Thread: MK4 Loss of power
Results 1 to 9 of 9
  1. MK4 Loss of power
    Oct 2015
    South Africa
    Hi all
    Car: Golf 4 1.6sr 2004
    I am experiencing a loss of power with my mk4. while my foot is on acceleration it would loss power and car will idle funny. like a judder sound. Its gotten to a point where the idle will drop till the car switches off. If I leave the car off for a while then the issue will be gone for a while.
    All that's been done:
    Head gasket fixed
    spark plugs replaced
    cleaned throttle body
    front exhaust box
    sensor above exhaust replaced
    and issue persisted, my 'mechanic' said he doesn't know what's wrong.
    I had the same issue quite some time back and a sensor was replace but not sure which 1.
    Please advise if possible
  2. Re: MK4 Loss of power
    Sep 2009
    London/Bucks England
    Would recommend scanning the car, sounds like crank position. Did you disconnect your TB while cleaning it?
    Coil pack perhaps. Scan scan scan, saves a fortune replacing random parts. These aren't only mechanically driven vehicles. The ecu is there to log faults and operate the machine
    151 PS @ 3800 rpm 1.6 8V MPi - 31.5mpg urban <-- Happy days
    123k On the clock and counting. (25k on the block)
    I need all your V-Powers.
  3. Re: MK4 Loss of power
    130 Post(s)
    1972 Post(s)
    What is the cars engine type code?
  4. Re: MK4 Loss of power
    Oct 2015
    South Africa
    engine code: AKL
  5. Re: MK4 Loss of power
    130 Post(s)
    1972 Post(s)
    I thought, "AKL on a 2004, ***, ahhh, Süd Africa!"
    What fault codes keep coming back?
  6. Re: MK4 Loss of power
    Oct 2015
    South Africa
    I must still get a diagnostic test done.
    The hall sensor was replaced in 2007.
    What are the life expectancy of this sensor?
    And what are the chances it is the cause?
  7. Re: MK4 Loss of power
    130 Post(s)
    1972 Post(s)
    The camshaft hall sender?
  8. Re: MK4 Loss of power
    Oct 2015
    South Africa
    yes the camshaft hall sensor
  9. Re: MK4 Loss of power
    130 Post(s)
    1972 Post(s)
    They are a well known problem on the AKL but which variation of the code are you getting?
    00515 Hall sender -G40. No signal or 00515 Hall sender -G40. Implausible signal
  1. Please Help Power loss on mk4 tdi
    By stan still in forum Golf MK4 - 1999 - 2004
    Last Post: 11-07-2016, 08:30 PM
  2. Please Help 1999 mk4 golf 1.6 - power loss
    By azza in forum Golf MK4 - 1999 - 2004
    Last Post: 26-10-2015, 10:09 AM
  3. Please Help Loss of power> smokey > then no smoke or power at all!! (VW Mk4 GT TDI 130)
    By v15hal in forum Golf MK4 - 1999 - 2004
    Last Post: 24-08-2012, 07:24 AM
  4. Another Power Loss Problem on a MK4 GT TDI 150
    By Saucy in forum Golf MK4 - 1999 - 2004
    Last Post: 21-08-2008, 03:24 PM
  5. golf mk4 loss of power... help please
    By tannerzxr in forum Golf MK4 - 1999 - 2004
    Last Post: 06-09-2007, 04:41 PM
