Thread: Engine Management warning light
Results 1 to 10 of 13
  1. Engine Management warning light
    Aug 2008
    Just got an amber engine management warning light come on, this was after an intermittent glow plug warning
    looking in the owners manual it gives " catalytic converter fault" This came on shortly after topping up with
    fuel, Yes it did come from the diesel pump Has anyone had this experience
    Passat Highline Plus 2.0 ltr tdi
    Cheers Mike
  2. Re: Engine Management warning light
    129 Post(s)
    1972 Post(s)
    It could be anything, you need a fault code scan to know why the light is on. What is the cars year and engine type code?
  3. Re: Engine Management warning light
    Sep 2008
    SE London
  4. Re: Engine Management warning light
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    Quote Originally Posted by mikegbingham View Post
    Cheers Mike
    Car details will help as would a VCDS (VagCom) scan report but to clarify the warning lights on a Tdi, the yellow glow plug preheating light is also a general engine fault light at any other time. The engine shaped yellow light is usually an engine emission fault warning light to do with exhaust gases.
    Mad Mitch
  5. Re: Engine Management warning light
    Aug 2008
    The Year May 2010 Engine Type CBA B
  6. Re: Engine Management warning light
    129 Post(s)
    1972 Post(s)
    From experience I would say you have a high probability of that being a simple faulty DPF pressure sensor. These are relatively cheap even genuine at £65 and very easy to change being on the upper rear right of the engine (the T30 bolt is awkward to get out though), apart from needing to be calibrated after fitting. The sensor changed slightly in late 2009 so it may be that your car was built a little earlier than you think and so you have the 076 906 051 A instead of the later 076 906 051 B. You can get these sensors cheaper from all sorts of places made by Bosch, Febi, Vemo etc etc and I keep the Febi ones in stock for £48.
  7. Re: Engine Management warning light
    Aug 2008
    [QUOTE=Crasher;977796]From experience I would say you have a high probability of that being a simple faulty DPF pressure sensor. These are relatively cheap even genuine at £65 and very easy to change being on the upper rear right of the engine (the T30 bolt is awkward to get out though), apart from needing to be calibrated after fitting. The sensor changed slightly in late 2009 so it may be that your car was built a little earlier than you think and so you have the 076 906 051 A instead of the later 076 906 051 B. You can get these sensors cheaper from all sorts of places made by Bosch, Febi, Vemo etc etc and I keep the Febi ones in stock for £48.[/QUOTE
    Thanks, Just been to local indi BOSCH to arrange scan, Their crystal ball suggested DPF may need a good blowout so I done just over 100 miles at 2500 to 3000 rpm, But it hasn't cleared problem.
    I will report the results of the code, and thanks for your suggestions
    Mike
  8. Re: Engine Management warning light
    129 Post(s)
    1972 Post(s)
    Didn't they do a scan before they told you that? If the DPF was at all blocked, it would specifically inform you of this on the dash.
  9. Re: Engine Management warning light
    Aug 2008
    No Can't get a scan for a few days
  10. Re: Engine Management warning light
    Jan 2012
    10 Post(s)
    88 Post(s)
    Once the warning light is active the car may not do the regenerations. Also your fuel level needs to be high enough as below a certain level the regenerations will not occur. If the active soot load reaches 55% of its limit the DPF light will illuminate (yellow rectangular exhaust back box shaped light). Any faulty part should be replaced and the fault codes should be cleared first before you try the "Italian Tune Up" otherwise may be a wasted exercise and wasted fuel.
  1. Please Help 2002 Audi A4 1.8t Oil warning light after 5 mins of driving then engine management light comes on
    By ScottyDoo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-09-2013, 01:02 PM
  2. Engine management warning light
    By andy boy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-01-2011, 09:57 PM
  3. Engine Management Warning Light
    By kerrian in forum VCDS - Help Requests
    Last Post: 03-06-2009, 02:53 PM
  4. A4 Engine Management Warning Light
    By ukdeluded in forum Audi A4 - Archive Topics
    Last Post: 04-12-2007, 08:18 PM
  5. engine management warning light
    By audi-nutz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-11-2007, 05:01 PM
