Thread: 2006 Polo BKY Engine Help
  1. 2006 Polo BKY Engine Help
    South Molton, Devon
    Hi folks
    I bought my daughter a 2006 Polo 1.4 16v Auto with a dodgy engine with 97k on it, anyway it turned out to be low compression so a used replacement was sourced and old one removed only to find the BKY engine sent is for a manual which is different to the BKY Auto engine (Thanks VW) anyhoo I cant send it back so am stuck with it till I sell it.
    So I was thinking of rebuilding the existing engine but cannot find spec/tolerances anywhere
    Can anyone help?
    I got a bore gauge on the bores and they seem Within a reasonable amount of the original but I cant find any info on what specs are acceptable
    Plan is to hone out the bore and fit new rings and oil pump, altho I did read something that Crasher put up that these engines are allready a bit sloppy on the cylinder specs so maybe a rebore and + size pistons maybe in order
    Any info or help appreciated
  2. Re: 2006 Polo BKY Engine Help
    Oct 2015
    GB
    What is different on it?
    Thought all you would have to do is change the clutch etc on the manual to the original torque convertor to the new engine...
    Sent from my SM-A300FU using Tapatalk
  3. Re: 2006 Polo BKY Engine Help
    South Molton, Devon
    Different Block castings
    Starter mounts on rear on the Auto and at the front on the Manual and the Block castings allow for that
  4. Re: 2006 Polo BKY Engine Help
    Oct 2015
    GB
    Oh yea I see what you mean now, just had a look on Google.
    Typical vw lol
    Is it possible to change over the bell housings??
    The other thing is, if you type in Google " transmission conversion plate" you may be able to source or have it made so the auto tranny will just bolt on to the new manual block.
    Might be worth a research aye...
  5. Re: 2006 Polo BKY Engine Help
    South Molton, Devon
    id rather just rebuild motor the I know itll last
  1. Replies: 0
    Last Post: 15-04-2015, 01:18 AM
  2. Question Hi All, 2006 VW POLO 9N BKY Suspected Ignition Coil failure
    By vwpolobky in forum New Member Introductions
    Last Post: 03-05-2014, 06:35 AM
  3. Please Help 2005 Polo 1.4 BKY - LTFT High, Running Rich, MPG down! O2 sensor reading?
    By Rob69 in forum Polo - Derby - Lupo - Fox
    Last Post: 28-03-2013, 09:56 PM
  4. Question VW Polo 2006 1.4 plastic engine cover removal?
    By Buzzoff in forum Polo - Derby - Lupo - Fox
    Last Post: 24-02-2013, 07:45 PM
  5. polo 1.4tdi 2006 engine mgt light on
    By barnacle in forum Polo - Derby - Lupo - Fox
    Last Post: 02-11-2009, 10:21 PM
