Thread: Headlight wiring deterioration
  1. Headlight wiring deterioration
    Jul 2015
    BG
    Im sure that most of us have cracked isolation inside the headlights. I had BMW and Porsche with the same problem.
    How can I fix this stupid mistake made by the German law for biodegradable wiring isolation.
    Maybe cutting the wires, soldering and heat shrink will solve the problem? Is there any way to disconnect the cables from the connector in order to put heat shrink without cutting the wire? Do I have to open the headlight assembly (in oven), or only the plastic caps.
  2. Re: Headlight wiring deterioration
    Jul 2013
    76 Post(s)
    extract the pins out of the plug one by one, then put heatshrink over the wires.
    By the look of that the wiring has got hot and gone brittle.
    if it was me i would cut back the wires and put new terminals on them.
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: Headlight wiring deterioration
    May 2014
    Darlington
    78 Post(s)
    As above I think you have had a fault and it's caused the wiring to get hot. My A6 is a 2006 model and I've just had my headlights out and the wiring was fine.
  4. Re: Headlight wiring deterioration
    Nov 2012
    Somerset UK
    Zaf, it may also help if you were to add your model/engine/transmission/year to your signature strip so you don't have to remind those when posting
  5. Re: Headlight wiring deterioration
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Check with dealer that a repair wire/connector is available. This should have new connector filled with wires of the correct colour. I've had VAG tailgate repair connector/wires before - quite inexpensive . Damage looks confined to short length so repair conn./ wiring should be O.K. This makes for an easy quality repair - either use insulated in-line crimps or solder conns. + heat shrink tubing.
    Scrap yard supply of complete conn + wires ?
    Skoda Octavia II SE 1.9PD TDI
  1. Chrome Trim Deterioration
    By apole in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-03-2013, 02:37 PM
  2. headlight leveling wiring
    By hibbsy21 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-01-2012, 07:34 PM
  3. Headlight wiring - Tech help required
    By patzer in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-09-2009, 01:34 PM
  4. B6 alloy wheel deterioration
    By tom smith in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-09-2009, 12:54 PM
  5. Headlight Unit Wiring Connector
    By gregk81 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-02-2008, 12:09 AM
