Thread: A3 2.0 tdi clouds of white smoke when accelerating
  1. A3 2.0 tdi clouds of white smoke when accelerating
    Aug 2015
    wales
    hello guys im new to audi just got a 2006 audi a3 2.0 tdi 140 sportback last month nice car to drive then after 2 weeks of ownership the timing belt tensioner went and destroyed the head so got a second hand head of a blb engine code mine is bkd and got the car back on the road the car was ruining a bit lumpy and over fuelling a bit but used as it was the mechanic hew done the head said it needed to be put on a computer and have the injector timing adjusted but iv bean using the car as it was and nw its started chucking clouds of white smoke out the exhaust under acceleration i am stuck now as to wat to do i have had the injector seals replaced injector stretch bolts replaced the glow plugs and the throttle body manifold flap i am stuck to wat hells this problem could the white smoke stinks of unbent diesel any help will be much appreciated thank you
  2. Re: A3 2.0 tdi clouds of white smoke when accelerating
    Aberdeen
    63 Post(s)
    White smoke is unburnt diesel or water. Probably over fuelling when accelerating.
  3. Re: A3 2.0 tdi clouds of white smoke when accelerating
    Pembrokeshire
    22 Post(s)
    turbo hose popped off maybe, which is likely if its all been apart. bet it had a new timing belt but some tightwad didn't want to fork out for a complete kit but was happy to pass it onto you.
  1. Trouble starting her, loss of power & clouds of grey smoke!!
    By VWVirgin08 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-01-2014, 01:18 AM
  2. PD150 Turbo issues, chugging and clouds of smoke.....not good
    By Disk0 in forum Golf MK4 - 1999 - 2004
    Last Post: 06-03-2012, 11:06 PM
  3. Please Help 1.8T Clouds of smoke when warm idling??
    By wmaiden in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-03-2011, 03:53 PM
  4. Question Clouds of Smoke !!
    By 200QT in forum 80 - 90
    Last Post: 26-03-2009, 01:36 AM
  5. 98 Passat 1.8T - Smoke Clouds - Why?
    By SilentBob in forum Archive posts
    Last Post: 17-06-2007, 05:59 PM
