Thread: Radio works, CD works, No sound. MOST Bus?
  1. Radio works, CD works, No sound. MOST Bus?
    Nov 2015
    Sweden
    Hello!
    I have a problem with my sound system
    Audi A6 2.4 2005 year model
    MMI Basic Plus
    The radio / MMI / CD works but i get no sound from the speakers.
    Sometimes when i start the MMI the screen lights up and then goes black and starts again.
    I can play cds, i can see the seconds go up.
    I have read a bit about the MOST Bus.
    I disconnected the optical cable going to the amp
    When i turn the ignition on i can see a red light from the optical cable but after a couple of seconds it flashes and then goes out.
    Is the red light supposed to light up all the time?
    I suspect that their might be a glitch in the optics so thats why it flashes and then goes out. What i have read so far is that the amplifier is the last unit in the ring?
    So the next step i thought would be to disconnect CD changer and see how the optics behave when it is disconnected.
    This fault has been for 2 years, the workshop hasnt been able to find the problem.
    Kind regards
    Kevin
  2. Re: Radio works, CD works, No sound. MOST Bus?
    Mar 2013
    Lincolnshire
    Are you able to scan your car with VCDS?
    A6 2008 57 Reg 2.7TDi SE Tiptronic Avant Quattro
  3. Re: Radio works, CD works, No sound. MOST Bus?
    Nov 2015
    Sweden
    On the paper from the workshop it says, no communication with MMI
    Faultcode on the optical bus
    Coding not possible
    Errors in MMI, Device: Interfacebox
    0412, 00a HU not coded
    0525, 04 Cluster ctrl
    0824, 05a CompProt no co
    082F, 00a ComProt active
  4. Re: Radio works, CD works, No sound. MOST Bus?
    May 2014
    Darlington
    78 Post(s)
    Looks like Component Protection is active, you will need to get that removed by an Audi dealer, then you will get sound.
  5. Re: Radio works, CD works, No sound. MOST Bus?
    Nov 2015
    Sweden
    It has been to the audi dealer, can it be that they cant erase it due to a faulty unit?
  6. Re: Radio works, CD works, No sound. MOST Bus?
    May 2014
    Darlington
    78 Post(s)
    Then the only option is to get the part number off the current unit and have a look on ebay for a replacement. When you fit the replacement unit component protection will be active on the replacement so will require a trip to the dealer.
  7. Re: Radio works, CD works, No sound. MOST Bus?
    Nov 2015
    Sweden
    Optical test:
    Optical Bus Diagnostic : Standard
    Controller Electrical Optical
    19-CAN Gateway OK OK
    07-Control Head(Std Plus) OK OK
    0E-Media Player 1 ERROR ERROR
    47-Sound System OK OK
    56-Radio ERROR ERROR
    Adress Autoscan
    Address 07: Control Head Labels: Redir Fail!
    Part No SW: 4F0 910 729 J HW: 4F0 035 729 D
    Component: MMI Cockpit H35 0040
    Revision: C51100DE Serial number: AUZ6Z3E1BD1022
    Coding: 0000000
    Shop #: WSC 00000 000 00000
    VCID: 306B14F3D8E3
    Part No: 4F0 910 609 B
    Component: Bedienteil MMIC6H07 0010
    3 Faults Found:
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 254
    Time Indication: 0
    02084 - Component Protection
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 5
    Mileage: 176664 km
    Time Indication: 0
    Date: 2015.09.23
    Time: 00:17:58
    02095 - Component Protection Active
    000 - -
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Mileage: 179599 km
    Time Indication: 0
    Date: 2015.12.02
    Time: 17:20:28
    _______________________________________
    Address 0E: Media Player 1 Labels: Redir Fail!
    Coding: 0000000
    VCID: 306B14F3D8E3
    No fault code found.
    Address 19: CAN Gateway Labels: 4F0-910-468.lbl
    Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
    Component: Gateway H09 0030
    Revision: 09 Serial number: 0800804C110039
    Coding: 6DEE73C41B0104
    Shop #: WSC 02325 785 00200
    VCID: 2759FFAFED2D
    2 Faults Found:
    00384 - Optical Databus
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 231
    Mileage: 178941 km
    Time Indication: 0
    Date: 2015.11.20
    Time: 10:02:38
    000 - -
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 20
    Reset counter: 208
    Mileage: 178979 km
    Time Indication: 0
    Date: 2015.11.21
    Time: 19:31:06
    Address 47: Sound System Labels: 4F0-910-223-AS.lbl
    Part No SW: 4F0 910 223 B HW: 4F0 035 223
    Component: Amp.-ASK H09 0270
    Revision: 16S00001 Serial number: 01512040055593
    Coding: 0000004
    Shop #: WSC 02335 785 00200
    VCID: 1D35DD47BF71
    Address 56: Radio Labels: Redir Fail!
    Coding: 0000000
    VCID: 306B14F3D8E3
    By Kev85 in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 29-11-2015, 10:21 PM
  2. Radio works, CD works, No sound. MOST Bus?
    By Kev85 in forum In Car Entertainment
    Last Post: 29-11-2015, 10:17 PM
  3. Please Help 99 Cabrio - fan only works at highest speed; A/C only works in sppeds 1-3
    By yueli831 in forum Golf MK4 - 1999 - 2004
    Last Post: 29-11-2009, 09:26 AM
  4. Radio works but no CD player
    By witm in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 04-06-2009, 12:42 PM
  5. Radio only works with strong radio signals
    By RJS_90q in forum Audi A3 - Archive Topics
    Last Post: 25-02-2007, 07:47 PM
