Thread: Flushing the Brake Fluid?
Results 1 to 10 of 13
  1. Flushing the Brake Fluid?
    Oct 2009
    Malvern
    Can I do a full Brake Fluid Flush of the system with out the need of any of this Computer Wizardry? Or do I need to take this to a dealer who has the computer software to enable Brake Fluid change? The car is due for a service but I'd much rather do it myself if I can :-)
    Audi A4 3.0TDI Q SE Lava Grey + B&O, Audi Drive Select, Sports Seats, Sun Roof, DVD Sat Nav Plus, Blue Tooth Phone Prep, Audi Hill Assist, Rear Parking Aid, Electric Seats, Light Pack, Audi Audio Interface, MMI etc... and 4 Halfords Bulbs lol....
  2. Re: Flushing the Brake Fluid?
    Pembrokeshire
    22 Post(s)
    you can doit without computer as long as you can do it without getting any air in. just pump 1/4 a litre through each caliper, keeping the resevoir topped up.
  3. Re: Flushing the Brake Fluid?
    Oct 2009
    Malvern
    Thanks mate, I was hoping you were going to say that :-) I just replaced my Front Discs and Pad on my Renault Kango Van and bled the brakes myself with just a Jam Jar and a piece of clear tubing attached, so will do the same on the car as that needs it's fluid changed too :-) I was just a bit worried I might set of a brake alarm and then need a garage to reset some warning light?
  4. Re: Flushing the Brake Fluid?
    Jul 2015
    Staffs
    46 Post(s)
    Does that flush out the ABS pump too? DOT 5.1 ok to use?
    Ian
    A4 B6 Avant Nogaro Blue
  5. Re: Flushing the Brake Fluid?
    Pembrokeshire
    22 Post(s)
    yes, the fluid goes through the abs pump before the calipers. and yes, 5.1 is fine although dot 4 is more than adequate . in fact, dot 2 is enough for most peoples driving. the dot is just the boiling point of the fluid with 5.1 being the highest and suitable for track use. dot 5 is silicon and best avoided at all costs.
    1 1 0
  6. Re: Flushing the Brake Fluid?
    May 2014
    Darlington
    78 Post(s)
    I would stick with the genuine VW stuff unless you going to flush the clutch as well, as I would not mix the fluids. Just crack the bleed nipple off at each corner (one at a time) and let the fluid drip through.
  7. Re: Flushing the Brake Fluid?
    Pembrokeshire
    22 Post(s)
    any brake fluid is compatible with any brake fluid. keep to dot 4 and you will be ok. letting it drip works but can take a long time. either do that and have a cuppa for each wheel or buy an easibleed, or just do it the old fashoned way.
    1 1 0
  8. Re: Flushing the Brake Fluid?
    Oct 2009
    Malvern
    Well I just had a practice on my Renault Kango Van and it was a breeze, I used a method I found on YouTube using a Jar with a lid, drill a hole in the top fit a length of clear tubing, have a small air hole too, make sure the tubing reaches the bottom put a bit of the old fluid in the bottom to cover the pipe end. Make sure the tubing fits tight on the bleed nipple use a cable tie to make an air tight seal, place some grease around the nipple so once you open it air can't get back in through it's threads, then open the bleed value pump away slowly up and down about 5 times then top up master cylinder, repeat to you have expelled about 250ml fluid from each wheel, start at the one furthest away. Now my van brakes are rock solid :-) Time to do my Audi now :-)
    0 2 0
  9. Re: Flushing the Brake Fluid?
    Ardfern
    8 Post(s)
    Good luck with the bleeding.
    I have vcds and am local to you if you need it for other jobs.
    A4 B8 143 Tdi S Line Saloon 2008 (Gone)
    Lotus Elan SE 1991
    A4 B8 170 Tdi Quattro Technik Avant 2011
    A4 B8.5 143 Tdi S Line Black Edition Saloon 2013(gone)
    A4 B8.5 Allroad Sport Nav 2.0 tdi quattro 2015
  10. Re: Flushing the Brake Fluid?
    Oct 2009
    Malvern
    Cheers BOY
    What would you charge to reset the oil service indicator? As if I could do that I might have a go at doing my own oil service on my Audi? Do you know how accessible the oil filter is to change on the 3.0 DTI A4 model is, I assume I have to remove the underside shield to access the underside of the engine compartment?
  1. Question Brake fluid, coolant, powers steering fluid.... advise please
    By IlovemyVW in forum Golf MK4 - 1999 - 2004
    Last Post: 17-11-2013, 07:43 PM
  2. Replaced Brake fluid (bled system). Red Brake warning light appears!
    By keemaklan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-12-2010, 03:21 PM
  3. Brake Fluid
    By ddave05 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 31-07-2009, 08:58 PM
  4. Renew your brake fluid with OEM spec fluid!!!
    By cbrpaul in forum Chat - Anything with wheels
    Last Post: 01-10-2007, 01:54 PM
  5. brake fluid
    By clint in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-06-2007, 05:33 PM
