Thread: 2006 Audi A4 B7 1.9TDI BRB Engine
  1. Lightbulb 2006 Audi A4 B7 1.9TDI BRB Engine
    Jan 2012
    Cork,Ireland
    Hello all
    First post for myself here.
    I recently bought an Audi A4 B7 with the what I am told is the more reliable engine (1.9tdi)
    the car has 100k miles which is excellent for its year and serviced with premium parts always
    I recently have had a steam train like car than a diesel run around.
    the car when running pours out the coolant and pushes steam out the back for 5-10 ft.
    The head is fine there is no overheating. full power, starts effortlessly etc etc
    From speaking to people i have been pointed towards the egr cooler which i am inclined to get rid of due to the failure rate.
    What would be the issues if i connected the feeder pipe and return pipe together. Engine runs poorly? Long term effects?
    I intend to leave the egr and not blank off. Is this doable without a cooler?
    PS cold air no hot air from the matrix since.
    thanks
    paul
  2. Re: 2006 Audi A4 B7 1.9TDI BRB Engine
    Pembrokeshire
    22 Post(s)
    bypassing the cooler is acceptble to rule it out as the fault, or confirm it is faulty. you can pressure test them as well. as for running without it, why would you, its there for a reason. its part of the egr system so either bin the whole egr system or fit a new cooler . incidentally, if you do find its faulty, you would then get exhaust gas leaking out the ends where there was coolant pipes, so these would also need blanking off.
  3. Re: 2006 Audi A4 B7 1.9TDI BRB Engine
    Jan 2012
    Cork,Ireland
    Thanks for the info. Going to try get this tested and today or over the weekend and see if this is the issue. Airing on the side of replacing it and leaving egr in situe
    When replaced would it be worth assuming the heat from the aircon will return?
    thanks for your help
  1. Audi A3 1.9TDI 2006 engine fault codes
    By akhurshid in forum 1.9TDi - Engine
    Last Post: 09-10-2015, 10:27 AM
  2. Audi A4 1.9tdi 2006 b7
    By Nav5587 in forum New Member Introductions
    Last Post: 20-07-2015, 10:03 AM
  3. A4 1.9tdi 2007 BRB not starting after new camshaft fitted
    By beeswax in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-04-2015, 12:27 AM
  4. 2006 1.9TDi 115BHP (BRB) A4 Avant Poor MPG
    By gcon45 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-10-2012, 09:51 AM
  5. Question Known faults of the 1.9 TDI engine with the BRB code and other questions...
    By Dejc in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 27-06-2012, 12:02 PM
