Thread: Engine oil. What are you all using?
Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 66
  1. Re: Engine oil. What are you all using?
    #51
    Sep 2008
    SE London
    Quote Originally Posted by DMitch16 View Post
    I have used that before Vespa and put in the VW507 specification search which brought up 17 oils that meet the specification with the usual offenders listed Castrol Edge, Valvoline, Shell Helix, Fuchs, PETRONAS etc. Hence I have bought PETRONAS SYNPOWER AV 5000 from ECP at £24.99 / 4L with a free Bosch Oil Filter (worth a fiver). £25 for an oil change with really good stuff AND a filter???...that's a BargaFin - yes an F in Bargain!!
    Unfortunately, the promotion has "expired", according to ECP.
    With a consumption of 1L per 2,400 miles-ish I feel confident my Comma stuff won't suddenly turn to water.
    Nor will the Quantum III I'll be using next. But it'd be daft to go to a no-name soup at nothing-pence for a vat of the stuff.
    Long ago and far away I drove an Armstrong Siddley Lancaster (how much worth today?) Used to burn a sump full every two hundred miles or so. So used to use "commercial" grade. Whatever that was, it was rather thick. So much so had to park on a hill in winter and roll down to bump start. "Eeee y'don't know y'born, lad..." etc
  2. Re: Engine oil. What are you all using?
    #52
    May 2006
    Redruth, United Kingdom
    That's why I said most are hydrocracked. There are some that are group IV, but I'm not sure if there are any approved ones that are group V.
    Tim
  3. Re: Engine oil. What are you all using?
    #53
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    [QUOTE=DMitch16;973695]Read the Castrol Edge / Magnetec bottles anyone?
    One states "Meets or exceeds", the other just has the standards marked on it (so it meets but does not boast it exceeds the manufacturers specs), of which one is the VW spec. So our famous Castrol oil is not an APPROVED VW oil it seems but by reputation and endorsement is chosen by many...
    PS The Tesco VW oil is a "Meets or exceeds" type too.
    Castrol edge 5W-30 504/507 IS approved by VW ! This oil is even in my official VW Golf TDI handbook & is on the approved VW oil list !
    Castrol magnetic is NOT 504/507 VW approved and has never been labelled as such.
    Seems there is still a lot of confusion over oil specs !
    I'm amazed that my tongue in cheek comments about Supermarket oil specs were taken at face value - I only posted these to show how ridiculous some spec claims are !
    Skoda Octavia II SE 1.9PD TDI
  4. Re: Engine oil. What are you all using?
    #54
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    Here you go - VW do not publish an Approved list per se but a "Meets the Oil Quality Standards of VW" list. So called "approved" oils are therefore not technically approved but do meet their standards and are on the VW list (I have renamed this the "VW Recommended Oil List").
    http://my-gti.com/wp-content/uploads...ngine_oils.pdf
    This is not the most up to date list so is STILL not exhaustive but most of the oils are currently marketed.
  5. Re: Engine oil. What are you all using?
    #55
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Semantics ! It used to be called the VW approved oil list.
    Here is a later list- google "VW approved oil list 2015" - "www.anciravolkswagen.com/blogs/949/.../2015/.../Approved-Oil-List.pd..."
  6. Re: Engine oil. What are you all using?
    #56
    Sep 2008
    SE London
    Thanks for the list...
    Not only is Quantum Longlife III SAE 5W-30 listed by VW as meeting 504/507,
    it's also the best buy for serious-named engine oil at £27 for 5L
  7. Re: Engine oil. What are you all using?
    #57
    Jan 2012
    10 Post(s)
    88 Post(s)
    Quote Originally Posted by vwcabriolet1971 View Post
    Ha ha ha! Still only a list of "oils that meet..." ignoring the fact that an American franchise dealer has decided to name a VW TSB as an approved list on their web site.
  8. Re: Engine oil. What are you all using?
    #58
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    It's still an official VW bulletin.
  9. Re: Engine oil. What are you all using?
    #59
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    It's still an official VW bulletin and a much more up to date one at that . Ha Ha.
  10. Re: Engine oil. What are you all using?
    #60
    Jan 2012
    10 Post(s)
    88 Post(s)
    Ha ha ha!! Can't get more up to date than this...1997 to 2016
    READ: TECHNICAL SERVICE BULLETIN - AUDI * DeniaHauskauf.Com
    TSB 17 15 57 2010043/14
    All the standards listed are VWS.
  1. Replies: 5
    Last Post: 07-02-2012, 10:11 PM
  2. Please Help Engine Oil Pressure light, No engine fault codes on VAG COM
    By dfilogik in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 04-06-2010, 08:28 PM
  3. Question Correct engine oil for 2001 TDI Caravelle (AUF engine)
    By guidoping in forum The Commercial Range
    Last Post: 11-04-2010, 09:26 AM
  4. Replies: 2
    Last Post: 02-07-2008, 07:50 PM
  5. oil filter, oil pump. turbo or engine- You decide!!
    By jonny williams in forum Chat - Anything with wheels
    Last Post: 15-04-2008, 01:29 PM
