revision: --H05---
       Coding: 0000531
       VCID: 2143CA9EF8B0D329411-8074
    Address 55: Headlight Range        Labels: 8P0-907-357.lbl
       Part No: 8P0 907 357 H
       Component: Dynamische LWR  H02 0010
       Revision: 00000001    Serial number:
       Coding: 0000003
       VCID: 3F876CE66E0485D9575-806A
    Address 56: Radio (R)       Labels: Redir Fail!
       Part No SW: 4F0 035 053 B    HW: 4F0 035 053
       Component: Radio U Basic H44 0020
       Revision: AB001007    Serial number: 341AQ097529712
       Coding: 010003010000000000
       VCID: 1C3DFB6A1FD2FEC1927-8049
    Address 5F: Information Electr. (J794)       Labels: 4E0-035-6xx-5F.clb
       Part No SW: 4E0 035 652 A    HW: 4E0 035 652
       Component: B-BN-EU       H47 0048
       Revision: --------    Serial number: 349A-097506098
       Coding: 010101010102C3FD43000F0DEF7300030001
       Shop #: WSC 00779 210 97010
       VCID: 1F47CC660EC4E5D9775-804A
       Subsystem 1 - Part No SW: 4L0 919 604     HW: 4L0 919 604
       Component: DU6 Basic  H43 0306
       Subsystem 2 - Part No SW: 4F0 910 609 E    HW: 4F2 919 611 H
       Component: Bedienteil MM  H01 0060
    1 Fault Found:
    03157 - Functionality limited due to Communications Disruption
                000 -  -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 161
                        Mileage: 60241 km
                        Time Indication: 0
                        Date: 2008.08.14
                        Time: 00:43:36
                 Freeze Frame:
                        Bin. Bits: 00000000 00000000
                        Bin. Bits: 00000000 00000101
    Address 62: Door, Rear Left (J388)       Labels: 4F0-959-795.clb
       Part No SW: 4F0 959 795 M    HW: 8K0 959 795 B
       Component: TSG HL        H10 0251
       Revision:             Serial number: 0000100645651
       Coding: 010E04204041220001
       VCID: 438F6016C2ECE13933D-8016
    Address 72: Door, Rear Right (J389)       Labels: 4F0-959-795.clb
       Component: TSG HR        H10 0251
       Revision:             Serial number: 0000100645097
    Address 76: Park Assist        Labels: 4Fx-910-283.lbl
       Part No SW: 4L0 910 283 A    HW: 4L0 919 283 A
       Component: Parkhilfe 8-Kan H02 0400
       Revision: 00H02000    Serial number: 13630901502908
       Coding: 0201016
       VCID: 2855D7BA9B8A226106F-807D
    End-------------------------(Elapsed Time: 02:52)--------------------------
    2 1 0
  3. Re: A6 saloon facelift conversion problems
    Nov 2012
    Somerset UK
    OP, do you have VCDS?
    As Roy has said have you checked the clusters themselves? Are they brand new or second hand?
    Have you checked the voltages/earths regarding the feeds to the lights?
  4. Re: A6 saloon facelift conversion problems
    May 2014
    Darlington
    78 Post(s)
    You would need to replace the central convenience module with a facelift version that supports LED lights. The module will require coding to enable the LED lights. Also the module will have component protection which can only be done at an Audi dealer.
    2 0 0
  5. A6 saloon facelift conversion problems
    Sep 2015
    widnes uk
    Thanks for the input guys, all your thoughts much appreciated
    TBH I am absolutely clueless when it comes to electronics and vcds.
    Thanks Roy I will pass that on to my electrician- he does everything but its the first time he's done the conversion/ re wiring
    The lights were genuines second hand but working when removed?
    In regards to the central convenience module being replaced i dont even know what that is or where to look/ start
    I read somewhere on the forums that only the coding to highline and re wiring is required?
    I decided on doing this conversion as it looked simple enough on paper - obviously not!!!
    Must say the car looks a lot meaner/ newer now though.
    I'm pretty sure the fault lies with the actual re wiring of the lights as the LEDs do work just brakes lights not using the whole led set
    I will forward all msgs to my electrician because id be lying if I said I understand them myself!?
    Has anyone done this conversion who would be able to pass on the wiring diagrams or even photos of your rear light wiring showing what wire goes where ?
    I have a spare set of lights I could possibly switch incase the fault is with them but I doubt it as the bulbs all work but not correctly so I think its the wiring
    Thanks again for your help
    Look forward to learning some more from you guys
  6. Re: A6 saloon facelift conversion problems
    Sep 2015
    widnes uk
    Quote Originally Posted by MarkTM View Post
    No dont have any diagnostic equipment whatsoever
    Im confident and like having a go fixing issues myself but when it comes to vcds electronics etc I'm sorry to admit I'm absolutely clueless
    I think I will shortly invest in vcds, someone on here is a supplier rosstech?
    Will have to slowly learn as I'm not planning to sell mine anytime soon- its a great car all round apart from the annoying yellow light paying regular visits
    I wouldn't know where to start though
  7. Re: A6 saloon facelift conversion problems
    Sep 2015
    widnes uk
    I have had the car scanned and there are faults with the convenience module, brake light circuits and a cpl others trying to upload but cant
    I'll screen shot it if anyone else can advise the problem
  8. Re: A6 saloon facelift conversion problems
    Sep 2015
    widnes uk
    Saturday,16,January,2016,17:53:28:62939
    VCDS Version: Release 12.12.0 (x64)
    Data version: 20130910
    VIN: WAUZZZ4F87N044337 License Plate: RICKY
    Mileage: 144710km-89918mi Repair Order:
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 56
    61 62 67 72 76 77
    VIN: WAUZZZ4F87N044337 Mileage: 144710km/89918miles
    07-Control Head -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    67-Voice Control -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4F0 910 402 D HW: 4F0 907 401 C
    Component: 3.0L V6TDI G000AG 0020
    Revision: --H03--- Serial number:
    Coding: 0011372
    Shop #: WSC 66565 257 00032
    VCID: 1E3338F3C9420EEE86F-804B
    Readiness: 0 0 1 1 1
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4F2 910 156 F HW: 09L 927 156 C
    Component: AG6 09L 3,0 TDI RdW 0030
    Revision: --H01--- Serial number: 4211322
    Coding: 0000001
    VCID: 285F1E2B9B06C05EFC3-807D
    Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
    Component: ESP8 quattro H01 0070
    Coding: 0020876
    VCID: 66C350135192162E0EF-8033
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H31 0220
    Revision: 31050601 Serial number: 10601000507884
    Coding: 0000019
    Shop #: WSC 02323 785 00200
    VCID: E3C5C90722A0E306691-80B6
    Subsystem 1 - Part No: 4F0 910 131 E
    Component: FBSAUDIC6 EZS H45 0080
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
    Part No SW: 4F0 910 731 J HW: 4E0 035 729
    Component: Interfacebox H43 2860
    Revision: 00000000 Serial number: 350HK067711613
    Coding: 0000002
    Shop #: WSC 00836 210 91875
    VCID: 29591B2F800CF956E3D-807C
    Subsystem 1 - Part No: 4F0 910 609 E
    Component: Bedienteil MMIC6H02 0060
    Subsystem 2 - Serial number: 00000000489836
    Subsystem 3 - Serial number: 0103.08.060000000100010395ÿ
    Subsystem 4 - Serial number: 010395ÿ
    Part No SW: 4F0 910 043 HW: 4F2 820 043 N
    Component: KLIMABETAETIGUNGH20 0170
    Revision: 00000031 Serial number: 00000000297703
    Coding: 0001046
    VCID: DBB5F1E71AD0DBC6211-808E
    Part No SW: 4F0 910 279 AF HW: 4F0 907 279
    Component: ILM Fahrer H30 0390
    Coding: 0019121
    Shop #: WSC 12345 123 00001
    VCID: 6DD12F3F746425764F5-8038
    Subsystem 1 - Part No: 4F2 910 113 A
    Component: Wischer AudiC6 H04 0190
    Coding: 00064784
    Shop #: WSC 12345
    Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH13 0090
    Coding: 00146221
    Shop #: WSC 12345
    2 Faults Found:
    02095 - Component Protection Active
    000 - -
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 201
    Mileage: 144708 km
    Time Indication: 0
    Date: 2016.01.16
    Time: 17:56:00
    02084 - Component Protection
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 201
    Mileage: 144708 km
    Time Indication: 0
    Date: 2016.01.16
    Time: 17:56:00
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
    Component: CD-Changer H44 0470
    Revision: 00000000 Serial number: AUZ5ZBF8171921
    Shop #: WSC 00000 000 00000
    VCID: 1C3732FBDF5E1CFE68B-8049
    Address 15: Airbags Labels: 4F0-910-655-8R.lbl
    Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
    Component: 4E AIRBAG AUDI8RH29 0280
    Revision: 08H29000 Serial number: 0037LD0G7DD7
    Coding: 0013381
    Subsystem 1 - Serial number: 6332CSME1209157E0
    Subsystem 2 - Serial number: 6342CSME12145D2D3
    Subsystem 3 - Serial number: 6352QSME13790579I
    Subsystem 4 - Serial number: 6362QSME136B370DM
    Subsystem 5 - Serial number: 63734SME0F591F65E
    Subsystem 6 - Serial number: 63834SME124F472D7
    Part No SW: 4F0 910 549 HW: 4F0 953 549 A
    Component: Lenksäulenmodul H08 0230
    Revision: 00H08000 Serial number: 90026062080297
    Coding: 0102141
    Shop #: WSC 00561 210 84714
    VCID: E6C3D013D192962E8EF-80B3
    Component: Lenkradmodul H07 0090
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 930 C HW: 4F0 920 981 F
    Component: KOMBIINSTR. M73 H18 0110
    Revision: 00400000 Serial number: 5HS34TU76
    Coding: 2049443
    Shop #: WSC 36594 001 1048576
    VCID: 23450907E2202306A91-8076
    Address 19: CAN Gateway Labels: 4F0-910-468.lbl
    Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
    Component: Gateway H11 0070
    Revision: 11 Serial number: 13008067268015
    Coding: ECFE53C41B7104
    Shop #: WSC 02334 785 00200
    VCID: 275D1D179618CF26F59-8072
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 P HW: 4E0 919 887 D
    Component: MNS ECE H48 1060
    Revision: 00000000 Serial number: 364H+067584990
    VCID: 3B75D1677A907BC6811-806E
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
    Component: TSG FA H12 0120
    Revision: 00000000 Serial number: 4e†
    Coding: 0002682
    Shop #: WSC 02327 785 00200
    VCID: 2C57E23B8FFEEC7E18B-8079
    Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
    Component: Komfortgeraet H22 0170
    Revision: 01700022 Serial number: 01017604170000
    Coding: 0142331
    VCID: 2E53E833B9E29E6E36F-807B
    4 Faults Found:
    01518 - Bulb for Back-Up Lights; Left (M16)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 204
    Reset counter: 201
    Mileage: 143287 km
    Time Indication: 0
    Date: 2015.12.21
    Time: 21:52:26
    01403 - Glass-Break Sensors; Rear
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 254
    Reset counter: 201
    Mileage: 143287 km
    Time Indication: 0
    Date: 2015.12.21
    Time: 20:10:13
    02932 - Control Circuit for Brake Light in Trunk/Hatch Lid; Right
    Freeze Frame:
    Fault Priority: 3
    Reset counter: 201
    Mileage: 143287 km
    Time Indication: 0
    Date: 2015.12.21
    Time: 20:14:26
    02933 - Control Circuit for Brake Light in Trunk/Hatch Lid; Left
    Freeze Frame:
    Fault Priority: 3
    Reset counter: 201
    Mileage: 143287 km
    Time Indication: 0
    Date: 2015.12.21
    Time: 20:15:03
    Address 47: Sound System Labels: 4F0-910-223-AS.lbl
    Part No SW: 4F0 910 223 G HW: 4F0 035 223
    Component: Amp.-ASK H10 0350
    Revision: 44S00001 Serial number: 02707060327957
    Coding: 0000013
    VCID: 224B0C03FD3A2A0EA27-8077
    Component: ILM Beifahrer H10 0080
    Revision: Serial number: 00000000267252
    Coding: 0001103
    VCID: DEB3F8F309C2CEEE46F-808B
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
    Component: TSG BF H12 0120
    Revision: 00000000 Serial number: ”rˆ
    Coding: 0002682
    Part No SW: 4F0 910 801 B HW: 4F0 907 801 A
    Component: EPB CB4C0060 H04 0060
    Revision: --H04---
    Coding: 0000321
    VCID: 1F4D05F7CE4807E68D9-804A
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 M HW: 4F0 035 541 H
    Component: TUNER EU/US/RDW H42 0570
    Revision: 00000000 Serial number: 394H 067673418
    Coding: 0000001
    VCID: 2A5BE423850AF24EEA7-807F
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: J0644 BEM H12 0590
    Revision: 00000000 Serial number: 00000000090026
    Shop #: WSC 00539 210 08758
    Subsystem 1 - Part No: 4F0 915 105 D
    Component: von VA0 2608040502
    Coding: 344630393135313035442056413032363038303430353032
    Shop #: WSC 00000 384 00290
    Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
    Component: TSG HL H21 0050
    Coding: 0002090
    Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
    Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
    Component: SDS 3502 UK H45 0630
    Revision: 00000000 Serial number: 00000606210017
    Shop #: WSC 12336 024 394758
    VCID: 3663C05341B2A6AE7EF-8063
    Cannot be reached
    Cannot be reached
    Address 77: Telephone Labels: 4E0-910-336.lbl
    Part No SW: 4E0 910 336 M HW: 4E0 862 335
    Component: Handyvorb2 H13 1130
    Revision: 00000000 Serial number: 00000007566099
    Coding: 0010900
  9. Re: A6 saloon facelift conversion problems
    Sep 2015
    widnes uk
    Sorry I have no idea how this works or what it means
  10. Re: A6 saloon facelift conversion problems
    Jul 2013
    76 Post(s)
    You need to get the component protection removed on the 09 central convience module.
    Then do the correct coding for the modul and the basic setting.
    Dan
    2009/2010 2.0 TDIe SE
  1. Please Help Facelift bumper conversion brackets?
    By jake4321 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-01-2015, 05:17 AM
  2. Question Facelift Boot Lid on 2008 8 saloon?
    By Boy in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-10-2014, 03:16 PM
  3. ET35 wheels on facelift A6 Saloon?
    By Aleung2 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-02-2014, 07:53 PM
  4. Facelift conversion
    By Mo123456 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-03-2011, 12:17 PM
  5. facelift conversion
    By b5 meatball in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-06-2008, 09:08 PM
