Thread: Window alignment off after fitting new regulator
  1. Window alignment off after fitting new regulator
    Aug 2009
    Fraserburgh
    Sorry wrong forum area, she's a B7
    Hi folks, I fitted a new driver side regulator today, didn't even think there would be any problems with alignment as I couldn't see any way it would go askew with the securing points
    the window would only go down to start with, would not go up? cut a long story short, dismantled the sealed window switch unit and cleaned all connections, window working perfect now
    but I did notice a scraping noise as it would go up?
    Mrs was first to take the car out on the road, she came back and told me it was leaking as she could hear wind noise?
    I went out and heard it for myself, then checked the window, sure enough she is misaligned ( see photos )
    Any advice on how to correct this gratefully received
    Stuart
    Last edited by culnara; 02-07-2015 at 07:20 PM. Reason: wrong forum area should have been A4 B7
  2. Re: Window alignment off after fitting new regulator
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Go back into the door, loosen the clamps on the glass, push the glass back up to its correct parked position and then lock the clamp bolts again.Bit of a pain to open it all up again, but all you can do really
  3. Re: Window alignment off after fitting new regulator
    Aug 2009
    Fraserburgh
    Damn, I was going to slacken the bottom bolts and try it from there, thanks for the reply
  4. Re: Window alignment off after fitting new regulator
    Oct 2009
    10 Post(s)
    I did the regulator swap at Christmas on my 52 A4 cabriolet, basically if the motor has parked correctly at the top you just shove the glass home and lock it.
    I was a bit worried because the cabriolet has a drop function when the door opens, trying to gauge for the drop/raise when I locked the bracket bolts, as it happens because the door was open during the work, it works it all out for itself
    Good luck
    Stuart
  5. Re: Window alignment off after fitting new regulator
    Aug 2009
    Fraserburgh
    Yeah, Thanks again, what you are saying makes sense, the damned cable holder on the regulator fell out and both cables sprung loose from the carrier :O
    it took me near on 2 - 3 hours to get it back in again, when installing, I neglected to push the window fully up into the door frame, when it came to tightening
    the bottom bolts, I had to slightly pull the regulator frame legs to the left, thinking about it now, if I had fitted it correctly the holes would have lined up perfectly
    oh well, you live and learn.... sigh
  6. Re: Window alignment off after fitting new regulator
    46 Post(s)
  1. Please Help Replaced Window Regulator...Door Not Shutting Properly :( Window Cracked!
    By remfanuk in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-08-2016, 04:12 PM
  2. Window regulator
    By Fourbears in forum Touran - Sharan - Caravelle
    Last Post: 22-07-2014, 10:36 PM
  3. Window Regulator
    By zoomered in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-03-2011, 07:51 PM
  4. n/s/f window regulator
    By estate130 in forum Bora - 1998 - 2005
    Last Post: 07-07-2010, 12:59 PM
  5. window regulator
    By dmnmulvenna@yah in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-01-2009, 03:52 PM
