Thread: Passat B6 nothing signal to the dashboard not start
Results 1 to 10 of 12
  1. Passat B6 nothing signal to the dashboard not start
    Sep 2015
    cameroon
    I erased the faults and there is always the problem that the car walk and suddenly she stopped and know nothing on the dashboard before I had a battery problem since I tried everything but nothing no signal at the dashboard so I do not know if it's just a diet or immobilzer or electronic steering column lock and Ignition Switch Start Stop because when I put the key is nothing and nothing signal on dashboard
    00-Steering Angle Sensor -- Status: Cannot be reached 1100
    01-Engine -- Status: Malfunction 1010
    03-ABS Brakes -- Status: Malfunction 1010
    15-Airbags -- Status: Malfunction 1010
    16-Steering wheel -- Status: Cannot be reached 1100
    25-Immobilizer -- Status: Malfunction 1010
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: Malfunction 1010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 1010
    56-Radio -- Status: Malfunction 0010
    Address 01: Engine Labels: 03G-906-016-BKC.lbl
    Part No SW: 03G 906 021 LR HW: 03G 906 021 AN
    Component: R4 1,9L EDC 000SG 9248
    Revision: --H06--- Serial number: VWZCZ000000000
    Coding: 0000071
    Shop #: WSC 05311 000 00000
    VCID: 7AF1834C35C446E
    2 Faults Found:
    005488 - Engine Start Blocked by Immobilizer
    P1570 - 000 - - MIL ON
    Freeze Frame:
    Fault Status: 11110000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 73032 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 01:07:44
    Freeze Frame:
    RPM: 1323 /min
    Speed: 3.0 km/h
    Load: 60.8 %
    Voltage: 10.18 V
    Bin. Bits: 11000100
    Bin. Bits: 11000000
    Bin. Bits: 00100001
    005441 - Fuel Pump Relay (J17)
    P1541 - 000 - Open Circuit
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 73033 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:23:15
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.39 V
    Bin. Bits: 11000000
    Bin. Bits: 0
    Bin. Bits: 00000000
    Readiness: 1 1 0 0 0
    Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
    Part No SW: 3C0 614 109 HW: 3C0 614 109
    Component: ESP 440 C4 H018 0001
    Revision: H018 Serial number: 0775076576
    Coding: 0013569
    Shop #: WSC 00241 378 100439
    VCID: DBBF66C81A3E1F6
    1 Fault Found:
    00778 - Steering Angle Sensor (G85)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 28
    Reset counter: 134
    Mileage: 73033 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:24:23
    Address 08: Auto HVAC Labels: 3C0-907-044.lbl
    Part No SW: 3C0 907 044 AF HW: 3C0 907 044 AF
    Component: ClimatronicPQ46 050 0505
    Revision: 00050005 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 65CBC030AC7AD96
    4 Faults Found:
    01317 - Control Module in Instrument Cluster (J285)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 5
    Fault Frequency: 5
    Reset counter: 175
    Mileage: 73033 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 01:13:37
    01299 - Diagnostic Interface for Data Bus (J533)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 3
    Reset counter: 175
    Mileage: 73033 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:01:06
    00229 - Refrigerant Pressure
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00110010
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 175
    Mileage: 73033 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 01:04:06
    00457 - Control Module for Network (J519)
    Freeze Frame:
    Fault Status: 00110100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 175
    Mileage: 73033 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 01:14:17
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
    Part No SW: 3C0 937 049 AD HW: 3C0 937 049 AD
    Component: Bordnetz-SG H52 2002
    Revision: 00H52000 Serial number: 00000006607083
    Coding: 00880F0700041A00470A00000F000000000959435C0001
    VCID: 6BDFB6084A9EEF6
    Subsystem 1 - Part No: 3C1 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer 250107 022 0601
    Coding: 00046997
    Shop #: WSC 05311
    10 Faults Found:
    00834 - Signal for Activation of Heated Rear Window
    009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00101001
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 175
    Mileage: 73033 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 12.60 V
    OFF
    ON
    OFF
    OFF
    OFF
    02071 - Local Databus
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 175
    Mileage: 73033 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 11.05 V
    OFF
    OFF
    OFF
    OFF
    OFF
    01516 - Terminal 30; Left
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 175
    Mileage: 73033 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 12.60 V
    OFF
    ON
    OFF
    OFF
    OFF
    02403 - Terminal 15 for Interior
    006 - Short to Plus
    Freeze Frame:
    Fault Status: 01100110
    Fault Priority: 2
    Fault Frequency: 11
    Reset counter: 135
    Mileage: 73033 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 12.50 V
    OFF
    ON
    OFF
    OFF
    OFF
    01049 - Supply Voltage Term 50
    006 - Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00100110
    Fault Priority: 1
    Fault Frequency: 3
    Reset counter: 175
    Mileage: 73033 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 12.60 V
    OFF
    ON
    OFF
    ON
    OFF
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 175
    Mileage: 1048575 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 12.55 V
    OFF
    ON
    OFF
    OFF
    OFF
    01330 - Central Control Module for Central Convenience (J393)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 175
    Mileage: 73033 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 12.50 V
    OFF
    OFF
    OFF
    OFF
    OFF
    00466 - Control Module for Steering Column Electronics (J527)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 254
    Reset counter: 135
    Mileage: 73033 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 10.80 V
    OFF
    OFF
    OFF
    OFF
    OFF
    00153 - Windshield Wiper Motor; Driver Side (V216)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 175
    Mileage: 73033 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 11.05 V
    OFF
    OFF
    OFF
    OFF
    OFF
    00927 - Terminal 30 (Right)
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 175
    Mileage: 73033 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 10.15 V
    OFF
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 3C0-909-605.lbl
    Part No SW: 3C0 909 605 M HW: 3C0 909 605 M
    Component: 0B AIRBAG VW8 031 2522
    Revision: 11031000 Serial number: 003B1P1B1DG$
    Coding: 0012354
    VCID: 30656164A3384CE
    2 Faults Found:
    00588 - Airbag Igniter; Driver Side (N95)
    001 - Upper Limit Exceeded - MIL ON
    01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
    009 - Open or Short to Ground - MIL ON
    Address 16: Steering wheel
    Cannot be reached
    Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
    Part No SW: 3C0 920 852 J HW: 3C0 920 852 J
    Component: KOMBIINSTRUMENT VD1 1614
    Revision: V0007000 Serial number: 00000000000000
    Coding: 0007105
    VCID: 2A51730C85E436E
    8 Faults Found:
    00446 - Function Limitation due to Under-Voltage
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 175
    Mileage: 73033 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:22:56
    00532 - Supply Voltage B+
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 175
    Mileage: 73033 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:22:56
    01314 - Engine Control Module
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 175
    Mileage: 73033 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:18:57
    01316 - ABS Control Module
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 175
    Mileage: 73033 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:18:57
    01321 - Control Module for Airbags (J234)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 175
    Mileage: 73033 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:18:57
    00473 - Control Module for Elect. Park/Hand Brake (J540)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 175
    Mileage: 73033 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:18:57
    00474 - Control Module for Immobilizer
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 175
    Mileage: 73033 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:51:34
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 175
    Mileage: 73033 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:51:35
    Address 19: CAN Gateway Labels: 3C0-907-530.lbl
    Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
    Component: Gateway 007 0040
    Revision: 00007000 Serial number: 0700C071240FB2
    Coding: 3D3D0C04C22002
    VCID: 21439420F8D2F56
    10 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 135
    Mileage: 73033 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:00:05
    02638 - Enabling Steering Column Lock
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 1
    Fault Frequency: 11
    Reset counter: 175
    Mileage: 73033 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:01:47
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 175
    Mileage: 73033 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:18:40
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 175
    Mileage: 73033 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:18:40
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 135
    Mileage: 73033 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:18:40
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 175
    Mileage: 73033 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:18:40
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 175
    Mileage: 73033 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:18:40
    00470 - Combination comfort Databus in Single Wire
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 175
    Mileage: 73033 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:41:22
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 175
    Mileage: 73033 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:51:35
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 175
    Mileage: 73033 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:51:36
    Address 25: Immobilizer Labels: 3C0-959-433-25.clb
    Part No SW: 3C0 959 433 AB HW: 3C0 959 433 AB
    Component: IMMO 043 0383
    Revision: 00043000 Serial number: 00000000000000
    Shop #: WSC 131005 319 2096127
    VCID: 6AD1B30C4564F6E
    Part No: 3C0 905 861 G
    Component: ELV 027 0380
    3C0905861G ELV 027 0380
    1 Fault Found:
    02825 - Supply Voltage for Electronic Steering Column Lock Motor
    Address 42: Door Elect, Driver
    Cannot be reached
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K1 909 144 L
    Component: EPS_ZFLS Kl.134 H07 1806
    VCID: 346D6D74572070E
    5 Faults Found:
    000 - - - Intermittent
    Freeze Frame:
    Freeze Frame:
    Freeze Frame:
    Mileage: 0 km
    Temperature: 23.0°C
    Voltage: 12.50 V
    Voltage: 12.30 V
    00625 - Vehicle Speed Signal
    Freeze Frame:
    Mileage: 0 km
    Temperature: 23.0°C
    Voltage: 12.50 V
    Voltage: 12.30 V
    Freeze Frame:
    Mileage: 0 km
    Temperature: 23.0°C
    Voltage: 12.50 V
    Voltage: 12.30 V
    Address 46: Central Conv.
    Cannot be reached
    Address 52: Door Elect, Pass.
    Cannot be reached
    Address 53: Parking Brake Labels: 3C0-907-801-53.clb
    Part No SW: 3C0 907 801 G HW: 3C0 907 801 G
    Component: EPB VD8HC005 013 0005
    Revision: 013
    Coding: 0000011
    VCID: 2649873C91FC12E
    3 Faults Found:
    00576 - Terminal 15
    012 - Electrical Fault in Circuit - MIL ON
    Freeze Frame:
    Fault Status: 11101100
    Fault Priority: 4
    Fault Frequency: 8
    Reset counter: 135
    Mileage: 73032 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:23:15
    Freeze Frame:
    Voltage: 12.32 V
    Count: 41
    01487 - System Function Test
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 4
    Fault Frequency: 3
    Reset counter: 175
    Time Indication: 0
    Freeze Frame:
    Voltage: 12.42 V
    Count: 152
    02443 - Control Head
    Freeze Frame:
    Fault Status: 11111100
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 135
    Time Indication: 0
    Freeze Frame:
    Voltage: 12.42 V
    Count: 40
    Address 56: Radio
    Cannot be reached
  2. Re: Passat B6 nothing signal to the dashboard not start
    130 Post(s)
    1972 Post(s)
    Pardon me for stating the bleedin obvious but I would say a flat battery judging by those codes.
  3. Re: Passat B6 nothing signal to the dashboard not start
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    Hard not to laugh sometimes...
  4. Re: Passat B6 nothing signal to the dashboard not start
    Sep 2015
    cameroon
    I put my key and nothing when I test no power reaches the level of the Director of Electronic Lock column
    I change the battery and when I put the key no signal on the dashboard I'd really consulting
  5. Re: Passat B6 nothing signal to the dashboard not start
    Sep 2008
    SE London
    Send me your email address. I will return with copy of my help .doc for Electronic Lock. Some parts you must buy from VW. Or if you have electronic skills two small micro switches. The repair means removal of steering column.
    Sorry, .doc not in French
  6. Re: Passat B6 nothing signal to the dashboard not start
    Sep 2015
    cameroon
    my mail garage.autocar@gmail.com
  7. Re: Passat B6 nothing signal to the dashboard not start
    Sep 2015
    cameroon
    the electric power output of which is red cable to power-CCM BODY COMFORT CONVENIENCE unable to Steering Column
  8. Re: Passat B6 nothing signal to the dashboard not start
    Sep 2008
    SE London
    You have eMail
  9. Re: Passat B6 nothing signal to the dashboard not start
    Sep 2015
    cameroon
  10. Re: Passat B6 nothing signal to the dashboard not start
    Norfolk
    ESCL has failed. No electrics will work while ESCL is in lock position. Move ESCL to unlock position and ignition will come back but engine will not start.
  1. Replies: 19
    Last Post: 13-01-2015, 09:15 PM
  2. Replies: 0
    Last Post: 17-11-2014, 04:33 PM
  3. Dashboard lights flashing on ignition, disappear on engine start
    By Steve- in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-05-2012, 12:38 PM
  4. 04 Passat Dashboard Indicator Lights
    By westerboyz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-01-2008, 11:30 PM
  5. 04 Passat Dashboard Indicator Lights
    By westerboyz in forum Passat - Archive Topics
    Last Post: 26-01-2008, 10:22 PM
