Thread: MAP sensor location
  1. MAP sensor location
    Jul 2013
    London
    Hi , I have looked but cannot find a picture of the MAP sensor on the engine or where it lives ! Any advice please , a photo or a map (pardon the pun) would be gratefully appreciated
  2. Re: MAP sensor location
    Jul 2013
    London
    Just realised the glaring error in this post !!
    Passat 2006 2.0 TDI 140 BKP ! Thanks
  3. Re: MAP sensor location
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    If you mean the G31 Charge Air Pressure aka Manifold Pressure aka Boost Pressure sensor it is located in one of the large turbo boost hoses at the front of the car. It is plugged into a hole in the hose and has a connector running into the loom under the oil filter housing or thereabouts. There are 2 small retaining bolts. It's easy to miss it as it is masked by other pipework etc. in that area and if viewed from underneath sits on top of the hose making it difficult to see.
  4. Re: MAP sensor location
    Jul 2013
    London
    Many Thanks !
  1. Please Help 17964 fault? MAP valve (N75) & MAP sensor location ??? how to check vac lines?
    By spadders in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-03-2015, 09:55 PM
  2. Replies: 0
    Last Post: 27-11-2013, 09:36 PM
  3. Question 2008 a3 tfsi s line map sensor / thrust sensor location..help
    By leigh76 in forum Chat - Anything with wheels
    Last Post: 22-07-2011, 09:44 PM
  4. Please Help 2008 a3 tfsi s line map sensor / thrust sensor location..help
    By leigh76 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-07-2011, 07:58 PM
  5. MAP Sensor location?
    By MikiebV6 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-12-2009, 05:41 PM
