Thread: B6 Passat Seized Rear Caliper
Results 1 to 10 of 11
  1. B6 Passat Seized Rear Caliper
    Jan 2015
    Antrim, Northern Ireland
    Hi guys,
    Bit of background - Tried taking off the electronic handbrake and got a "handbrake fault" message. Ran the diagnostics and got the fault code 02429 - Right Parking Brake Motor (V283) Clamping Force Not Reached.
    However I am nearly 100% sure it is the caliper has seized.
    I made an attempt to remove the caliper (using the VCDS (RossTech) to open the pistons etc) however it would not budge. The pads are low and needed changed so I am wondering if this has caused the piston to over extend? Also should I have done this even having existing fault codes?
    What are the options for taking off a seized caliper?
    At this stage I am considering cutting it off!!!
    I know this subject has been asked a million times, but any thoughts or guidance is greatly appreciated.
    Thanks in advance,
    Andrew
  2. Re: B6 Passat Seized Rear Caliper
    Sep 2008
    SE London
    I've put together the best bits seen in the interwebsphere about EPB failure in case it ever happened to me.
    PM me an email address for return attach
  3. Re: B6 Passat Seized Rear Caliper
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    You can unbolt the motor, lift it out of the way, minding the cable and use the hole at the back of the caliper (splined bit) to manually unwind it slightly until it is no longer clamping the piston from inside. Put the motor back on and see if it will retract under the basic settings procedure. If it still won't move then it is shot for sure and needs replacing.
    Mad Mitch
  4. Re: B6 Passat Seized Rear Caliper
    Sep 2008
    SE London
    Triple-square MT14 (aka Spline bit or XZN driver) needed + penetrating fluid
  5. Re: B6 Passat Seized Rear Caliper
    Jan 2015
    Thanks for the replies.
    Can I do this with the caliper still attached to the disc? Or can you only do this when the caliper is removed?
    I am happy enough to replace the caliper, just wondering if the above suggestion will work if the piston cannot be retracted and I can't get the caliper off.
    Thanks again.
  6. Re: B6 Passat Seized Rear Caliper
    Jan 2012
    10 Post(s)
    88 Post(s)
    The motor part is attached with 2 bolts and easy to remove. Unplug the connector and release the wiring from any clips then undo the motor bolts and withdraw. You will then see a fairly deep splined hole in the back of the caliper itself into which you can insert the matching male splined socket. Then undo to release the piston pressure on the disc.
    Mad Mitch
  7. Re: B6 Passat Seized Rear Caliper
    Jan 2015
    Thanks Mitch, appreciate the comments.
    I was going to go with the following process:
    - Use the VCDS to open the piston (as per this link)
    - Remove the caliper. If the caliper won't come off, remove the motor as above and manually wind back the piston
    - Replace the brake pads and caliper
    - Use VCDS to close the piston again
    - Run test/diagnostics again
    Anything else anyone would add or any tips/hints?
    A couple more questions:
    1. Do I replace both brake pads and then close the piston? Or replace one, close the piston, open the piston, replace the other side then close the piston again?
    2. I am getting the "Clamping force not reached" fault. Would that make sense to get that fault from a seized caliper? I am thinking the piston has overextended due to the pads being low.
    Thanks again,
    Andrew
  8. Re: B6 Passat Seized Rear Caliper
    Jan 2012
    10 Post(s)
    88 Post(s)
    Replace both sides then close and perform a brake function test with VCDS. Follow the instructions on the Ross Tech site for changing brake pads on a 3C with EPB.
    Mad Mitch
    1 1 0
  9. Re: B6 Passat Seized Rear Caliper
    Sep 2008
    SE London
    If manually opening caliper, as Mitch mentioned earlier, do not turn more than one turn -- otherwise the close and re-setup programs run by VCDS will not be able to reset to the correct distance between your replacement pads and disk.
    The low pads' warning that comes up on the dash is only measuring your front nearside pad thickness remaining. I've not heard of low rear pads, even if they're down to the rivets, being outside the tolerance for caliper operation or the EPB. But if they're down to the rivets then your disks will probably be damaged
  10. Re: B6 Passat Seized Rear Caliper
    Jan 2015
    Thanks again RichardSEL.
    Hopefully last question.
    When I have changed the brake pads and replaced one of the calipers is it just a case of closing the pistons? Do I need to tell the computer it is a new caliper or do I just go ahead and close it with the VCDS? Probably over thinking the process!!
    Andrew
  1. Please Help NS Front Brake not working, though caliper not seized
    By leeoz in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-04-2012, 05:43 PM
  2. caliper seized
    By mark78 in forum Superb
    Last Post: 07-03-2011, 03:52 PM
  3. Passat B6 rear caliper seized
    By Bowelman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-02-2011, 09:19 AM
  4. Polo brake caliper bolt seized
    By trevh in forum Polo - Derby - Lupo - Fox
    Last Post: 11-08-2007, 12:23 PM
  5. Polo brake caliper seized
    Last Post: 04-08-2007, 07:50 PM
