Thread: Dynamic lights cluster
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. Dynamic lights cluster
    Oct 2010
    Blackburn uk
    Could anybody tell me if the LED light cluster fitted on a 2015 A6 4G can be retrofitted with the dynamic light module available on the internet or are the dynamic light cluster fitted in the factory physically different ( although visually the same ).
    Many thanks
    Roger
  2. Re: Dynamic lights cluster
    Apr 2009
    Surrey
    179 Post(s)
    Quote Originally Posted by drrgriffiths View Post
    Many thanks
    Roger
    I believe they can and somewhere on here is a post of someone who did it, but if I recall correctly it cost several hundred pounds
  3. Re: Dynamic lights cluster
    Feb 2013
    Gloucester
    57 Post(s)
    Retrofit the matrix lights? That would be amazing if it works
  4. Re: Dynamic lights cluster
    Feb 2012
    Essex, innit.
    I think drrgriffiths is referring to the Dynamic Rear Lights, with the swoosh indicators. There are a couple of companies offering these as aftermarket options.
    The Matrix lights are a whole different kettle of fish. Their ECU is linked to your Sat Nav and they have sensors for detecting other vehicles in front (going in both directions and moving left to right). They also use the sat nav to detect the curve of the road. I'm sure it can be done but the cost would be eye watering. Fitting would be 'interesting' if the loom parts were missing.
    That said, they are truly incredible to drive behind
    A6 Bi Turbo (320PS) Black Edition, Techno pack, Matrix lights, heavy right shoe. Sept 2015.
  5. Re: Dynamic lights cluster
    Aug 2013
    18 Post(s)
    I thought the op meant the front too. Wasn't the dynamic light module was created for the rear? There would be no need to ask… or am I missing something?
    Anyway, if it’s for the rear then maybe someone with extensive experience of modding the original rear clusters and fitting the facelift units could advise. If only we had someone here like that
  6. Re: Dynamic lights cluster
    Feb 2013
    Gloucester
    57 Post(s)
    Haha, I've done the tears and love them. The front on the A7 are 2 grand per side, plus a new bumper (as they are a different shape) plus paint, plus and looms, coding etc (if it's even possible)
    Rears are easy though. Just plug and plau
  7. Re: Dynamic lights cluster
    Oct 2010
    Blackburn uk
    Hi, yes the dynamic light are the rear ones. My question is simply if the LED clusters fitted on a 2015 A6 that does not have factory fitted dynamic lights are the same ones fitted to a car that does. I have been in the process of purchasing the modules the update the light clusters to dynamic but have been advised to check they are dynamic capable.
    Regards
    Roger
  8. Re: Dynamic lights cluster
    Sep 2015
    Staplehurst, Kent
    Audi A6 Rear LED Lights & Dynamic Indicators | Advanced In-Car
    shows it's possible and fairly simple. But £££'s
  9. Re: Dynamic lights cluster
    Oct 2010
    Blackburn uk
    Ah, that's who I was getting the control units off but they've asked me to check the LED clusters are the right ones before they send them out as there none refundable !!
  10. Re: Dynamic lights cluster
    Apr 2009
    Surrey
    179 Post(s)
    OK I think the question you are really asking is whether the SE (static) and S-Line (dynamic) cars have the same rear light cluster. Key will be whether the LEDs for the indicators on the SE are wired as one or individually. I would suggest the easiest option (as Partsbase does not yet go up to 2015) is to ask someone in the dealer parts department to check if the part numbers for the 2 units are the same or different.
  1. Question Is there a way to disable dynamic turning lights on taillights on ne Audi A6
    By dzankou in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 26-12-2019, 01:58 PM
  2. Instramunt cluster lights
    By SteveEmz in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 09-07-2015, 10:40 AM
  3. A6 rear lights cluster replacement help.
    By tommyk19 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-05-2012, 06:52 PM
  4. Please Help a4 cluster lights
    By tbs in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-09-2008, 04:08 PM
  5. Sharan 1997 TDI Cluster Lights
    By hawkz_2002_uk in forum Touran - Sharan - Caravelle
    Last Post: 23-09-2006, 05:38 PM
