Thread: A pillar trim removal
  1. A pillar trim removal
    Jan 2012
    Rotherham/uk
    Has any body removed the a pillar interior trim on a 2007 a6. Need to remove it to hide a wire.
  2. Re: A pillar trim removal
    46 Post(s)
    Pull and slide, it's quite tight so requires a bit of force. You'll not break it.
  3. Re: A pillar trim removal
    Nov 2012
    Somerset UK
    Not quite true, you may break one of the metal pins as I did, this happened when advised A pillar trim needed to be removed to access ABS wiring loom...when it doesn't
  4. Re: A pillar trim removal
    Jan 2011
    Stafford, UK
    Quote Originally Posted by Bodkin40 View Post
    If you just want to get a wire behind the A pillar, you can just take the trim from behind the door rubber and feed your wire behind it, then tuck the trim back behind the door rubber.
    You can do the same with the roof lining,
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
  5. Re: A pillar trim removal
    46 Post(s)
    Quote Originally Posted by MarkTM View Post
    Worked for me on the old A6, my A3 and now A4.
  6. Re: A pillar trim removal
    It may be worth grabbing a trim removal kit too - just in case, much easier than fingers getting trapped and cut (it happens) and they're <£10 depending on the kit you get.
  7. Re: A pillar trim removal
    Jan 2012
    Rotherham/uk
    Thanks all. Gunna feed wire behind than try an get it off. Thanks for replies
  1. Removing C-Pillar Trim
    By Westyfield2 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 27-09-2014, 06:58 PM
  2. How To Removal of gloss black door pillar trim
    By rosco in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-02-2013, 01:03 PM
  3. Question A4 B7 B Pillar Trim removal?
    By phil. in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2011, 05:37 PM
  4. B pillar trim
    By Vapper in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-11-2008, 04:39 PM
  5. B pillar trim removal 1999 A4 1.9 TDi
    By fantasiagreen in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-06-2008, 12:03 PM
