Thread: 1999 A4 2.5 v6 TDI Starter Location????
Results 1 to 10 of 11
  1. 1999 A4 2.5 v6 TDI Starter Location????
    Dec 2015
    Belfast
    Hi all,
    It seems my starter motor on my 1999 a4 2,5 v6 has givin up the ghost, how big a job is it to swap out and where is it located. Any help would be greatly appreciated. Thank you
  2. Re: 1999 A4 2.5 v6 TDI Starter Location????
    Sep 2008
    6 Post(s)
    I've not had the misfortune to do this job yet. From what I can determine, it's behind the radiator and fans at the front of the engine. You'll need to drop the lower engine plastic tray, remove the bumper and put it into service position to access. Quite an interesting video here for C6 2.0TDi (A6) but not removing bumper. Looks like more hassle than it's worth. Removing bumper is straight-forward and gives you proper access. Starter Motor Replacement and Alternator Removal Audi A6 C4 - YouTube
    This is a great site for general DIYs if you haven't come across it before. AudiDIY (Do It Yourself) Article Portal
    2016 BMW i3 REx (80k)
  3. Re: 1999 A4 2.5 v6 TDI Starter Location????
    Dec 2015
    Belfast
    Thank you spartacus 68, i'll have a look now, every mechanic I've mentioned it to has had a sharp intake of breath so hopefully its not as big a job as some where making out
  4. Re: 1999 A4 2.5 v6 TDI Starter Location????
    Dec 2013
    From - Walney Island, Cumbria, Live in: Larkhill, Wiltshire
    11 Post(s)
    Would have though you would be able to remove under tray and one of the front wheels and get to it through the corresponding wheel arch. It will sit either on left or right of engine at the seam between block and gearbox. Took me about an hour on a 1.9 Passat. No bumper off or anything. Just under tray and d/s wheel. Granted yours is the V6 but theoretically should be in a similar place? If not, ignore me.
    Mini
    Type your engine number into eBay and look at pictures, then you will see where it's at
  5. Re: 1999 A4 2.5 v6 TDI Starter Location????
    Dec 2013
    11 Post(s)
    Looking at pics, it's behind drivers side wheel arch. Same place as the 1.9s. Shouldn't be a huge issue to get out, probably a bit of wiggling to fit past driveshaft and suspension? On my 1.9 I had to unbolt AC compressor and rest it on a shoebox to give me room to pull starter out. Took me about 2 hours to remove it, rebuild it and put it back.
    Mini
  6. Re: 1999 A4 2.5 v6 TDI Starter Location????
    Dec 2015
    Belfast
    that was my original thought mini but I've had a poke around and can't see anything around there, i think the v6 is different but hey thats why I'm here, here to learn my friend thanks
  7. Re: 1999 A4 2.5 v6 TDI Starter Location????
    Dec 2013
    11 Post(s)
    That's a picture of the v6 mate. Same place as 1.9 on that. What's your engine number bud?
    Mini
  8. Re: 1999 A4 2.5 v6 TDI Starter Location????
    Dec 2015
    Belfast
    B5 mate, i think i just need to look a bit harder at what I'm doing to be honest, i had a quick poke around but the weather is not very favourable here atm so ill have to get it indoors and have another go,
  9. Re: 1999 A4 2.5 v6 TDI Starter Location????
    london/ UK
    What you guys don't see in that picture is the engine mount, exhaust manifold and alternator are very, very close proximity and it will not come out unless you take the alternator out or engine mount and exhaust manifold. I do put the car in the service position but it can be done by taking the exhaust manifold off- too much trouble though ! Starter is quite a big motta and it needs a bit of room before being persuaded to come out ! The wires are short as well and the exciter plugs on late models is a pain in the proverbial to remove due to crud getting in...
    0 3 0
  10. Re: 1999 A4 2.5 v6 TDI Starter Location????
    Dec 2013
    11 Post(s)
    That's fair enough. I have a gasaxe if that helps and at least you know where it is now.
    Good luck!
    Mini
  1. coolant temp sensor location 1999 a4 tdi avant 110bhp
    By jonnygfx in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-05-2012, 04:48 PM
  2. Starter motor location
    By jasper0407 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-02-2010, 03:11 PM
  3. starter motor location
    By justin31 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-01-2010, 01:38 PM
  4. a4 tdi 1999 fuse box location?
    By rob1976 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-10-2008, 07:33 PM
  5. Golf Tdi 1999 non starter
    By mistuart in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 21-05-2007, 10:03 PM
