Thread: Replace the roof aerial
Results 1 to 8 of 8
  1. Replace the roof aerial
    Oct 2015
    Cork, ireland
    Hi all,
    First time poster, long time Golf MK5 owner.
    I have a red MK5 golf.
    I'm looking to replace the roof aerial and was thinking of a "shark" type aerial similar to what you see on most BMWs.
    Does anyone know where I could pick up a red one online that matches the car colour? Or if there are other styles I could consider?
    Thanks!
  2. Re: Replace the roof aerial
    Kinross Scotland
    Depending on the year and spec of your car you may have an amplified "beesting" antenna, where the amp is in the base on the roof, this is for your FM/AM signal.
    Replacing it with a sharks fin antenna will probably seriously degrade your signal to the H/U.
    Most cars with sharkfin antenna have their FM antenna in the rear screen or side windows in the back.
    You can get lots of them on ebay and you can spray paint them easily.
    Do not trust 3rd party units that say they are amplified as you will just be throwing your money away. They do not work.
    Tiguan 2.0 4Motion 140PS 01/07/2013
  3. Re: Replace the roof aerial
    Oct 2015
    Cork, ireland
    Quote Originally Posted by richard@thebrae View Post
    Thanks. I just bought this. Not bad to test it out for around a tenner.
    Genuine Replacement CAR Roof Shark FIN Aerial Antenna Mast VW Golf MK4 MK5 | eBay
  4. Re: Replace the roof aerial
    Kinross Scotland
    No harm in giving it a go, but two things 1)you will need a power supply up to the sharksfin (oem unit the power comes up the antenna lead) and 2) the connector will need a iso to fakra adapter
  5. Re: Replace the roof aerial
    Oct 2015
    Cork, ireland
    Eeeek.
    Is getting a power supply to it a major job? Could I somehow use the existing power from the current aerial?
    Is this the adapter needed?
    http://www.ebay.co.uk/itm/Vokswagen-...8AAOSwgQ9VzIb2
  6. Re: Replace the roof aerial
    Kinross Scotland
    TBH I do not know if you can tap off the current lead, and you could accidently damage the HU while experimenting not worth the risk in my opinion.
    To provide a supply look at getting it off the live side of the rear interior light, but fit an inline fuse where you can get at if required (behind the light unit) this supply might be constant live and you might need to swop it to an ignition controlled feed at the fuse box. Perhaps someone else can provide advice here.
  7. Re: Replace the roof aerial
    Chinnor, South Oxfordshire
    Just get a replacement aerial for the golf on ebay. Costs very little and just unscrew the old one and screw in the new one. If you want, spray it red!
  8. Re: Replace the roof aerial
    Nov 2014
    Meppershall Beds.
    Quote Originally Posted by KeithS View Post
    think I paid about £2 for a replacement stick aerial for my daughter's GT Sport. took 30 seconds. Shark's fin type WAY too much hassle
  1. Cabriolet Power roof not Working / Electric aerial extended -stops roof from lowering
    By Q7quattro in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-02-2014, 05:06 PM
  2. Roof aerial
    By D.I.L.L.I.G.A.F in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-09-2010, 11:17 AM
  3. A3 roof aerial
    By huzarm in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 08-04-2010, 09:28 AM
  4. Roof Aerial
    By jonburt88 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-09-2009, 09:28 AM
  5. Please Help Gps Not Working, Aerial Replace
    By loopie6 in forum In Car Entertainment
    Last Post: 20-10-2008, 04:59 PM
