Thread: Allroad rear brakes binding after new discs and pads
  1. Allroad rear brakes binding after new discs and pads
    Oct 2015
    Edinburgh
    Hi there. I'm wondering if anyone has an idea what could be causing my N/S rear brakes to be binding slightly after new discs and pads all Roy d the car. I rewound the Piston back in as I should. All the others wheels seem fine but this on is hot. This is the first time I've had it out since the change. Can't really see what I could have got wrong.
  2. Re: Allroad rear brakes binding after new discs and pads
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    did you get the pad carrier brackets nice and clean before fitting the pads or where they tight to get in? might be the pads jammed in position after first brake application.
  3. Re: Allroad rear brakes binding after new discs and pads
    Oct 2015
    Edinburgh
    Yeah it could be that .. I certainly didn't check and yes they were tight .. I'll check in the morning when I see what s going on.
  4. Re: Allroad rear brakes binding after new discs and pads
    Nov 2011
    Duns Scotland
    11 Post(s)
    You should always remove the two slider pins on the caliper, clean them up and re-coat with a little anti-corrosion grease and re-seat them. Also clean up the two rubber grommet at either end of the pins. With the pads out and the caliper off the wheel, the slider pins should easily press in and pop back out (by themselves). If the pins are badly corroded, see an earlier post of mine for a link to a co who offer replacements.
  5. Re: Allroad rear brakes binding after new discs and pads
    Oct 2015
    Edinburgh
    Thanks for that. Yeah the pins were in great condition as were the grommets. I greased them up a little and they slid perfectly. I'm wondering if he handbrake mechanism could get itself jammed a little. I'll get the wheel off tomorrow and have a look.
  6. Re: Allroad rear brakes binding after new discs and pads
    Aberdeen
    63 Post(s)
    Might just be the pistons are getting older and are scored with grit getting in.
  7. Re: Allroad rear brakes binding after new discs and pads
    Oct 2015
    Edinburgh
    After some messing it turns out that the Pistons were just sticking a bit and after some WD40, rubber grease and a few pushes in and out and all is good.
  1. Polo Rear Drum Brakes Binding
    By DOILY in forum Polo - Derby - Lupo - Fox
    Last Post: 09-05-2013, 07:33 PM
  2. No brakes after new calliper, pads and discs
    By liamthecoder in forum Golf MK4 - 1999 - 2004
    Last Post: 04-01-2013, 10:57 PM
  3. Allroad - Binding Brakes
    By WesleyP in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-04-2010, 06:56 PM
  4. new brakes discs and pads
    By chrismac10 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-07-2009, 11:21 AM
  5. Caravelle T5 rear brakes sticking/binding!!
    By max5765 in forum Touran - Sharan - Caravelle
    Last Post: 21-07-2008, 12:23 PM
