Thread: Multiple cylinder misfire on 2006 1.4 BBZ engine
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. Multiple cylinder misfire on 2006 1.4 BBZ engine
    warp_speed Guest
    Looking for some advice. I've got a SEAT Ibiza (56 reg) 1.4 with BBZ engine and its recently came up with the engine management light flashing. Plugged in the VCDS and it came up with multiple cylinder misfire detected with fault codes for cylinder 1, 3 and 4. I've changed the coil pack on cylinder 3 to see if it would help the situation but no change, group 14 and 15 shows multiple counts of misfire across all 3 cylinders. Any other ideas what this could be.
  2. Re: Multiple cylinder misfire on 2006 1.4 BBZ engine
    Oct 2005
    The ignition leads run in the grove of the engine cover which often causes them to deteriorate - Edit: I may be talking crap here, I might be thinking of the Polo 1.4 MPI not the BBZ in the 1.4 16v Ibiza (I have both vehicles!). The next part will work regardless though, it'll hopefully eliminate the leads being an issue.
    Making a note of which lead goes where, remove the lead from #2 and swap it with one that you know is misfiring.
    See if the misfire moves.
  3. Re: Multiple cylinder misfire on 2006 1.4 BBZ engine
    warp_speed Guest
    Quote Originally Posted by Sam View Post
    It has coil packs, no HT leads. But have checked the wiring to the coil packs and they look ok.
  4. Re: Multiple cylinder misfire on 2006 1.4 BBZ engine
    Oct 2005
    I'm confusing my vehicles, apologies.
    You say you changed the coilpack on #3 but not the others. For the sake of £30 it might be worth changing all 4.
    When was it last serviced, how old are the plugs and finally what were the exact codes stored?
  5. Re: Multiple cylinder misfire on 2006 1.4 BBZ engine
    Pembrokeshire
    22 Post(s)
    i would try some new sparkplugs as well.
  6. Re: Multiple cylinder misfire on 2006 1.4 BBZ engine
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Compression test maybe worth doing if no joy with plugs and packs.
  7. Re: Multiple cylinder misfire on 2006 1.4 BBZ engine
    warp_speed Guest
    Quote Originally Posted by Rob69 View Post
    Next on my list of things to do, any idea on what the compression value should be?
  8. Re: Multiple cylinder misfire on 2006 1.4 BBZ engine
    Pembrokeshire
    22 Post(s)
    a petrol should be around 150 - 180 ish, but what you want are even compressions across all 4. if one or more are 20 psi out, then you have found a potential problem.
  9. Re: Multiple cylinder misfire on 2006 1.4 BBZ engine
    warp_speed Guest
    Serviced around 5 months ago. Plugs changed around 20k and I used a standard handheld scanner (VCDS laptop not available at the time) and it reported misfire on cylinder 3, hence got a coil pack for it (£43 at TPS). Got home and connecting up VCDS it reported the following fault codes.
    P0300 16684
    P0303 16687
    P0304 16688
    I checked out group 14 and 15 of VCDS and it showed multiple misfire counts across cylinders 1, 3 and 4, nothing for 2.
  10. Re: Multiple cylinder misfire on 2006 1.4 BBZ engine
    Pembrokeshire
    22 Post(s)
    20k on a set of plugs, change them..
  1. Engine misfire(2006 A4 petrol)
    By BTW in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-06-2014, 12:08 PM
  2. Replies: 28
    Last Post: 30-10-2009, 02:12 AM
  3. Multiple Cylinder Misfire
    By CYLax in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-11-2008, 10:49 PM
  4. Multiple cylinder misfires! (Random)
    By AndrewB648 in forum Golf MK4 - 1999 - 2004
    Last Post: 10-05-2008, 09:34 PM
  5. Random/Multiple Cylinder Misfire Detected
    By mercaudi40 in forum A8 - S8 - V8
    Last Post: 23-01-2008, 05:46 PM
