Thread: Steering lock module program.
  1. Steering lock module program.
    Nov 2006
    derbyshire
    Hi. Need to replace steering column lock module but want to know if it will only be VW who can program/code it. If not does anyone know of people who can do it in chesterfield or Sheffield area. Thanks
  2. Re: Steering lock module program.
    Nov 2006
    derbyshire
    Hmm. Seems I'm the only one with this problem
  3. Re: Steering lock module program.
    Sep 2008
    SE London
    Quote Originally Posted by gresty View Post
    Depends on how you intend fixing the problem. If you change or get changed the two most likely components to have failed, the two micro switches, then no re-programing is needed. If you change the entire IMMO board at the bottom of the steering column then yes, it will have to be re-programed by VW which calls back data held in Germany. VW main agents have a fixed price deal for this, last I saw was £350. It was a free fix in n. America until July'13
    If you’re anywhere near Northampton, many have used this firm to fix their steering lock problem:
    http://www.ebay.co.uk/itm/PASSAT-B6-...-/261429296132
    And in Rainham, Essex RM13 8QT for the same price:
    http://www.ebay.co.uk/itm/STEERING-L...8f429420a8b85a
    See this thread:
    https://www.vwaudiforum.co.uk/forum/showthread.php/101776-Steering-Lock-See-Workshop-and-dealer-problem?highlight=steering%20lock
    Get a copy of my help .doc that tells more. PM me your email address for return attach
  4. Re: Steering lock module program.
    Nov 2006
    derbyshire
    Thanks for that. Have already removed steering lock from column and cable tied it up out of the way. Have bought a new unit but can always get refund if the repair works. Cheera
  5. Re: Steering lock module program.
    Nov 2006
    derbyshire
    Right. Had a go at lubricating mechanism inside lock module and having a general fiddle to make sure all contact are good etcetera. Refitted and was the same. So booked in with vertu vw in Mansfield who programmed new steering column module and programmed both keys for £120. I refitted the column module myself when got back home. So all in it cost £196 for new column lock module, programming and keys coding. Not too bad
  1. Program remote - only have one key and no door lock!
    By falcao in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-03-2015, 02:08 PM
  2. How to program a replacement ABS Controller & Setup G85 Steering Control Sensor???
    By Tecnic91687 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-01-2012, 10:56 PM
  3. Please Help Mk4 Golf Door Lock Module Microswitches
    By overthetop in forum Golf MK4 - 1999 - 2004
    Last Post: 19-08-2011, 02:10 PM
  4. Question How to program comfort control module for VW Passat
    By justscottish in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-01-2009, 07:59 PM
  5. Mk4 Door Lock Module
    By richjthorpe in forum Golf MK4 - 1999 - 2004
    Last Post: 28-11-2008, 03:30 AM
